Arduino Forum My arduino car project
  • Replies 9 replies
  • Subscribers 419 subscribers
  • Views 998 views
yawgyakobo
yawgyakobo over 12 years ago
Hi, My name is Andrew. I have been making an RC car using an arduino. When I connect the stepper motors to the arduino pins, the motors either don't work or rotate slowly. When I connect a motor shield to the arduino I don't know the correct pins to connect the motors since the pins are not labelled 13,12, or 1,2,3 . So I want ask you to send me an image of a motor shield that has labelled pins(13,12 and so on) and connects to an arduino.
  • element14jamie
    0 element14jamie over 12 years ago
    Hello Andrew,
    We hope you are enjoying the element14 Community! I will move this over to the Arduino area as it is a better fit to your question.
    Thank you,
    Jamie
  • booran
    0 booran over 12 years ago
    Hey Andrew,
         Can you share which motor shield you are working with?
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    The shield link would be good
    For sure you can not drive a motor directly from the Arduino, it will draw way too much power and the Arduino can not provide that, you need to use the shield or build your own driver
    When you post he shield info we can help more
  • yawgyakobo
    0 yawgyakobo over 12 years ago in reply to booran
    Thanks for replying but I don't know the name of the shield so I will send you an image of it.
    0 Robert Peter Oakes over 12 years ago in reply to yawgyakobo
    that will work, thanks
  • booran
    0 booran over 12 years ago in reply to yawgyakobo
    Hey Andrew,
         How is that image of the shield coming along? Also is there any text on the shield that might hint at the name of it?
    If you want to control motors with an arduino you need to use a transistor with the collector connected to one of the wires on the motor and the emitter connected to the 5v supply rail on your arduino board then the base pin connected to an I-0 pin on the arduino.
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    The Arduino 5V rail will not be able to supply the current for an RC motor. You will also need more than just a transistor connected the way you describe
    good tutorial is here https://learn.adafruit.com/adafruit-arduino-lesson-13-dc-motors/overview
    regards
    peter
    0 Robert Peter Oakes over 12 years ago in reply to Robert Peter Oakes
    with the exception that this too uses the 5V rail to supply the motor, this will work for the smallest of motors with no load on them but not RC cars
