Arduino Forum IR send for Carrier Air Conditioners
  • Subscribers 417 subscribers
  • Views 1599 views
  • ir
gunaseelan
gunaseelan over 12 years ago
Carrier Air Conditioners  On/Off :
Switch On :
9368D502
Unknown encoding: 9368D502 (32 bits)
Raw (100): 7048 4450 -4300 600 -1550 600 -500 600 -1550 650 -1550 600 -500 600 -500 600 -1550 600 -500 600 -500 600 -1550 600 -500 600 -500 600 -1550 600 -1600 600 -450 650 -1550 600 -500 600 -450 650 -1550 600 -1550 650 -1550 600 -1550 650 -1550 600 -1550 650 -1550 600 -1550 600 -500 600 -500 600 -500 600 -450 650 -450 650 -450 600 -500 600 -500 600 -450 650 -450 650 -450 600 -500 600 -500 600 -500 600 -1550 600 -1550 650 -1550 600 -1550 650 -1550 600 -1550 650 -1550 600 -1550 600
Switch Off :
FA36E9A0
Unknown encoding: FA36E9A0 (32 bits)
Raw (100): 7206 4450 -4300 650 -1550 600 -500 600 -1550 600 -1550 650 -450 650 -450 600 -1600 600 -450 650 -450 600 -1600 600 -450 650 -450 650 -1550 600 -1550 600 -500 600 -1550 650 -450 600 -1600 600 -1550 600 -1600 600 -1550 600 -500 600 -1550 650 -1550 600 -1550 600 -500 600 -500 600 -500 600 -450 650 -1550 600 -500 600 -450 650 -1550 600 -1550 650 -1550 600 -500 600 -450 650 -450 650 -450 600 -500 600 -500 600 -450 650 -450 650 -1550 600 -1550 600 -1600 600 -1550 600 -1550 600
The Hex codes , which i receive is the same everytime.  smiley  but the raw data varies ..
Now How should  I will write the irsend to send this code for the air conditioner?
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +1
    The data stream you are seeing is actually the microseconds of the carrier, this will vary a bit due to the software timing of the ir. All you need to do is take the average of each pulse in order to simplify…
    here is a sample from a library I am modifying // pulse parameters in usec #define NEC_HDR_MARK 9000 #define NEC_HDR_SPACE 4500 #define NEC_BIT_MARK 560 #define NEC_ONE_SPACE 1600 #define NEC_ZERO_SPACE…
    0 Robert Peter Oakes over 12 years ago
    All you need to do is take the average of each pulse in order to simplify the replay
    If you want more info, the best place to look is the code for the or library, the timing will all be there
    #define NEC_ZERO_SPACE 560
    #define NEC_RPT_SPACE 2250
    #define SAM_HDR_MARK 4500
    #define SAM_HDR_SPACE 4500
    #define SAM_BIT_MARK 560
    #define SAM_ONE_SPACE 1600
    #define SAM_ZERO_SPACE 560
    #define SAM_RPT_LENGTH 45000
    #define SONY_HDR_MARK 2400
    #define SONY_HDR_SPACE 600
    #define SONY_ONE_MARK 1200
    #define SONY_ZERO_MARK 600
    #define SONY_RPT_LENGTH 45000
    #define RC5_T1 889
    #define RC5_RPT_LENGTH 46000
    #define RC6_HDR_MARK 2666
    #define RC6_HDR_SPACE 889
    #define RC6_T1 444
    #define RC6_RPT_LENGTH 46000
    #define TOLERANCE 25  // percent toleran
  • gunaseelan
    0 gunaseelan over 12 years ago in reply to Robert Peter Oakes
    Hello Peter ,
                               May i know what library you are referring and then how about this way ?
    unsigned int Signal_0_0[] = {3750,1850,500,400,500,1350,550,400,500,1350,500,450,500,1350,550,400,500,1350,500,450,500,1350,500,450,500,1350,500,1350,500,450,500,1350,500,450,500,1350,500,1400,450,1400,500,1350,500,450,500,400,500,1400,450,1400,500,450,500,400,550,400,500,450,500,1350,500,400,550,400,500,450,500,400,500,450,500,450,450,1400,500,450,450,450,500,450,500,450,450,1400,500,400,500,450,500,450,500,1350,500,450,500,400,500,450,500,1350,550,400,500,400,550,400,500,450,450,1400,500,450,450,450,550,400,500,450,500,400,500,450,500,400,500,450,500,450,500,400,550,400,500,450,500,400,550,1350,500,400,500,450,500,400,550,400,500,450,500,400,500,450,500,450,450,450,550,400,500,400,500,1400,500,450,500,400,500,450,500,400,500,450,500,450,500,400,500,450,500,450,450,450,550,1300,500,450,500,1350,500,1400,450,1400,500,1350,500,1400,500,400,550,400,500,450,500,400,500,450,500,1350,500,1350,500,1000};
    int khz=38;
    void setup()
      Serial.begin(9600);
    void loop() {
             if (Serial.read() == '0') {
             Serial.println("Transmitting");
             for (int i = 0; i < 3; i++)
             irsend.sendRaw(Signal_0_0, sizeof(Signal_0_0)/sizeof(int), khz);
             delay(40);
    0 Robert Peter Oakes over 12 years ago in reply to gunaseelan
    sorry for the delay, yes without testing it looks like that should work
