Arduino Forum Gas sensors with pulse sensor,no serial output problem, PLEASE HELP!!!
  • Subscribers 417 subscribers
  • Views 568 views
  • sensors
im new to arduino, can i please know that how use two analog gas sensors,
a temparature sensor with the pulse sensor (www.pulsesensor.com), pulse sensor having interrupts
so i cant get serial output of those all in once, anyone know how to do that, what i need to do?
how to get all sensors output and pass to serial (bluetooth device) ?
please HELP ME!!!
    0 michaelkellett over 12 years ago
    For a start you need to tell us which sensors you are trying to use and post links to the data sheets.
  • nschreiber0813
    0 nschreiber0813 over 12 years ago
    Dear: Buddhima
    I am sorry but you weren't very specific. You need to tell us first of all what sensor you are using, the datasheet you are using, and what code you are using. Then that should be enough for us to help you.
    0 e14 Contributor over 12 years ago in reply to michaelkellett
    MQ7 - Carbon monoxide sensor - https://www.sparkfun.com/datasheets/Sensors/Biometric/MQ-7.pdf
    MQ2 - methane sensor - http://www.seeedstudio.com/depot/datasheet/MQ-2.pdf
    DHT11 - temparature sensor - http://www.micro4you.com/files/sensor/DHT11.pdf
    pulse sensor - www.pulsesensor.com
    and i used arduino uno board for processing
    thank you and please help...
    0 e14 Contributor over 12 years ago in reply to nschreiber0813
    #include <DHT11.h>
    int pin = 4;
    DHT11 dht11(pin);
    int coPin = A0;
    int pulsePin = A1;
    int methanePin = A2;
    int pulseRate = 0;
    int sensorValue = 0;
    int tempValue = 0;
    int methaneValue = 0;
    int coValue = 0;
    int blinkPin = 13;                // pin to blink led at each beat
    int fadePin = 5;                  // pin to do fancy classy fading blink at each beat
    int fadeRate = 0;                 // used to fade LED on with PWM on fadePin
    // these variables are volatile because they are used during the interrupt service routine!
    volatile int BPM;                   // used to hold the pulse rate
    volatile int Signal;                // holds the incoming raw data
    volatile int IBI = 600;             // holds the time between beats, must be seeded!
    volatile boolean Pulse = false;     // true when pulse wave is high, false when it's low
    volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
    void setup()
       Serial.begin(9600);
      while (!Serial) {
          ; // wait for serial port to connect. Needed for Leonardo only
    void loop()
      interruptSetup();
       sendDataToProcessing('S', Signal);     // send Processing the raw Pulse Sensor data
      if (QS == true){                       // Quantified Self flag is true when arduino finds a heartbeat
            fadeRate = 255;                  // Set 'fadeRate' Variable to 255 to fade LED with pulse
            sendDataToProcessing('B',BPM);   // send heart rate with a 'B' prefix
            sendDataToProcessing('Q',IBI);   // send time between beats with a 'Q' prefix
            QS = false;                      // reset the Quantified Self flag for next time
      delay(20);
      get_co();
      get_methane();
      get_temp();
      delay(5000);
    int get_co()
    coValue = analogRead(coPin);
    Serial.println(coValue);
    int get_methane()
      methaneValue = analogRead(methanePin);
      Serial.println(methaneValue);
    void get_temp()
    int err;
      float temp, humi;
      err=dht11.read(humi, temp);
      delay(DHT11_RETRY_DELAY); //delay for reread
      Serial.println(temp);
      Serial.println(humi);
    void sendDataToProcessing(char symbol, int data ){
                                               // symbol prefix tells Processing what type of data is coming
        Serial.println(BPM);                // the data to send culminating in a carriage return
    //////// here is my code i think problem is with the code please help. thank you.///////
