Arduino Forum Processing
  • Replies 9 replies
  • Subscribers 417 subscribers
  • Views 969 views
Processing
I want to read  data from Onavi USB seismic sensor through serial port.Is it possible with Processing?
    0 michaelkellett over 12 years ago
    You're going to need to provide some detail here  - how about a link to the specification of the sensor.
    0 e14 Contributor over 12 years ago in reply to michaelkellett
    here it is Michael
    http://www.o-navi.com/Gyrocube3A_4.pdf
    0 michaelkellett over 12 years ago in reply to e14 Contributor
    Have you actually got one of these - if not I would look elsewhere since it seems to be very expensive and badly documented. I can't see any detailed spec for the digitizer but it looks as if it has a serial output not USB. Are you sure your link takes me to the right part because the Gyrocube 3A has analogue outputs.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    The link you provided goes to an Analog only device, all sensors are output in Analog form
    there is indication of an ADC but again this board does not seem to have USB on it
    If your using a USB interface you will need to provide the part link.
    if your using the base unit, then an Arduino could read the analog values directly and communicate this via its USB, but this will only give you 10 bits of resolution at best. Using an external ACD can improve this
    Regards
    Peter
    yes MK,
    I have one with USB cable. here it is,File:O-Navi 23565-B.jpg - Wikimedia Commons
    so if the device shows p as a com port once you install it, i dont see why not
    If it installs as a true USB device this will be allot more complicated
    That sensor is nothing like the one you linked to.
    I had a quick look at the Stanford project and I think you are on your own here. ONavi don't even list this sensor as  a product and Stanford don't seem interested in describing how the sensor works. Your only hope is to email ONavi and ask for details of the USB interface so that you could write your own software.
    You'll need a device that supports USB OTG (google it) and I don't think that the Arduino does.
    This all seems very hard work - the other route is to hack the sensor - but I get the feeling that may be out of your comfort zone. If not then open it up and take some pictures (good enough so we can read the writing on the chips) and post them here.
    0 e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    Peter,
    The device is installed in a com port, now COM22. How to go about reading the data if it is possible?
    I would start with connecting to it with telnet and simply talking to it to see what it says back. So get to learn its commands etc
    I would expect the user guide to tell you this ?
    once you know the command and responses you should be able to code using the PC or a Micro-controller with a HOST USB capability (On-The Go USB).
    As Michael said, you will need to do a little research
    Regards
