Arduino Forum Problem With Radiation Sensor
  • Subscribers 402 subscribers
  • Views 409 views
  • rs-232
  • radiation
  • drone
  • sensor
brv64
brv64 over 10 years ago
Hello!
I'm having trouble getting data from a AT1117M, bdkg-01, which is a radiation sensor.
Apparently It can communicate with RS-232, but I can't make it to send me data.
Is there some sort of protocol, or something I need to do to make it work?
  • clem57
    0 clem57 over 10 years ago
    I am guessing they ATOMTEX do not want to share the interface... Buy the hardware/software and then you can see what the interface is....
    Clem
  • brv64
    0 brv64 over 10 years ago in reply to clem57
    Does That mean That you're the solution, clem is an Interface, or just a joke?
    Because a googled Clem and...
    Nothing useful
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to brv64
    It looks like the communication protocol isn't documented anywhere on the web (that I can find).
    You may be running into issues where the data-sheets talk about direct PC connection. This is likely to use the RS232 electrical specifications which isn't really compatible with the TX/RX pins on the Arduino. You need to look at converting the logic levels to TTL. A useful article about this subject can be found here: https://www.sparkfun.com/tutorials/215
    It's worth a read.
