Arduino Forum Arduino learning
  • Replies 10 replies
  • Subscribers 420 subscribers
  • Views 972 views
Arduino learning
royston02
royston02 over 12 years ago
Which is the best book tolearn anroid arduino9including taking data from inbuilt accelorometer)
  • royston02
    royston02 over 12 years ago in reply to Robert Peter Oakes +1
    If you use the famous search engine called Google, a number of choices are found and I want ot narrow it down. I also want it to be wireless.(bluethoot) Many of you may find it difficult to find a specific…
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    This should be two separate things
    Arduino is based on Atmel Micro-controllers and does not typically include an accelerometer. here you are buying into a hardware platform
    Android is a complete operating system based on Linux and can run on many different hardware platforms, typically something like an Arm Cortex Microprocessor and is multitasking
    the use and approach to programming for each is very different
    What I learned the most from about Arduino was the book by Massimo Banzi (co founder of the microcontroller)  getting started with Arduino, you can find the book at Radio Shack or Maker Shed.com.
  • vaghasiamadhuri
    0 vaghasiamadhuri over 12 years ago
    I have learned arduino+android with direct hands on and support of arduino and processing forum, online tutorial and community....this is best way I think to learn android and Arduino...
    may be this site will be useful for getting started with less complexity Amarino - "Android meets Arduino" - Home ......
    All the best
  • royston02
    0 royston02 over 12 years ago in reply to Robert Peter Oakes
    Peter, I'musing the accelorometer from the android phone to control 2/1 motor/s and 4 servos(2 outputting the same value) and want to know a book regarding this programming.
  • royston02
    0 royston02 over 12 years ago in reply to e14 Contributor
    I want a bok with arduino+andriod not just arduino. thanks though!
  • royston02
    0 royston02 over 12 years ago in reply to vaghasiamadhuri
    I want it with only the slave module(without extra stuff) because I want it to be tin and small.
  • royston02
    0 royston02 over 12 years ago in reply to royston02
    any idea????????????
    0 mcb1 over 12 years ago in reply to royston02
    What have you found using the famous search engine called Google.
    If you perhaps had a list of possible books, then others might be able to say that one is good, or not.
    Hi there again
    As for a book recommendation, sorry can not help there
    As to how to connect them, it seems using the OTG on the Android device ("On The Go" USB connection), you should be able to communicate with the Arduino device (Attached to the other end of the USB) in a similar way as you use the PC to talk to the Arduino
  • royston02
    Many of you may find it difficult to find a specific book so any way to communicate wirelessly with a chip?microcontroller(wifi may require to update to the server/web connection) so I'm looking for bluethoot .
