Arduino Forum Hi I have a pygmalion Innobot, and i am having troble uploading the code....Any help!!
  • Subscribers 417 subscribers
  • Views 374 views
  • arduino_development_environment
  This robot runs off of Arduino. I uploaded the code, and it runs on
robot while plugged in, but the moment I unplug it, and turn it on..it does nothing but blink its yellow light. Any help, or suggestions?
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    Please can you provide a little more detail as to how you have it wired
    What power are you using when plugged in, what is your battery config when in autonomous mode
    What are the volts on the controller in each case
    Please provide a diagram if you can as it will help a lot
    Any other additional info would also be helpful, Pictures, code etc
    Currently I am thinking it is your batteries
    Peter
    0 e14 Contributor over 11 years ago in reply to Robert Peter Oakes
    You were right! it was the voltage.
    What I tried first was changing the 9v battery, but that didn't seen to work, it only pulsed the motors slightly.
    So what I did was trouble-shoot the power problem, I used a voltage change switch, which can change from 1.5 - 12volts.
    I first set at 9 volts, because that was what the robot came with, but it still was not getting enough power, so I went the next voltage up.
    I was afraid to go up thinking it was going to fry the board! but I went for it.
    It worked!!! the robot ran its program all the way through!!
    My question is why???
    Now the problem is... how am I supposed to mount 12 volt's to my BOT???!!
    by the way Thanks for helping me.
