Arduino Forum project help please its really important
  • Subscribers 417 subscribers
  • Views 656 views
  • diy
  • servo
  • gps
so im a highschool student who is competeing in a uav flight contest in australia. we have to drop a package from our quad copter. i was thinking of using arduino and a gps module to get the distance between the starting point and the dropping zone. once the distance is reached i wanted a servo to turn enabling the package to fall. the thing is i have no idea how to program this and i really need help. any help or ideas would be great.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    I would suggest looking at using a solenoid rather than a servo, it is simpler to drive and also probably can be way lighter. It will only require a single output from an Arduino or other micro-controller to trigger it (Via an N channel Mosfet or other transistor)
    see here for some of my videos on the subject
    direct drive to an NChannel FET  <-- of most interest to you
    https://www.youtube.com/watch?v=gBSTlV54aJg
    Opto Isolated output to an P Channel FET witn mention on how to also drive a N Channel FET
    https://www.youtube.com/watch?v=ckptzvpM6Es
    and
    Opto isolated inputs:
    0 e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    The thing is i need to use a servo because of our drop design
    Here's a link to our video so you can kinda get an idea of what im talking about
    https://www.youtube.com/watch?v=2AWD2IIovDU
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    OK, looks simple enough, the arduino has a library for servos of this kind and uses a single PWM output to drive it
    look here for details http://arduino.cc/en/Tutorial/sweep, there are plenty more on the site, just search Arduino and Servo and Library
    hope this helps
    peter
    And go here for plenty of ideas regarding a GPS module, there are plenty of other sources
    http://www.adafruit.com/products/1272
    0 dougw over 12 years ago
    You will likely need a GPS module (such as Ublox NEO-6M GPS Module Aircraft Flight Controller For Arduino) and a small microcontroller (such as an arduino nano) to decode the NMEA position messages from the GPS module and compare the position to your target position. You can download NMEA decoding libraries for the arduino from the web.
    If you want to use a servo motor for the dump mechanism, you will need the arduino to generate 50 pulses per second on a digital output pin where each pulse is either 1 ms long or 2 ms long depending on which position the servo is in. Servo drivers for arduino are also available on the web.
    0 e14 Contributor over 12 years ago in reply to dougw
    well so far im using an arduino uno board and an adafruit ultimate gps breakout v3 module. do you think ill be able to do it with these? aalso the thing i really need help on is the programming part of this
