Arduino Forum Electronics and Creation
  • Replies 20 replies
  • Answers 2 answers
  • Subscribers 422 subscribers
  • Views 2197 views
Thank you for visiting this discussion. If you can share your wisdom with me, that would mean a ton. I want to pursue electronics/electrical engineering as a hobby to create awesome things (which things I do not know yet because I do not know enough about the subject). However, I have no idea how to start. Should I start buying books to read on electronics/electrical engineering or should I buy equipment or should I just take electronics that I find in my house and break them apart and fix them? Any advice would be awesome.
  • alanwood
    alanwood over 12 years ago +2 suggested
    Hi, My suggestion is to start off with something simple such as this kind of thing: 200 in 1 Electronic Projects Lab Kit - RobotShop No soldering or tools are required beyond a pair of wire cutters and…
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to alanwood +2 suggested
    Excellent advice alanwood if Jae is at the absolute beginner stage with no electronics background then going this route will avoid a huge headache going forward as the basics will be understood and therefore…
    jw0752 over 12 years ago +1
    http://www.electronics-tutorials.ws/ Hi Jae, The true path lies with some of each of the things you mentioned. I have always found the mixture of learning from books with the hands on of hooking things…
  • alanwood
    0 alanwood over 12 years ago
    No soldering or tools are required beyond a pair of wire cutters and wire strippers. You start off by building simple circuits and you can try changing component values to see what happens. No previous knowledge is assumed and you will build up your skills gradually in a structured way. I wouldn't get into Arduino just yet until you know about current, voltage, resistance, the difference between analogue and digital etc. It really does help to have the basics nailed!
    It may also help to subscribe to a monthly magazine on the subject. Choose one that caters for beginners.
    Good luck with your adventures and above all: have fun!
    Alan
    0 Robert Peter Oakes over 12 years ago in reply to alanwood
    Excellent advice alanwood if Jae is at the absolute beginner stage with no electronics background then going this route will avoid a huge headache going forward as the basics will be understood and therefore trouble shooting once you introduce software will be easier.
    The nice thing is this community can help either way as many of us are already seasoned Electronics Engineers so even starting with the basics does not mean were not there for you, we can be
    Regards
    peter
    0 shabaz over 12 years ago in reply to Robert Peter Oakes
    I loved those x00-in-1 kits, they were awesome. Mine was a 160-in-1 kit. Good old Tandy/Radio Shack : )
    0 e14 Contributor over 12 years ago in reply to alanwood
    Alan,
    I want to thank you so much for getting back to me and giving me such a helpful answer. I will definitely consider the kit. Seriously, the people in this forum are so helpful. Once again, thank you so much.
    Best, Jae Kim
    0 e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    Peter,
    Thank you for responding to my post. Though seemingly irrelevant to this topic, my ultimate desire for pursuing this discipline is to help and serve people in the future. And I mean helping and serving people in a significant sense. So, assuming that you understand the capacity of what electronics can do, is this a good means by which to do this? Because if it is not, I, personally, do not think it is a sensible thing for me to invest my time, energy, and resources to this discipline. But from what I have heard, it is very beneficial meeting the needs of others.
    Furthermore, I want to invest in a 200 in 1 Kit and just to confirm one more time, this will give me a good foundation for electrical engineering?
    Also, in your opinion, what is the difference between an electrician and an electrical engineer? Does the 200 in 1 Kit prepare me for an engineer or an electrician? Or both?
    Best, Jae Kim
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    Well, I am glad your pursuing your dream. as far as electrician or electrical engineer, I learned my trade way back in the mid 1970s and then it was Electrician or Electronics Engineer.
    The way I used to explain the difference was the Electrician dealt with everything from the wall socket out to the power station, the electronics Engineer dealt with everything from the wall socket into the various appliances be it a washing machine to a Laptop and more.
    these days the distinction is a little blurred with the advent of micro controllers and the like showing up everywhere and more cross skill learning going on.
    Another way of looking at it in simplistic terms is the electrician deals with the high voltage stuff and the electronics engineer the low voltage stuff (Less than 100V for example) but as I said, these days thts a little too simplistic
    Helping people with the trade is an admirable thought and objective but please bear in mind, electrician or electronics can be used for good and evil (Bombs to prostheses) so its how you choose to use what you learn but i digress
    In your case, the electronics side I would think will enable you to better help people, designing medical aids, sensor equipment for the infirm and disabled, even home automation to help people save money and the environment
    The 200 in 1 kit will help you with the electronics primarily but the actual learning about electricity will serve both . The kit is geared toward electronics and in my opinion is a good choice for you based on your goals, even if you change your mind in a few years and want to change track, what you will learn will not be wasted
    Hope this helps
    Oh, Im of the Electronics Engineering variety image
    Peter
    Peter,
    I understand that it does get confusing when things get posted twice. I appreciate your telling me so I do not do this in the future. Thank you again for all your help.
    God bless, Jae Kim
    no problem, still here to help when needed
    Peter
  • nschreiber0813
    0 nschreiber0813 over 12 years ago
    Dear: Jae
    If you are trying to start with electrical/software engineering I actually did the following to become as skilled as I am. Do the following research on electrical which are Diodes, Capacitors, batteries, electrical engineering, Microcontrollers, Switches ,and more. You can find all that stuff here.
    Diode - Wikipedia, the free encyclopedia
    Capacitor - Wikipedia, the free encyclopedia
    Battery (electricity) - Wikipedia, the free encyclopedia
    Microcontroller - Wikipedia, the free encyclopedia
    Electrical engineering - Wikipedia, the free encyclopedia
    Switch - Wikipedia, the free encyclopedia
    I understand wikipedia is not the most reliable source for information but that is what I used to learn engineering so if you want a book go here.
    Electrical Engineering 101, Third Edition: Everything You Should Have Learned in School...but Probably Didn't: Darren As…
    Also for software engineering I had trouble learning it on my own so I read a book and this book I do own myself and it is what I recommend for you.
    Amazon.com: Exploring Arduino: Tools and Techniques for Engineering Wizardry (9781118549360): Jeremy Blum: Books
    So in that case I wish you good luck and I hope you have as much fun as I did.
    0 e14 Contributor over 12 years ago in reply to nschreiber0813
    Noah,
    Thank you for taking the time to respond to my posts and suggesting all these resources. I actually facebook messaged the author of that book asking how I should start my journey in electrical engineering and he responded. He is super nice. And I will take a look at the book that you had suggested as well. Thank you so much!
    Best, Jae Kim
