Arduino Forum arduino with xbee
  • Subscribers 417 subscribers
  • Views 323 views
arduino with xbee
i connected xbee transmitter with arduino with thermocouples. when i looked to the receiver xbee its shows incorrect readings. then i checked the readings in arduino after removing xbee,shows the correct value. how can i get the correct value through xbee?
  • ipv1
    0 ipv1 over 12 years ago
    Can you post the schematic?
  • gihu
    0 gihu over 12 years ago
    It seems like you are having problems on the UART configuration, check that UART on arduino and the XBEE transmitter are setup in the same way (baudrate, parity, bit stop), and also do the same in the remote side with the XBEE receiver and whatever you have cnnected, pc, microcontroller, other arduino...
    Hope that helps,
    Miguel
