Arduino Forum How to reduce 12v dc to 5v dc
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 420 subscribers
  • Views 3121 views
  • quadcopter
Hello everyone,
I wrote a simple Arduino sketch to control 12 led lights in a pattern.
The led's will be mounted on my quadcopter.
The plan is to burn the sketch to an Attiny2213 micro controller mounted on a board along with the relay, transistors ect.
The problem is that the quad uses a 4s lipo(14.8v) battery.
Attiny2213 has a max of 5.5v.
I currently have a working model on the bread board with the led's using the 14.8v, and a 9v battery powering the Arduino.
Any suggestions on how to get rid of the 9v battery(weight reduction is the goal), and use only the lipo battery to power everything?
Thanks for your help.
Stan
    Oops, I meant the quad uses a 3s lipo....11.1v.
    Stan
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    A small buck converter, this will be the most efficient for you and quite light, should only be a few $$
    it will take you right to 5V, any linear LDO will simply burn up power as heat dropping the volts from 14 to 5
    Regards
    Peter
  • johnbeetem
    0 johnbeetem over 11 years ago
    You probably want to use a DC-to-DC converter or "buck" switching regulator.  These are a very efficient way to reduce a higher voltage to a well-regulated lower voltage.  Member Robert Peter Oakes made some recommendations of easy-to-use modules on 27 April 2014 on this thread: http://www.element14.com/community/message/110535#110535
    Update: I made this comment before seeing Peter's own comment 10 minutes earlier.  Well, this way Peter doesn't have to try to track down the comment he made last April image
    Thanks guys.
    Very helpful!
  • D_Hersey
    0 D_Hersey over 11 years ago
    Buck converters are great because they are the most stable.  In the case of LiPO, the potential varies greatly over the discharge curve.  This implies a second-order topology such as SEPIC.
    I was just looking at this converter, and adding a diode in series to prevent a voltage shock.
    http://www.newark.com/recom-power/r-785-0-1-0/dc-dc-conv-5w-5v-1a-sip/dp/62X9542
    Or am I thinking wrong?
    I actually know very little about what I am doing ......lol
    0 jw0752 over 11 years ago
    Hi Stanley,
    You say that you are currently using a 9 volt battery to power the Microcontroller. This implies to me that you already have a 5 volt regulator working in the circuit. I suspect that you can put the 11.1 volts from the quad copter where you have the 9 volts now and it will be regulated to the 5 volts just as the 9 volts is being regulated.
    John,
    Everything is still on the bread board.
    The lipo is powering the LED's and the 9v battery is powering the Arduino board.
    The arduino has inputs for 3.3v, 5v, or 9v.
    I haven't burned the arduino sketch to the Attiny yet.
    I should upload a picture of the tangle of wires I have......
    Here are a couple pictures.
    rchelipilot2.weebly.com
    0 jw0752 over 11 years ago in reply to e14 Contributor
    Hi Stanley, I thought that you were already using the Atiny.
