Arduino Forum Arduino pro mini issues
  • Replies 12 replies
  • Subscribers 420 subscribers
  • Views 2556 views
  • ftdi232
  • ttl
  • usb
  • promini
  • serial
  • stk500_getsync():
funinalaska
funinalaska over 11 years ago
OK, I have been using Arduino Uno, Mega and micro for a while now.
All have USB on the board.
I had ordered some Pro Mini boards a while ago and am just now finally getting to fool around with them.
I got a FTDI232 board to program them with but I am having no luck.
I have followed along with many tutorials online that use these boards with this adapter.
I always get:
avrdude: stk500_getsync(): not in sync: resp=0x00
I have tried a couple different Pro Minis thinking maybe one I had was bad.
I also did do the test with putting a jumper over RX and TX and seeing if I get mirroring in Serial monitor and I do.
I have checked the settings in the com port on my system settings and it seems to be set as the tutorial say.
Anyone have any thoughts what could be my issue?
  • funinalaska
    0 funinalaska over 11 years ago in reply to mcb1
    100% FIXED THE ISSUE.
    Thank you VERY much.
    Now I just need to burn the bootloader to all these boards :/
    But at least I know what the problem is and how to fix it.
    Thank you all for the help.
  • funinalaska
    Ok, so for an update. Once I burned the bootloader on theis board as described here:
    http://forum.arduino.cc/index.php?topic=217246.0
    now my pro mini accepts upload with no problem simply by connecting the FTDI to it so DTR pins line up.
    Now I have 5 more boards to play with image
