Arduino Forum Detect oscillations
  • Replies 33 replies
  • Subscribers 421 subscribers
  • Views 3540 views
  • oscillations
  • processing
  • accelerometer
  • movement
  • algorithm
Detect oscillations
kosme
kosme over 12 years ago
I'm trying to use an Arduino and a MMA8452Q accelerometer to sense movement and detect oscillations. What would be the best way to analyze and process the info to detect oscillations at a specific frequency range and act accordingly?
Edit 1:
Aswering Michael Kellett questions
Must you detect  a single frequency (known in advance) or a band of frequencies.
I must detect if the oscillation is in the 4-8Hz range.
Is the sampling rate under direct contorl of the Arduino or is it set by the accelerometer.
It is mostly under control of the Arduino. The accelerometer is set to sample at a certain rate but I can "miss steps" simply by reading the I2C interface at a much lower rate.
What is the range of frequencies and amplitudes you must detect.
I must detect if the oscillation is in the 4-8Hz range. The amplitude will be handled by the accelerometer but I expect it to be between ±4G's
Are there other signals present at the same time which you must ignore.
No, but it would be nice to be able to log the results.
How quickly must you reach a  decision when the signal appears.
I haven't decided that yet but the oscillation must persist for several seconds before action is taken. The exact number of seconds hasn't still been determined.
What accelerometer are you suing.
MMA8452Q I2C accelerometer
    michaelkellett over 12 years ago +1 suggested
    Hello Enrique, It makes it easier for people to follow the thread if you just add a new message rather than editing the original question. It seems that you want to detect energy in the band 4 - 8Hz, not…
  • D_Hersey
    D_Hersey over 12 years ago +1
    SO has just come down with Parky's, so I know of the characteristics of the tremors, they do seem to have a characteristic wave form, narrow fq, fairly constant amplitude between ramp-up and ramp-down…
  • kosme
    0 kosme over 12 years ago in reply to D_Hersey
    Don, would you care explaining a little more about the counting method? I does sound interesting and I am still reviewing my options before making a decision of the method I will use.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to D_Hersey
    I love the discussion but I think poor old Enrique Condes may be scratching a head wondering what is going on lol
    I am intrigued as to where it will lead, but Enrique has been a little quiet image
    Just saying.
    Keep up the debate.
    peter
  • dragonstyne
    0 dragonstyne over 12 years ago in reply to Robert Peter Oakes
    Interesting dialogue you guys are having here.
    -Steve
  • kosme
    0 kosme over 12 years ago in reply to Robert Peter Oakes
    Hehe, thanks for the interest Peter. I must say I don't quiet know how to contribute to the debate, anytime something is asked or something interesting is mentioned, I try to either answer or ask about it, but the results have been mixed between successful and probably overlooked.
    - Enrique
  • dragonstyne
    0 dragonstyne over 12 years ago in reply to kosme
    Greetings Enrique,
    Sometimes we have to go through chaos to get to the answer. It may take a combination of ideas for success. the more ideas greater the chance reach your goal.
    -Steve
    0 michaelkellett over 12 years ago in reply to D_Hersey
    Don, you are making huge and unjustified assumptions about the signal ('because the signal data is so sinuate') - the OP hasn't shared any recordings of acceleration data and until that data is available it just isn't possible to suggest an event detection algorithm.
    Step 1 is to look at the data, and, since it comes out of the accelerometer as a time series, that's the best way to look at it first.
    'The Fourier Transform is (like, say, negation) self-inverse:'
    This is only partially true - to reconstruct a discrete event correctly you need an infinite time series, practical methods of sampling always involve some messing about like windowing, overlapping etc. This can all be very useful in trying to understand some data which is why I suggested the OP should try to get hold of  a copy of MATLAB which can do a lot of this stuff.
    'Therefore it does not lose (aside from quantization) information' - I'll be pedantic again - Fourier Transforms are linear, it's the Discrete Fourier Transform that involves quantizing. Since the data from the accelerometer is a digital time series already there need be no further loss in that area.
  • dragonstyne
    From what I gather here, you want to record the trimmer episodes and not normal movements or movements such as scratching. Couldn't you consider each movement as a a pulse.  The duration and consistency of the pulse would be used to indicate an episode.
    Am I close?
    -Steve
  • kosme
    0 kosme over 12 years ago in reply to dragonstyne
    Indeed Steve, I want to record those events, not normal movements ranging from scratching to tripping.
    - Enrique
  • kosme
    0 kosme over 12 years ago in reply to michaelkellett
    I agree with Don, indeed the signal I want to measure is very periodic. He correctly assumes that the shaking events I want to record and analyze have periodic movements that could be plotted not necessarily as sines, but as a triangular wave.
    - Enrique
    Ps. What is an OP? I am not familiar with that term or acronym.
    0 michaelkellett over 12 years ago in reply to kosme
    OP = Original Poster
    If you haven't come across this term that means you may not have discovered usenet.
    You should be able to access it via your ISP's news server or (less good) via Google.
    Check out Usenet - Wikipedia, the free encyclopedia
    Get yourself a news reader programme and have  a look.
    Do you have any plots of typical acceleration data to show use the kind of events you want to detect and reject.
