Arduino Forum wirless display using Arduino and NRF24L01
  • Replies 32 replies
  • Answers 2 answers
  • Subscribers 419 subscribers
  • Views 4052 views
  • help
  • nrf24l01+
  • led
billpenner
billpenner over 11 years ago
I am bogged down in this project
I'm using Arduino UNO.
I Have the keyboard data decoded and printing to the serial port (computer) fine.
I  want to send this data to a 16X2  LCD as soon as it is entered on the keypad.
  The LCD is working fine with serial input from computer to the Arduino but I cannot get the data to display on the
  LCD as soon as  a key is depressed. I have to send “enter”, then all three numbers are displayed.
I must have all three numbers sent to the transmitter as a group but the LCD should display them instantly as they are entered.
When the three numbers have been entered , the "*" key will send the string of numbers to a  NRF24L01.
Another  NRF24L01 and Arduino UNO will decode the data and display the numbers on a large 3 digit, 7 segment display.
The 7 segment display/decoder is working fine.
I can't seem to get the keyboard data into a form suitable for sending to either the 16X2  LCD or the  NRF24L01.
I can't even seem to get it into a string. I guess this is the form I need?
I think the  NRF24L01 will need a string of 3 digit numbers as a string? Right?
This is the code I have so far. Any help in getting me headed in the right direction would be greatly appreciated.
I gone over and over all the examples and tutorials on strings I can find but I can't seem to absorb it enough to make it work.
// key board to remote display.
#include <Keypad.h>
#include <LiquidCrystal.h>
int i;
String  A;                // Setup string to contain the data to transmit.
String  B;
String  C;
String  D;
                                          // set up the keypad decode
const byte ROWS = 4;       // Four rows
const byte COLS = 3;         // Three columns
                                          // Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = { 5, 4, 3, 2 }; // keypad rows to Arduino pins
byte colPins[COLS] = { 6, 7, 8 }; //keypad columns to Arduino pins
                                                    // Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
#define NRF2401                      // output pin to xmitter
void setup()
  Serial.begin(9600);
void loop()
char key = kpd.getKey();
  delay(10);
  if(key)  // Check for a valid key.
     switch (key)                            // check for transmit or clear keys
      case '*':                                     //send data to transmitter
        Serial.print(key);                      // send data to xmitter
        Serial.println("  pressed");       //testing
      break;
                // digitalWrite(transmit); // for testing
                 // break;                          // for testing
      case '#':                                     // clear and reset data
       A,B,C="";                                   // clear strings
        Serial.print(key);
        Serial.println(" Cleared");         // testing
       // Serial.println(C4);  // for testing
       break;
      default:    //accum max 3 char
        for(int i=0 ; i<4 ; i++){
         if (i==1)
           A = A + char(key);
           Serial.print (A);            // for testing
           Serial.print (key);        // for testing
         if(i==2)
           B = A +(key);               // for testing
           Serial.print(B);            // for testing
         if(i==3)
           C = B +(key);
          Serial.println(C);          // for testing
           Serial.print(i);             // for testing
        break;
         // Serial.println(C);         // for testing
     /*    Serial.print (A);
           Serial.print(char(B));                        // For testing
           Serial.print(char(C));
           Serial.print (char(A+B+C+D));
          if(i==4)                                                    //Too many digits! Only three allowed
           Serial.print("   ERROR");
         // Serial.println(i) ;
  • bobcroft
    bobcroft over 11 years ago in reply to e14 Contributor +1
    Hi Averil, Peter has posted some information for you that will help you. However, if you need anything else please send me your email address and I'll forward what I have. I used an Arduino and a LCD display…
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    I see no code what so ever here to write to the LCD, sure you have the library included but thats it
    you need to create an instance of the LCD library and send the data to it as you read from the keypad
    this might help get you started http://tronixstuff.com/2013/12/16/arduino-tutorials-chapter-42-numeric-keypads/
  • billpenner
    0 billpenner over 11 years ago in reply to Robert Peter Oakes
    I apologize for that omission but that section uses the example "LiquidCrystal Library - Serial Input" from Arduino almost verbatim. I think that will be easier after the data is created to send to the radio. if you disagree, I will send the sketch including that part if it will help.
    Thank you so very much for your help. I will study your link in the meantime.
    Bill
  • billpenner
    I have just spent the last while on the link you sent. What an excellent site. Thank you.
    I will rewrite the sketch and get back to you with the question of sending the 3 digits to the radio.
    You are a great resource.
    Bill
    0 Robert Peter Oakes over 11 years ago in reply to billpenner
    Good luck, I look forward to hearing how you did
    Peter
    No problems, I am quite familiar with using the NRF radios and so could help if needed
    You just have to ask
    Peter
  • billpenner
    I think this will be fine. I will have to rewrite some of it since I am using the parallel LCD. Also I will have to go to the Mega since I will not have enough digital pins. (No problem)
    Thanks again.
    Bill
    If you use a SPI to parallel or I2C to parallel chip you could stick with the 328. But the mega is more than able too and provides plenty of additional IO for future expansion
    Let us know how you get on
    Peter
  • billpenner
    Peter:
    I have rebuilt the sketch using your reference (tronixstuff.com). great tutorials there. thanks.
    I am using the mega currently.
    This is the error I get when compiling
    C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:15:  undefined reference to `loop'C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:15: undefined reference to `loop'
    I went to the above error reference copied (below).
        USBDevice.attach();
    #endif
        setup();
        for (;;) {
            loop();
            if (serialEventRun) serialEventRun();
        return 0;
    I can not decipher what could be wrong. this seems to be referring to USB device...
    I'm afraid I am in over my head.
    Could you please help me fix it or send me for more education?
    This the current code
    //keypad/LCD combo
    // http://tronixstuff.com/tutorials > chapter 42
    #include <Keypad.h>
    #include<LiquidCrystal.h>
    char C1,C2,C3,C4 ;
    LiquidCrystal lcd(27, 26, 25, 24, 23, 22);
      {'1','2','3'},
      {'4','5','6'},
      {'7','8','9'},
      {'#','0','*'}
    byte rowPins[ROWS] = {5,4,3,2}; // keypad rows to Arduino pins
    byte colPins[COLS] = {8,7,6}; //keypad columns to Arduino pins
    Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    char PIN[6]={
      '1','2','A','D','5','6'}; // our secret  number
    char attempt[6]={
      '0','0','0','0','0','0'}; // used for comparison
    int z=0;
    void setup()
    Serial.begin(9600);
      lcd.begin(16, 2);
      lcd.print("PIN Lock ");
      delay(1000);
      lcd.clear();
      lcd.print("  Enter PIN...");
    void correctPIN() // do this if correct PIN entered
      lcd.print("* Correct PIN *");
      delay(1000);
      lcd.clear();
    void incorrectPIN() // do this if incorrect PIN entered
      lcd.print(" * Try again *");
      delay(1000);
      lcd.clear();
    void checkPIN()
      int correct=0;
      int i;
      for ( i = 0;   i < 6 ;  i++ )
        if (attempt[i]==PIN[i])
          correct++;
      if (correct==6)
        correctPIN();
      else
        incorrectPIN();
      for (int zz=0; zz<6; zz++)
        attempt[zz]='0';
    void readKeypad()
      char key = keypad.getKey();
      if (key != NO_KEY)
        attempt[z]=key;
        z++;
        switch(key)
        case '*':
          z=0;
          break;
        case '#':
          z=0;
          delay(100); // for extra debounce
          lcd.clear();
          checkPIN();
          break;
    Very straight forward problem:
    every sketch MUST have two functions specifically "Setup()" which you have, this is used to initialize stuff your using and also "loop()" where you kick off your code. The error your getting is because you dont have the lop() function.
    this is the one from the chapter42 of the tronix web site
    void loop()
      if (key != NO_KEY)
        lcd.print(key);
        count++;
        if (count==17)
          lcd.clear();
          count=0;
    you need a loop() function also to read the keypad, collect your keys and display them onto the lcd, also to call your functions like CheckKey() etc.
    That is why you have the error shown
    0 Robert Peter Oakes over 11 years ago in reply to Robert Peter Oakes
    Oh, they MUST have those two, but you can add your own funcions as well
