Arduino Forum i'm A mechanical engineering student (diploma)........... i doing a pnuematic hacksaw as project,,,,,,,
  • Subscribers 416 subscribers
  • Views 326 views
i want to  control servo motor and ultrasonic sensorsor using 8051................... i have a timer to control(555 timer) solenoid valve that control the air to opposite sides of a doble side cylinder.my conditions are when hacksaw placed and switch on measure the distance and take as 0...give the timer output to controller as input.. which the pulse given (by timer .the time of pulses  are controlled by rheostat) to solenoid valve is connect to actuate backward movement the servo motor rotate 180 degree upward and downword complete 180 degree before receive other pulse from timer to actuate forward movement.......................when the switch on the display will show a message to enter value in mm.when this value is entered by two up and down switches and other swith is help to on the hack saw.every forward movement of hacksaw the ulrasonic sensor (ASCII) will measure the distance and it will convert to mm .when the input value  and measurment value is equal, the servo motor receive a pulse and rotate 180 degree above and stop solenoid valve.....NB : after every forward motion the servo motor wil rotate 180 degree upward..and downward 180 before starting another forward stroke............................
PLZ    HELP ME .ITS URGENT
  • bluescreen
    0 bluescreen over 12 years ago
    Hi Subin.
    Welcome to element14, and congrats on your upcoming degree in Mech Engineering. Rather than post this in multiple place on the community, let's keep this thread as your main request for help. Chances are, someone will jump in, but we should give them a chance to respond. image
    Cheers,
    Sagar
