Arduino Forum Arduino Audio Button
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 417 subscribers
  • Views 880 views
     This year in our 8th grade science class, I was in the advanced class and we referred to ourselves as the "smart class." One of my friends had a specific way of saying it that cracked my teacher up.
I have some Arduino experience and wanted to make a bare-bones system in an enclosure that when she pressed the button it played a recording of my friend saying "The Smart Class" in his voice.
How will I go about doing this with a bare bones system? I know I can get a mp3 player pcb from sparkfun but it is too expensive for this novelty item. I wanted to use an ATMEGA328 or similar. And how would a drive a small .5 ohm speaker and amplify it. Any and all help is appreciated.
Austin
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    well you can use a pulse width modulated output to create the sound and drive a transistor to get the gain necessary to drive a small speaker
    btw, speakers are not normally .5 Ohms, they would typically be 4, 8 or more ohms.
    You would not need to smooth the PWM as the speaker would do that for you (Much like a class D amplifier)
    the biggest issue is getting the recording into a format that can be sent to the PWM timer and also if it will fit within 32K along with a boot loader and basic routine to read a switch and output the binary stream,
    If the sound bite is not too long it may well be doable which looking at your message should fit.
    all of this could be done with a ATMEGA328 (32K program space)
    You could also use 8 output pins (Or less) and create a simple R/2R digital to analog convertor but the issue still remains about digitizing the sound bite
    0 e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    How would I get the audio onto the chip without having to wire up, say a micro-sd card reader? And then get it to play. And also, how exactly do I set up the transistor circuit? You are correct the speaker was 8 ohms, and .5 watts.
    Austin
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    you could define it as a char[] long enough to hold the data as part of the program, then you just have to loop through it when the button is pressed
    a char is 8 bits, same as a byte so as long as you have enough program space for it all, you good to go
    Okay, and the audio recording itself. Can it be imported into the system memory? Or do I have to convert it to a char or something? I am not an audio person, nor am I super advanced with Arduinos.
    well that's where my current skills fade, I have not looked much at converting audio into a form consumable with an Arduino or other device
    If I find something I will post it but I suggest you try google "Waveform convert to WAV from MP3" or something
    Okay, what about pairing an SD card reader without the shield, since I am making it bare-bones? That might be an easier alternative.
    well you can get a board for a couple of $$ for example http://www.banggood.com/Arduino-Compatible-SD-Card-Module-Slot-Socket-Reader-For-Mp3-Player-p-74105.html?currency=CAD&utm_source=google&utm_medium=shopping&utm_content=miko_ruby&utm_campaign=Electronic-xie-ca&gclid=CIDz06W0wL4CFVQFMgodjwQA3g
    and this should simply work with the SD software
    Peter
    0 Robert Peter Oakes over 12 years ago in reply to Robert Peter Oakes
    then you can have as long a sound file as you want
    there are plenty of examples to play a file from SD
    For example http://forum.arduino.cc/index.php?topic=75359.0
    Okay thank you, I have been experimenting with a transistor amp, with a 2n 3904. And the first method may work. I will just need to experiment some.
    Thanks for all the help,
    Austin
