Arduino Forum Screen text controlled by photoresistor
  • Replies 7 replies
  • Subscribers 402 subscribers
  • Views 543 views
  • lcd
  • photoresistor
pot82es
pot82es over 10 years ago
Hey!
Im building a mailbox, and i could really ned some help with a code. I need a text on the keypad library to change to another text on a 1602 LCD when the light is blocked by the photoresistor (if, else). Any kind of help is higly appriciated!
  • neilk
    neilk over 10 years ago in reply to pot82es +3 verified
    pot82es Hi Kristoffer - surely you should be printing out the value of sensorValue that you are reading at: sensorValue = analogRead(analogPin); and do this at different light levels Neil
  • gadget.iom
    0 gadget.iom over 10 years ago
    Is your question related to this one?
    Arduino screen with photoresistor
  • pot82es
    0 pot82es over 10 years ago in reply to gadget.iom
    Yes! I didn't quite get i to work with the photoresistor...
  • clem57
    0 clem57 over 10 years ago in reply to pot82es
    Any output or observations to look at?
  • pot82es
    0 pot82es over 10 years ago in reply to clem57
    I have the code...
    #include <LiquidCrystal.h>
    #include <LCDKeypad.h>
    LCDKeypad lcd;
    const int threshold = 600;
    const int analogPin = A0;
    int sensorMin = 1023;  // minimum sensor value
    int sensorMax = 0;     // maximum sensor value
    int sensorValue = 0;         // the sensor value
    void setup() {
    void loop() {
      if (sensorValue > sensorMax)
      lcd.begin(16, 2);
      lcd.print("POSTKASSE V.1.1");
      lcd.setCursor(0,1);
      lcd.print("Du har post!");
      else
      lcd.begin(16, 2);
      lcd.setCursor(0,1);
      lcd.print("Du har ikke post");
      delay(150);
  • clem57
    Ok, does any print occur and why is it not correct?
  • pot82es
    The Photoresitor won't change anything  on the screen, thats what I need help for. I do not know the value to the anlog input or what code I should use for this.
  • neilk
    0 neilk over 10 years ago in reply to pot82es
    Neil
