Arduino Forum Serial won't work!
  • Replies 14 replies
  • Subscribers 417 subscribers
  • Views 1600 views
  • help
  • work
  • heating
  • code
  • please
  • serial
  • won't
Serial won't work!
I'v bin trying to making a heating auto heating system that turns the knob with a servo, I can change the var upload and it will change position but every time i try to set up commands thought serial I get nothing, not even printing the serial I just sent.  I'v tried this over and over again in different variations and am starting to get sick of just having my arduino uno just hanging from my wall doing nothing. please help.
my code:
#include <Servo.h>
Servo officeHeat;
int heat40 = 800;
int heat45 = 950;
int heat50 = 1150;
int heat55 = 1325;
int heat60 = 1500;
int heat65 = 1700;
int heat70 = 1825;
int heat75 = 1975;
int heat80 = 2150;
int officeHeatSetTo = heat60;
void setup(){
  Serial.begin(9600);
  officeHeat.attach(9);
void loop(){
//check if serial is available
  while(Serial.available() > 0){
    //read serial and set var
    int heatCommand = Serial.read();
    //if the command is A then set heat to 65
    if(heatCommand == 'A'){
      officeHeatSetTo = heat65;
  officeHeat.writeMicroseconds(officeHeatSetTo);
//tell computer the current set temp.
  while(true){
    if(officeHeatSetTo == 800){
    Serial.println("40");
    if(officeHeatSetTo == 950){
    Serial.println("45");
    if(officeHeatSetTo == 1150){
    Serial.println("50");
    if(officeHeatSetTo == 1325){
    Serial.println("55");
    if(officeHeatSetTo == 1500){
    Serial.println("60");
      if(officeHeatSetTo == 1700){
    Serial.println("65");
      if(officeHeatSetTo == 1825){
    Serial.println("70");
      if(officeHeatSetTo == 1975){
    Serial.println("75");
      if(officeHeatSetTo == 2150){
    Serial.println("80");
  delay(1000);
  • neilk
    0 neilk over 12 years ago
    Hi Kyle
    You are reading a character from the serial input into an integer variable:
    with the above code, heatCommand will be equal to the Ascii value of 'A' - ie 65 (if you type an 'A', of course).
    If you modify your code to use a character variable, then heatCommand will be equal to character 'A', when you type 'A'
        char heatCommand = Serial.read();
    Good luck
    Neil
    0 e14 Contributor over 12 years ago in reply to neilk
    changed the
    to
    and it still doesn't work
  • neilk
    0 neilk over 12 years ago in reply to e14 Contributor
    Can you be more precise and describe exactly what does happen? "It still doesn't work" doesn't tell us very much.
    I upload the program to my arduino open serial.  I see the 60 being printed(showing the current set temp.) but, when I send the A nothing changes(servo doesn't move or make a noise of trying and the Serial.println doesnt work)
    #include <Servo.h>
    Servo officeHeat;
    int heat40 = 800;
    int heat45 = 950;
    int heat50 = 1150;
    int heat55 = 1325;
    int heat60 = 1500;
    int heat65 = 1700;
    int heat70 = 1825;
    int heat75 = 1975;
    int heat80 = 2150;
    void setup(){
      Serial.begin(9600);
    void loop(){
          Serial.println("Heat set to 65");
      while(true){
      delay(1000);
  • neilk
    Sorry Kyle - I only looked as far as the first, very obvious error
    The structure:
      while(true){
    has the effect of locking the sketch into the while loop, so the serial read is only executed once - the first time through.
    Remove  while(true){     and its corresponding  closing brace - } and the program  flow will be correct.
    It works for me, although I don'y have a servo connected.
    Hope this helps.
    Neil
    well I i changed it to while true...I got the "heat set to 65" but, it wasn't printing the the the 60 or 65 like it should be and the servo didn't move.
    #include <Servo.h>
    Servo officeHeat;
    int heat40 = 800;
    int heat45 = 950;
    int heat50 = 1150;
    int heat55 = 1325;
    int heat60 = 1500;
    int heat65 = 1700;
    int heat70 = 1825;
    int heat75 = 1975;
    int heat80 = 2150;
    void setup(){
      Serial.begin(9600);
    void loop(){
      while(true){
      while(true){
      delay(1000);
    Then slashed out while true and it went back to Serial.println the for 60 started working again but, now it doesn't give me the "heat set to 60" or move the servo
    #include <Servo.h>
    Servo officeHeat;
    int heat40 = 800;
    int heat45 = 950;
    int heat50 = 1150;
    int heat55 = 1325;
    int heat60 = 1500;
    int heat65 = 1700;
    int heat70 = 1825;
    int heat75 = 1975;
    int heat80 = 2150;
    void setup(){
      Serial.begin(9600);
    void loop(){
    //  while(true){
      while(true){
      delay(1000);
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    what you need is something like this (Which works on my UNO)
    #define ServoEnabled 1 // change to 1 to enable servo output, 0 to disable
    #if ServoEnabled
    #include <Servo.h>
    #endif
    #define heat40  800
    #define heat45  950
    #define heat50  1150
    #define heat55  1325
    #define heat60  1500
    #define heat65  1700
    #define heat70  1825
    #define heat75  1975
    #define heat80  2150
    #define  printDelay 1000 // 1 second between prints
    int HeatSetting = 0;
    int newHeatSetting = 0;
    long printTimer = 0;
    #if ServoEnabled
    Servo officeHeat;
    #endif
    void setup()
       Serial.begin(9600);
       HeatSetting = heat60;
       newHeatSetting = HeatSetting;
    #if ServoEnabled
      officeHeat.attach(9,800,2150);
    #endif
       printTimer = millis() + printDelay;
    void loop() {
      // Any new commands ?
      check_serial();
    #if ServoEnabled
      check_Servo();
    #endif
      // Check if time to print heater setting
      if (millis() > printTimer)
        Serial.print("Temp Set to ");
        Serial.println(HeatSetting, DEC);
        printTimer = millis()+printDelay;
      // Do other stuff
    void check_serial()
      char a=Serial.read();
      if ((a>='0')&& (a<='Z'))
        switch (a)
            case 'A' :newHeatSetting = heat40; break;
            case 'B' : newHeatSetting = heat45; break;
            case 'C' : newHeatSetting = heat50; break;
            case 'D' : newHeatSetting = heat55; break;
            case 'E' : newHeatSetting = heat60; break;
            case 'F' : newHeatSetting = heat65; break;
            case 'G' : newHeatSetting = heat70; break;
            case 'H' : newHeatSetting = heat75; break;
            case 'I' : newHeatSetting = heat80; break;
            case '0' : Serial.println("0 Received"); break;
            case '1' : Serial.println("1 Received"); break;
            case '2' : Serial.println("2 Received"); break;
            case '3' : Serial.println("3 Received"); break;
            case '4' : Serial.println("4 Received"); break;
            case '5' : Serial.println("5 Received"); break;
            case '6' : Serial.println("6 Received"); break;
            case '7' : Serial.println("7 Received"); break;
            case '8' : Serial.println("8 Received"); break;
            case '=' : Serial.println(HeatSetting, DEC); break;
            default : break;
    #if ServoEnabled
    void check_Servo()
      if (newHeatSetting != HeatSetting)
        officeHeat.writeMicroseconds(HeatSetting);
        HeatSetting = newHeatSetting;
    #endif
    this will only change the servo when the current value is different from the new value, it does not waste time in delays and has a nice structured case for managing commands
    regards
    Peter
  • neilk
    Kyle
    The change you made after my last post wasn't the change I suggested  - you inserted another while(true){ in a different part of the sketch, instead of removing the existing while(true){.
    However, now that Peter has written the sketch for you, you need no further help from me.
    Good luck
    Neil
    0 Robert Peter Oakes over 12 years ago in reply to neilk
    Ya... I kinda got carried away with it as it was bugging me so much. I think I will turn it into a Blog entry for future reference as there are many items I have covered off in the version i posted like using defines vs INTS etc.
    Should be useful as educational material
    Peter
    I did notice that the Servo library does odd things at the low end of the range though, asking for lower pulse width actually ended up increasing the pulse width not decreasing it, i even added the initialization to try to mitigate it but it had no effect. I was monitoring with an oscilloscope to observe the output as I did not have an actual servo to hand
