Arduino Forum How can we make devices so slim?
  • Replies 8 replies
  • Subscribers 420 subscribers
  • Views 895 views
the_future
the_future over 12 years ago
As a novice in the electronic world i have wondered for so long
now how we can make devices so slim like a phone. I wonder
how all the components fit in so nicely and don't affect the
sleek appearance of the device. Are there slim ardunio boards
or do i have to make my own PCB (Are there tutorials around
on making PCBs)
  • ootbrobo
    0 ootbrobo over 12 years ago
    Condensing electronics is all about selecting component packages, this includes connectors too.  cell phones use a lot of QFN and BGA based ICs because they are generally low profile, and they consume the smallest board area.   In designs containing multiple PCBs you commonly see FFC (flat flexible cable) or flex PCBs making the connections between boards.
    As for slim arduinos,  I think some of the Sparkfun pro series boards are reasonably low profile, but as soon as you add on the typical .1" headers the board becomes fat as ever.  You really can't make a slim arduino, while maintaining shield compatibility.
  • the_future
    0 the_future over 12 years ago in reply to ootbrobo
    Ahhh Okay, so if I really wanted to make a slim product would it just be best to
    create my own PCBs? and How can you create one?
    Sorry for all my questions I am still at school image
  • ootbrobo
    0 ootbrobo over 12 years ago in reply to the_future
    Yep, you create a PCB using a software package such as EAGLE.  Once you come up with a design you send it out for fabrication.  If you are just starting out the best option out there, in my opinion, is oshpark.
  • magnus2112
    0 magnus2112 over 12 years ago
    Or you can create one yourself image
    i suggest that you watch this tutorial by Ben image
    https://www.youtube.com/watch?v=N3DGbwVXyN8
  • ootbrobo
    0 ootbrobo over 12 years ago in reply to magnus2112
    True, but if you are just learning how to design a PCB you already have enough on your plate.  Adding the learning curve and inherent constraints of homebrew PCB manufacturing overly complicates the learning process.  When you factor in the purchase of the copper clad etching solution, and tiny drill bits, you really don't even save much money.  OSHPARK gives you 3 boards for 5$ per square inch at 2 layers.  Putting that in perspective a standard arduino is about 5.6 sq inches.  So you could get 3 quality arduino PCBs made for $28.
  • kidiccurus
    0 kidiccurus over 12 years ago
    A solution for some projects is to use an attiny. It is a smaller version of the chip in the uno with only a few pins, and it can be programmed via an arduino. See this instructable for more info. http://m.instructables.com/id/Programming-the-ATtiny/
  • fidelsalinas
    0 fidelsalinas over 12 years ago
    If you wanna go really thin you can always go with flexible PCBs. Seeeduino Film, maybe the first Arduino(TM) compatible board on FPC – Seeed-3
  • the_future
    Thank you all for your help I am just a beginner and i will just try all
    the suggestions and see what works but I am really thankful for
    your support and advise
