Arduino Forum Simple task of telling an optical drive to eject.
  • Subscribers 417 subscribers
  • Views 342 views
eatumup
eatumup over 11 years ago
I am working on a computer that I have stuffed into an old Xbox 360. The problem i have is that the computer is using a slimline laptop optical drive. I know I can instruct the drive to eject from within the OS but I would like the ability to eject the disk before boot. Problem is that due to the "stock" look I am trying to maintain, the eject button is not accessible. I know its possible to wire in an external button in, But I have already destroyed a couple of drives in attempt and I would rather do this programmatically over SATA if I could.
So what I am thinking is that I would like to use something like a Auduino Nano to tap into the SATA cable and issue the eject command. So my question is, Could this be as simple as it sounds? Have the Auduino monitor a pin for activity and if so send the command to the optical drive by tapping into the Sata cable that the drive uses to communicate with the PC?
I would love to see any suggestions on how to re-route the "eject button" without opening the optical drive. I thought I would ask here to see what I would be getting myself into  (if its even worth doing) before I start buying hardware
  • binarygenius
    binarygenius over 11 years ago +1
    As far as i know the arduino is just far to slow and lacking in every way to be able to communicate with sata in any way. The best way would be to add the external button, what problems have you been having…
  • binarygenius
    0 binarygenius over 11 years ago
    As far as i know the arduino is just far to slow and lacking in every way to be able to communicate with sata in any way. The best way would be to add the external button, what problems have you been having that is causing you to break the drives when trying to add the new button i might be able to offer some advice.
  • gadget.iom
    0 gadget.iom over 11 years ago
    Post two of the following Arduino thread may be of interest. http://forum.arduino.cc/index.php?topic=14929.0
