Arduino Forum Reverse Footprint for Arduino Mega
  • Replies 22 replies
  • Subscribers 414 subscribers
  • Views 8704 views
  • arduino projects
colporteur
colporteur over 4 years ago
How do you mount a Mega on a PCB?
I'm using a Arduino Mega for a project and wanted to use Fritzing to create a PCB layout. The footprint for the Mega reflects the pinout of the motherboard. If I create a pin pattern on the board to mount the Mega directly to the board, then the pins need to be reversed. The Mega is flipped over and mounted face down on the PCB reversing the pinout.
I cannot find a pinout that reflects the Mega face down on a PCB. I would assume that is the way to install the board and not have a collection of jumpers running from the Mega board back to the PCB. If anyone has an insight I would welcome the input?
  • Andrew J
    Andrew J over 4 years ago +2
    I assume the PCB is plated through-hole? Put the footprint on the reverse of the PCB but actually solder the MEGA (or headers) onto the front of the board. That would work wouldn’t it?
  • BigG
    BigG over 4 years ago in reply to colporteur +2
    I would change the background colour so that you can see the white font. I did a quick test to prove and it is quite straightforward. If this is what you need, then I can place the modified fritzing…
  • BigG
    BigG over 4 years ago +1
    In PCB mode, click on the footprint and then change "pcb layer" to bottom.
  • colporteur
    0 colporteur over 4 years ago in reply to BigG
    A better question. WHere should I be looking?
  • javagoza
    0 javagoza over 4 years ago in reply to colporteur
    silk screen is transparent and labels are white. Try to change inkskape document background color
  • javagoza
    0 javagoza over 4 years ago in reply to javagoza
  • BigG
    0 BigG over 4 years ago in reply to colporteur
    If this is what you need, then I can place the modified fritzing part on my github page and provide a link - I cannot see a means to attach a file inside a comment... as in it won't let me upload.
    Here is the modified SVG file, if that also helps.
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <!-- Generator: Adobe Illustrator 16.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 0)  -->
    <svg
       version="1.1"
       id="_x30_"
       x="0px"
       y="0px"
       width="288.736px"
       height="151.2px"
       viewBox="0 0 288.736 151.2"
       enable-background="new 0 0 288.736 151.2"
       xml:space="preserve"
       sodipodi:docname="Arduino_ADK_MEGA_2560-Rev3_pcbREV.svg"
       inkscape:version="1.1.1 (1:1.1+202109281949+c3084ef5ed)"
       xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
       xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
       xmlns="http://www.w3.org/2000/svg"
       xmlns:svg="http://www.w3.org/2000/svg"><defs
       id="defs1259" /><sodipodi:namedview
       id="namedview1257"
       pagecolor="#505050"
       bordercolor="#ffffff"
       borderopacity="1"
       inkscape:pageshadow="0"
       inkscape:pageopacity="0"
       inkscape:pagecheckerboard="1"
       showgrid="false"
       inkscape:zoom="2.297947"
       inkscape:cx="196.69732"
       inkscape:cy="117.2786"
       inkscape:window-width="1920"
       inkscape:window-height="1013"
       inkscape:window-x="0"
       inkscape:window-y="0"
       inkscape:window-maximized="1"
       inkscape:current-layer="_x30_" />
    <g
       id="silkscreen">
    	<path
       id="_x30_.1.0"
       fill="none"
       stroke="#FFFFFF"
       stroke-width="0.576"
       d="M273.631,0.288l7.188,7.172v28.69l7.188,7.172v96.83   l-7.188,7.175v0.762c0.162,1.396-0.838,2.66-2.232,2.824c-0.198,0.022-0.397,0.022-0.598,0H3.375   c-1.396,0.164-2.663-0.834-2.829-2.229c-0.022-0.198-0.023-0.396-0.001-0.596V3.112C0.382,1.715,1.383,0.45,2.779,0.288   c0.198-0.023,0.396-0.023,0.596,0H273.631" />
    	<g
       id="_x30_.1.5">
    		<title
       id="0.1.5.0">element:ADCH</title>
    		<g
       id="_x30_.1.5.1">
    			<title
       id="0.1.5.1.0">package:1X08</title>
    				<line
       id="_x30_.1.5.1.1"
       fill="none"
       stroke="#FFFFFF"
       stroke-width="0.432"
       stroke-linecap="round"
       x1="250.49"
       y1="140.4"
       x2="254.092"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="254.092"
       y1="140.4"
       x2="255.893"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="255.893"
       y1="142.2"
       x2="255.893"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="255.893"
       y1="145.799"
       x2="254.092"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="241.49"
       y1="142.2"
       x2="243.293"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="243.293"
       y1="140.4"
       x2="246.893"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="246.893"
       y1="140.4"
       x2="248.693"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="248.693"
       y1="142.2"
       x2="248.693"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="248.693"
       y1="145.799"
       x2="246.893"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="246.893"
       y1="147.6"
       x2="243.293"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="243.293"
       y1="147.6"
       x2="241.49"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="250.49"
       y1="140.4"
       x2="248.693"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="248.693"
       y1="145.799"
       x2="250.49"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="254.092"
       y1="147.6"
       x2="250.49"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="228.893"
       y1="140.4"
       x2="232.49"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="232.49"
       y1="140.4"
       x2="234.293"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="234.293"
       y1="142.2"
       x2="234.293"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="234.293"
       y1="145.799"
       x2="232.49"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="234.293"
       y1="142.2"
       x2="236.092"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="236.092"
       y1="140.4"
       x2="239.693"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="239.693"
       y1="140.4"
       x2="241.49"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="241.49"
       y1="142.2"
       x2="241.49"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="241.49"
       y1="145.799"
       x2="239.693"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="239.693"
       y1="147.6"
       x2="236.092"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="236.092"
       y1="147.6"
       x2="234.293"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="219.893"
       y1="142.2"
       x2="221.693"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="221.693"
       y1="140.4"
       x2="225.293"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="225.293"
       y1="140.4"
       x2="227.092"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="227.092"
       y1="142.2"
       x2="227.092"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="227.092"
       y1="145.799"
       x2="225.293"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="225.293"
       y1="147.6"
       x2="221.693"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="221.693"
       y1="147.6"
       x2="219.893"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="228.893"
       y1="140.4"
       x2="227.092"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="227.092"
       y1="145.799"
       x2="228.893"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="232.49"
       y1="147.6"
       x2="228.893"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="207.293"
       y1="140.4"
       x2="210.893"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="210.893"
       y1="140.4"
       x2="212.693"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="212.693"
       y1="142.2"
       x2="212.693"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="212.693"
       y1="145.799"
       x2="210.893"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="212.693"
       y1="142.2"
       x2="214.49"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="214.49"
       y1="140.4"
       x2="218.092"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="218.092"
       y1="140.4"
       x2="219.893"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="219.893"
       y1="142.2"
       x2="219.893"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="219.893"
       y1="145.799"
       x2="218.092"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="218.092"
       y1="147.6"
       x2="214.49"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="214.49"
       y1="147.6"
       x2="212.693"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="205.49"
       y1="142.2"
       x2="205.49"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="207.293"
       y1="140.4"
       x2="205.49"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="205.49"
       y1="145.799"
       x2="207.293"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="210.893"
       y1="147.6"
       x2="207.293"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="257.693"
       y1="140.4"
       x2="261.293"
       y2="140.4" />
    				<line
       id="_x30_.1.5.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="261.293"
       y1="140.4"
       x2="263.092"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="142.2"
       x2="263.092"
       y2="145.799" />
    				<line
       id="_x30_.1.5.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="145.799"
       x2="261.293"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="257.693"
       y1="140.4"
       x2="255.893"
       y2="142.2" />
    				<line
       id="_x30_.1.5.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="255.893"
       y1="145.799"
       x2="257.693"
       y2="147.6" />
    				<line
       id="_x30_.1.5.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="261.293"
       y1="147.6"
       x2="257.693"
       y2="147.6" />
    		</g>
    	</g>
    	<g
       id="_x30_.1.6">
    		<title
       id="0.1.6.0">element:ADCL</title>
    		<g
       id="_x30_.1.6.1">
    			<title
       id="0.1.6.1.0">package:1X08</title>
    				<line
       id="_x30_.1.6.1.1"
       fill="none"
       stroke="#FFFFFF"
       x1="185.693"
       y1="140.4"
       x2="189.293"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="189.293"
       y1="140.4"
       x2="191.092"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="191.092"
       y1="142.2"
       x2="191.092"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="191.092"
       y1="145.799"
       x2="189.293"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="176.693"
       y1="142.2"
       x2="178.49"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="178.49"
       y1="140.4"
       x2="182.092"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="182.092"
       y1="140.4"
       x2="183.893"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="183.893"
       y1="142.2"
       x2="183.893"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="183.893"
       y1="145.799"
       x2="182.092"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="182.092"
       y1="147.6"
       x2="178.49"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="178.49"
       y1="147.6"
       x2="176.693"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="185.693"
       y1="140.4"
       x2="183.893"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="183.893"
       y1="145.799"
       x2="185.693"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="189.293"
       y1="147.6"
       x2="185.693"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="164.092"
       y1="140.4"
       x2="167.693"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="167.693"
       y1="140.4"
       x2="169.49"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="169.49"
       y1="142.2"
       x2="169.49"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="169.49"
       y1="145.799"
       x2="167.693"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="169.49"
       y1="142.2"
       x2="171.293"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="171.293"
       y1="140.4"
       x2="174.893"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="174.893"
       y1="140.4"
       x2="176.693"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="176.693"
       y1="142.2"
       x2="176.693"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="176.693"
       y1="145.799"
       x2="174.893"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="174.893"
       y1="147.6"
       x2="171.293"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="171.293"
       y1="147.6"
       x2="169.49"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="155.092"
       y1="142.2"
       x2="156.893"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="156.893"
       y1="140.4"
       x2="160.49"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="160.49"
       y1="140.4"
       x2="162.293"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="162.293"
       y1="142.2"
       x2="162.293"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="162.293"
       y1="145.799"
       x2="160.49"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="160.49"
       y1="147.6"
       x2="156.893"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="156.893"
       y1="147.6"
       x2="155.092"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="164.092"
       y1="140.4"
       x2="162.293"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="162.293"
       y1="145.799"
       x2="164.092"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="167.693"
       y1="147.6"
       x2="164.092"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="142.491"
       y1="140.4"
       x2="146.091"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="146.091"
       y1="140.4"
       x2="147.892"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="147.892"
       y1="142.2"
       x2="147.892"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="147.892"
       y1="145.799"
       x2="146.091"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="147.892"
       y1="142.2"
       x2="149.693"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="149.693"
       y1="140.4"
       x2="153.292"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="153.292"
       y1="140.4"
       x2="155.092"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="155.092"
       y1="142.2"
       x2="155.092"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="155.092"
       y1="145.799"
       x2="153.292"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="153.292"
       y1="147.6"
       x2="149.693"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="149.693"
       y1="147.6"
       x2="147.892"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="140.693"
       y1="142.2"
       x2="140.693"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="142.491"
       y1="140.4"
       x2="140.693"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="140.693"
       y1="145.799"
       x2="142.491"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="146.091"
       y1="147.6"
       x2="142.491"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="192.893"
       y1="140.4"
       x2="196.49"
       y2="140.4" />
    				<line
       id="_x30_.1.6.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="196.49"
       y1="140.4"
       x2="198.293"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="198.293"
       y1="142.2"
       x2="198.293"
       y2="145.799" />
    				<line
       id="_x30_.1.6.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="198.293"
       y1="145.799"
       x2="196.49"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="192.893"
       y1="140.4"
       x2="191.092"
       y2="142.2" />
    				<line
       id="_x30_.1.6.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="191.092"
       y1="145.799"
       x2="192.893"
       y2="147.6" />
    				<line
       id="_x30_.1.6.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="196.49"
       y1="147.6"
       x2="192.893"
       y2="147.6" />
    		</g>
    	</g>
    	<g
       id="_x30_.1.7">
    		<title
       id="0.1.7.0">element:COMMUNICATION</title>
    		<g
       id="_x30_.1.7.1">
    			<title
       id="0.1.7.1.0">package:1X08</title>
    				<line
       id="_x30_.1.7.1.1"
       fill="none"
       stroke="#FFFFFF"
       x1="203.693"
       y1="10.8"
       x2="200.092"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="200.092"
       y1="10.8"
       x2="198.293"
       y2="9" />
    				<line
       id="_x30_.1.7.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="198.293"
       y1="9"
       x2="198.293"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="198.293"
       y1="5.4"
       x2="200.092"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="212.693"
       y1="9"
       x2="210.893"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="210.893"
       y1="10.8"
       x2="207.293"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="207.293"
       y1="10.8"
       x2="205.49"
       y2="9" />
    				<line
       id="_x30_.1.7.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="205.49"
       y1="9"
       x2="205.49"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="205.49"
       y1="5.4"
       x2="207.293"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="207.293"
       y1="3.6"
       x2="210.893"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="210.893"
       y1="3.6"
       x2="212.693"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="203.693"
       y1="10.8"
       x2="205.49"
       y2="9" />
    				<line
       id="_x30_.1.7.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="205.49"
       y1="5.4"
       x2="203.693"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="200.092"
       y1="3.6"
       x2="203.693"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="225.293"
       y1="10.8"
       x2="221.693"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="221.693"
       y1="10.8"
       x2="219.893"
       y2="9" />
    				<line
       id="_x30_.1.7.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="219.893"
       y1="9"
       x2="219.893"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="219.893"
       y1="5.4"
       x2="221.693"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="219.893"
       y1="9"
       x2="218.092"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="218.092"
       y1="10.8"
       x2="214.49"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="214.49"
       y1="10.8"
       x2="212.693"
       y2="9" />
    				<line
       id="_x30_.1.7.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="212.693"
       y1="9"
       x2="212.693"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="212.693"
       y1="5.4"
       x2="214.49"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="214.49"
       y1="3.6"
       x2="218.092"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="218.092"
       y1="3.6"
       x2="219.893"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="234.293"
       y1="9"
       x2="232.49"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="232.49"
       y1="10.8"
       x2="228.893"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="228.893"
       y1="10.8"
       x2="227.092"
       y2="9" />
    				<line
       id="_x30_.1.7.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="227.092"
       y1="9"
       x2="227.092"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="227.092"
       y1="5.4"
       x2="228.893"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="228.893"
       y1="3.6"
       x2="232.49"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="232.49"
       y1="3.6"
       x2="234.293"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="225.293"
       y1="10.8"
       x2="227.092"
       y2="9" />
    				<line
       id="_x30_.1.7.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="227.092"
       y1="5.4"
       x2="225.293"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="221.693"
       y1="3.6"
       x2="225.293"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="246.893"
       y1="10.8"
       x2="243.293"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="243.293"
       y1="10.8"
       x2="241.49"
       y2="9" />
    				<line
       id="_x30_.1.7.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="241.49"
       y1="9"
       x2="241.49"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="241.49"
       y1="5.4"
       x2="243.293"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="241.49"
       y1="9"
       x2="239.693"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="239.693"
       y1="10.8"
       x2="236.092"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="236.092"
       y1="10.8"
       x2="234.293"
       y2="9" />
    				<line
       id="_x30_.1.7.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="234.293"
       y1="9"
       x2="234.293"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="234.293"
       y1="5.4"
       x2="236.092"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="236.092"
       y1="3.6"
       x2="239.693"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="239.693"
       y1="3.6"
       x2="241.49"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="248.693"
       y1="9"
       x2="248.693"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="246.893"
       y1="10.8"
       x2="248.693"
       y2="9" />
    				<line
       id="_x30_.1.7.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="248.693"
       y1="5.4"
       x2="246.893"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="243.293"
       y1="3.6"
       x2="246.893"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="196.49"
       y1="10.8"
       x2="192.893"
       y2="10.8" />
    				<line
       id="_x30_.1.7.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="192.893"
       y1="10.8"
       x2="191.092"
       y2="9" />
    				<line
       id="_x30_.1.7.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="191.092"
       y1="9"
       x2="191.092"
       y2="5.4" />
    				<line
       id="_x30_.1.7.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="191.092"
       y1="5.4"
       x2="192.893"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="196.49"
       y1="10.8"
       x2="198.293"
       y2="9" />
    				<line
       id="_x30_.1.7.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="198.293"
       y1="5.4"
       x2="196.49"
       y2="3.6" />
    				<line
       id="_x30_.1.7.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="192.893"
       y1="3.6"
       x2="196.49"
       y2="3.6" />
    		</g>
    	</g>
    	<g
       id="_x30_.1.26">
    		<title
       id="0.1.26.0">element:JP1</title>
    		<g
       id="_x30_.1.26.1">
    			<title
       id="0.1.26.1.0">package:1X10</title>
    				<line
       id="_x30_.1.26.1.1"
       fill="none"
       stroke="#FFFFFF"
       x1="107.572"
       y1="5.4"
       x2="109.372"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="109.372"
       y1="3.6"
       x2="112.972"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="112.972"
       y1="3.6"
       x2="114.772"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="114.772"
       y1="5.4"
       x2="114.772"
       y2="9" />
    				<line
       id="_x30_.1.26.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="114.772"
       y1="9"
       x2="112.972"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="112.972"
       y1="10.8"
       x2="109.372"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="109.372"
       y1="10.8"
       x2="107.572"
       y2="9" />
    				<line
       id="_x30_.1.26.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="94.972"
       y1="3.6"
       x2="98.572"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="98.572"
       y1="3.6"
       x2="100.372"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="100.372"
       y1="5.4"
       x2="100.372"
       y2="9" />
    				<line
       id="_x30_.1.26.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="100.372"
       y1="9"
       x2="98.572"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="100.372"
       y1="5.4"
       x2="102.172"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="102.172"
       y1="3.6"
       x2="105.772"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="105.772"
       y1="3.6"
       x2="107.572"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="107.572"
       y1="5.4"
       x2="107.572"
       y2="9" />
    				<line
       id="_x30_.1.26.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="107.572"
       y1="9"
       x2="105.772"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="105.772"
       y1="10.8"
       x2="102.172"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="102.172"
       y1="10.8"
       x2="100.372"
       y2="9" />
    				<line
       id="_x30_.1.26.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="85.972"
       y1="5.4"
       x2="87.772"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="87.772"
       y1="3.6"
       x2="91.372"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="91.372"
       y1="3.6"
       x2="93.172"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="93.172"
       y1="5.4"
       x2="93.172"
       y2="9" />
    				<line
       id="_x30_.1.26.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="93.172"
       y1="9"
       x2="91.372"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="91.372"
       y1="10.8"
       x2="87.772"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="87.772"
       y1="10.8"
       x2="85.972"
       y2="9" />
    				<line
       id="_x30_.1.26.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="94.972"
       y1="3.6"
       x2="93.172"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="93.172"
       y1="9"
       x2="94.972"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="98.572"
       y1="10.8"
       x2="94.972"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="73.372"
       y1="3.6"
       x2="76.972"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="76.972"
       y1="3.6"
       x2="78.772"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="78.772"
       y1="5.4"
       x2="78.772"
       y2="9" />
    				<line
       id="_x30_.1.26.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="78.772"
       y1="9"
       x2="76.972"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="78.772"
       y1="5.4"
       x2="80.572"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="80.572"
       y1="3.6"
       x2="84.172"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="84.172"
       y1="3.6"
       x2="85.972"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="85.972"
       y1="5.4"
       x2="85.972"
       y2="9" />
    				<line
       id="_x30_.1.26.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="85.972"
       y1="9"
       x2="84.172"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="84.172"
       y1="10.8"
       x2="80.572"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="80.572"
       y1="10.8"
       x2="78.772"
       y2="9" />
    				<line
       id="_x30_.1.26.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="64.372"
       y1="5.4"
       x2="66.172"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="66.172"
       y1="3.6"
       x2="69.772"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="69.772"
       y1="3.6"
       x2="71.572"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="71.572"
       y1="5.4"
       x2="71.572"
       y2="9" />
    				<line
       id="_x30_.1.26.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="71.572"
       y1="9"
       x2="69.772"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="69.772"
       y1="10.8"
       x2="66.172"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="66.172"
       y1="10.8"
       x2="64.372"
       y2="9" />
    				<line
       id="_x30_.1.26.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="73.372"
       y1="3.6"
       x2="71.572"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="71.572"
       y1="9"
       x2="73.372"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="76.972"
       y1="10.8"
       x2="73.372"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="51.772"
       y1="3.6"
       x2="55.372"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="55.372"
       y1="3.6"
       x2="57.172"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="57.172"
       y1="5.4"
       x2="57.172"
       y2="9" />
    				<line
       id="_x30_.1.26.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="57.172"
       y1="9"
       x2="55.372"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="57.172"
       y1="5.4"
       x2="58.972"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="58.972"
       y1="3.6"
       x2="62.572"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="62.572"
       y1="3.6"
       x2="64.372"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="64.372"
       y1="5.4"
       x2="64.372"
       y2="9" />
    				<line
       id="_x30_.1.26.1.58"
       fill="none"
       stroke="#FFFFFF"
       x1="64.372"
       y1="9"
       x2="62.572"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.59"
       fill="none"
       stroke="#FFFFFF"
       x1="62.572"
       y1="10.8"
       x2="58.972"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.60"
       fill="none"
       stroke="#FFFFFF"
       x1="58.972"
       y1="10.8"
       x2="57.172"
       y2="9" />
    				<line
       id="_x30_.1.26.1.61"
       fill="none"
       stroke="#FFFFFF"
       x1="49.971"
       y1="5.4"
       x2="49.971"
       y2="9" />
    				<line
       id="_x30_.1.26.1.62"
       fill="none"
       stroke="#FFFFFF"
       x1="51.772"
       y1="3.6"
       x2="49.971"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.63"
       fill="none"
       stroke="#FFFFFF"
       x1="49.971"
       y1="9"
       x2="51.772"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.64"
       fill="none"
       stroke="#FFFFFF"
       x1="55.372"
       y1="10.8"
       x2="51.772"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.65"
       fill="none"
       stroke="#FFFFFF"
       x1="116.572"
       y1="3.6"
       x2="120.172"
       y2="3.6" />
    				<line
       id="_x30_.1.26.1.66"
       fill="none"
       stroke="#FFFFFF"
       x1="120.172"
       y1="3.6"
       x2="121.972"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.67"
       fill="none"
       stroke="#FFFFFF"
       x1="121.972"
       y1="5.4"
       x2="121.972"
       y2="9" />
    				<line
       id="_x30_.1.26.1.68"
       fill="none"
       stroke="#FFFFFF"
       x1="121.972"
       y1="9"
       x2="120.172"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.69"
       fill="none"
       stroke="#FFFFFF"
       x1="116.572"
       y1="3.6"
       x2="114.772"
       y2="5.4" />
    				<line
       id="_x30_.1.26.1.70"
       fill="none"
       stroke="#FFFFFF"
       x1="114.772"
       y1="9"
       x2="116.572"
       y2="10.8" />
    				<line
       id="_x30_.1.26.1.71"
       fill="none"
       stroke="#FFFFFF"
       x1="120.172"
       y1="10.8"
       x2="116.572"
       y2="10.8" />
    		</g>
    	</g>
    	<g
       id="_x30_.1.30">
    		<title
       id="0.1.30.0">element:POWER</title>
    		<g
       id="_x30_.1.30.1">
    			<title
       id="0.1.30.1.0">package:1X08</title>
    				<line
       id="_x30_.1.30.1.1"
       fill="none"
       stroke="#FFFFFF"
       x1="120.892"
       y1="140.4"
       x2="124.492"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="124.492"
       y1="140.4"
       x2="126.292"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="126.292"
       y1="142.2"
       x2="126.292"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="126.292"
       y1="145.799"
       x2="124.492"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="111.892"
       y1="142.2"
       x2="113.692"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="113.692"
       y1="140.4"
       x2="117.292"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="117.292"
       y1="140.4"
       x2="119.092"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="119.092"
       y1="142.2"
       x2="119.092"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="119.092"
       y1="145.799"
       x2="117.292"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="117.292"
       y1="147.6"
       x2="113.692"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="113.692"
       y1="147.6"
       x2="111.892"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="120.892"
       y1="140.4"
       x2="119.092"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="119.092"
       y1="145.799"
       x2="120.892"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="124.492"
       y1="147.6"
       x2="120.892"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="99.292"
       y1="140.4"
       x2="102.892"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="102.892"
       y1="140.4"
       x2="104.692"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="104.692"
       y1="142.2"
       x2="104.692"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="104.692"
       y1="145.799"
       x2="102.892"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="104.692"
       y1="142.2"
       x2="106.492"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="106.492"
       y1="140.4"
       x2="110.092"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="110.092"
       y1="140.4"
       x2="111.892"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="111.892"
       y1="142.2"
       x2="111.892"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="111.892"
       y1="145.799"
       x2="110.092"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="110.092"
       y1="147.6"
       x2="106.492"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="106.492"
       y1="147.6"
       x2="104.692"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="90.292"
       y1="142.2"
       x2="92.092"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="92.092"
       y1="140.4"
       x2="95.692"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="95.692"
       y1="140.4"
       x2="97.492"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="97.492"
       y1="142.2"
       x2="97.492"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="97.492"
       y1="145.799"
       x2="95.692"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="95.692"
       y1="147.6"
       x2="92.092"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="92.092"
       y1="147.6"
       x2="90.292"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="99.292"
       y1="140.4"
       x2="97.492"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="97.492"
       y1="145.799"
       x2="99.292"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="102.892"
       y1="147.6"
       x2="99.292"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="77.692"
       y1="140.4"
       x2="81.292"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="81.292"
       y1="140.4"
       x2="83.092"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="83.092"
       y1="142.2"
       x2="83.092"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="83.092"
       y1="145.799"
       x2="81.292"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="83.092"
       y1="142.2"
       x2="84.892"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="84.892"
       y1="140.4"
       x2="88.492"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="88.492"
       y1="140.4"
       x2="90.292"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="90.292"
       y1="142.2"
       x2="90.292"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="90.292"
       y1="145.799"
       x2="88.492"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="88.492"
       y1="147.6"
       x2="84.892"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="84.892"
       y1="147.6"
       x2="83.092"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="75.892"
       y1="142.2"
       x2="75.892"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="77.692"
       y1="140.4"
       x2="75.892"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="75.892"
       y1="145.799"
       x2="77.692"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="81.292"
       y1="147.6"
       x2="77.692"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="128.092"
       y1="140.4"
       x2="131.692"
       y2="140.4" />
    				<line
       id="_x30_.1.30.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="131.692"
       y1="140.4"
       x2="133.492"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="133.492"
       y1="142.2"
       x2="133.492"
       y2="145.799" />
    				<line
       id="_x30_.1.30.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="133.492"
       y1="145.799"
       x2="131.692"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="128.092"
       y1="140.4"
       x2="126.292"
       y2="142.2" />
    				<line
       id="_x30_.1.30.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="126.292"
       y1="145.799"
       x2="128.092"
       y2="147.6" />
    				<line
       id="_x30_.1.30.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="131.692"
       y1="147.6"
       x2="128.092"
       y2="147.6" />
    		</g>
    	</g>
    	<g
       id="_x30_.1.31">
    		<title
       id="0.1.31.0">element:PWML</title>
    		<g
       id="_x30_.1.31.1">
    			<title
       id="0.1.31.1.0">package:1X08</title>
    				<line
       id="_x30_.1.31.1.1"
       fill="none"
       stroke="#FFFFFF"
       x1="138.892"
       y1="10.8"
       x2="135.292"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="135.292"
       y1="10.8"
       x2="133.492"
       y2="9" />
    				<line
       id="_x30_.1.31.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="133.492"
       y1="9"
       x2="133.492"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="133.492"
       y1="5.4"
       x2="135.292"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="147.892"
       y1="9"
       x2="146.091"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="146.091"
       y1="10.8"
       x2="142.491"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="142.491"
       y1="10.8"
       x2="140.693"
       y2="9" />
    				<line
       id="_x30_.1.31.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="140.693"
       y1="9"
       x2="140.693"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="140.693"
       y1="5.4"
       x2="142.491"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="142.491"
       y1="3.6"
       x2="146.091"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="146.091"
       y1="3.6"
       x2="147.892"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="138.892"
       y1="10.8"
       x2="140.693"
       y2="9" />
    				<line
       id="_x30_.1.31.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="140.693"
       y1="5.4"
       x2="138.892"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="135.292"
       y1="3.6"
       x2="138.892"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="160.49"
       y1="10.8"
       x2="156.893"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="156.893"
       y1="10.8"
       x2="155.092"
       y2="9" />
    				<line
       id="_x30_.1.31.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="155.092"
       y1="9"
       x2="155.092"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="155.092"
       y1="5.4"
       x2="156.893"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="155.092"
       y1="9"
       x2="153.292"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="153.292"
       y1="10.8"
       x2="149.693"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="149.693"
       y1="10.8"
       x2="147.892"
       y2="9" />
    				<line
       id="_x30_.1.31.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="147.892"
       y1="9"
       x2="147.892"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="147.892"
       y1="5.4"
       x2="149.693"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="149.693"
       y1="3.6"
       x2="153.292"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="153.292"
       y1="3.6"
       x2="155.092"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="169.49"
       y1="9"
       x2="167.693"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="167.693"
       y1="10.8"
       x2="164.092"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="164.092"
       y1="10.8"
       x2="162.293"
       y2="9" />
    				<line
       id="_x30_.1.31.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="162.293"
       y1="9"
       x2="162.293"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="162.293"
       y1="5.4"
       x2="164.092"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="164.092"
       y1="3.6"
       x2="167.693"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="167.693"
       y1="3.6"
       x2="169.49"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="160.49"
       y1="10.8"
       x2="162.293"
       y2="9" />
    				<line
       id="_x30_.1.31.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="162.293"
       y1="5.4"
       x2="160.49"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="156.893"
       y1="3.6"
       x2="160.49"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="182.092"
       y1="10.8"
       x2="178.49"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="178.49"
       y1="10.8"
       x2="176.693"
       y2="9" />
    				<line
       id="_x30_.1.31.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="176.693"
       y1="9"
       x2="176.693"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="176.693"
       y1="5.4"
       x2="178.49"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="176.693"
       y1="9"
       x2="174.893"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="174.893"
       y1="10.8"
       x2="171.293"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="171.293"
       y1="10.8"
       x2="169.49"
       y2="9" />
    				<line
       id="_x30_.1.31.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="169.49"
       y1="9"
       x2="169.49"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="169.49"
       y1="5.4"
       x2="171.293"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="171.293"
       y1="3.6"
       x2="174.893"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="174.893"
       y1="3.6"
       x2="176.693"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="183.893"
       y1="9"
       x2="183.893"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="182.092"
       y1="10.8"
       x2="183.893"
       y2="9" />
    				<line
       id="_x30_.1.31.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="183.893"
       y1="5.4"
       x2="182.092"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="178.49"
       y1="3.6"
       x2="182.092"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="131.692"
       y1="10.8"
       x2="128.092"
       y2="10.8" />
    				<line
       id="_x30_.1.31.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="128.092"
       y1="10.8"
       x2="126.292"
       y2="9" />
    				<line
       id="_x30_.1.31.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="126.292"
       y1="9"
       x2="126.292"
       y2="5.4" />
    				<line
       id="_x30_.1.31.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="126.292"
       y1="5.4"
       x2="128.092"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="131.692"
       y1="10.8"
       x2="133.492"
       y2="9" />
    				<line
       id="_x30_.1.31.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="133.492"
       y1="5.4"
       x2="131.692"
       y2="3.6" />
    				<line
       id="_x30_.1.31.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="128.092"
       y1="3.6"
       x2="131.692"
       y2="3.6" />
    		</g>
    	</g>
    	<g
       id="_x30_.1.41">
    		<title
       id="0.1.41.0">element:XIO</title>
    		<g
       id="_x30_.1.41.1">
    			<title
       id="0.1.41.1.0">package:2X18</title>
    				<line
       id="_x30_.1.41.1.1"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="3.6"
       x2="263.092"
       y2="5.4" />
    				<line
       id="_x30_.1.41.1.2"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="5.4"
       x2="263.092"
       y2="9" />
    				<line
       id="_x30_.1.41.1.3"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="9"
       x2="264.893"
       y2="10.8" />
    				<line
       id="_x30_.1.41.1.4"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="10.8"
       x2="263.092"
       y2="12.6" />
    				<line
       id="_x30_.1.41.1.5"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="12.6"
       x2="263.092"
       y2="16.2" />
    				<line
       id="_x30_.1.41.1.6"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="16.2"
       x2="264.893"
       y2="18" />
    				<line
       id="_x30_.1.41.1.7"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="18"
       x2="263.092"
       y2="19.8" />
    				<line
       id="_x30_.1.41.1.8"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="19.8"
       x2="263.092"
       y2="23.4" />
    				<line
       id="_x30_.1.41.1.9"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="23.4"
       x2="264.893"
       y2="25.2" />
    				<line
       id="_x30_.1.41.1.10"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="25.2"
       x2="263.092"
       y2="27" />
    				<line
       id="_x30_.1.41.1.11"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="27"
       x2="263.092"
       y2="30.6" />
    				<line
       id="_x30_.1.41.1.12"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="30.6"
       x2="264.893"
       y2="32.4" />
    				<line
       id="_x30_.1.41.1.13"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="32.4"
       x2="263.092"
       y2="34.2" />
    				<line
       id="_x30_.1.41.1.14"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="34.2"
       x2="263.092"
       y2="37.8" />
    				<line
       id="_x30_.1.41.1.15"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="37.8"
       x2="264.893"
       y2="39.6" />
    				<line
       id="_x30_.1.41.1.16"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="39.6"
       x2="263.092"
       y2="41.4" />
    				<line
       id="_x30_.1.41.1.17"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="41.4"
       x2="263.092"
       y2="45" />
    				<line
       id="_x30_.1.41.1.18"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="45"
       x2="264.893"
       y2="46.8" />
    				<line
       id="_x30_.1.41.1.19"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="3.6"
       x2="275.693"
       y2="3.6" />
    				<line
       id="_x30_.1.41.1.20"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="3.6"
       x2="277.49"
       y2="5.4" />
    				<line
       id="_x30_.1.41.1.21"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="5.4"
       x2="277.49"
       y2="9" />
    				<line
       id="_x30_.1.41.1.22"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="9"
       x2="275.693"
       y2="10.8" />
    				<line
       id="_x30_.1.41.1.23"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="10.8"
       x2="277.49"
       y2="12.6" />
    				<line
       id="_x30_.1.41.1.24"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="12.6"
       x2="277.49"
       y2="16.2" />
    				<line
       id="_x30_.1.41.1.25"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="16.2"
       x2="275.693"
       y2="18" />
    				<line
       id="_x30_.1.41.1.26"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="18"
       x2="277.49"
       y2="19.8" />
    				<line
       id="_x30_.1.41.1.27"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="19.8"
       x2="277.49"
       y2="23.4" />
    				<line
       id="_x30_.1.41.1.28"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="23.4"
       x2="275.693"
       y2="25.2" />
    				<line
       id="_x30_.1.41.1.29"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="25.2"
       x2="277.49"
       y2="27" />
    				<line
       id="_x30_.1.41.1.30"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="27"
       x2="277.49"
       y2="30.6" />
    				<line
       id="_x30_.1.41.1.31"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="30.6"
       x2="275.693"
       y2="32.4" />
    				<line
       id="_x30_.1.41.1.32"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="32.4"
       x2="277.49"
       y2="34.2" />
    				<line
       id="_x30_.1.41.1.33"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="34.2"
       x2="277.49"
       y2="37.8" />
    				<line
       id="_x30_.1.41.1.34"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="37.8"
       x2="275.693"
       y2="39.6" />
    				<line
       id="_x30_.1.41.1.35"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="39.6"
       x2="277.49"
       y2="41.4" />
    				<line
       id="_x30_.1.41.1.36"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="41.4"
       x2="277.49"
       y2="45" />
    				<line
       id="_x30_.1.41.1.37"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="45"
       x2="275.693"
       y2="46.8" />
    				<line
       id="_x30_.1.41.1.38"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="46.8"
       x2="277.49"
       y2="48.6" />
    				<line
       id="_x30_.1.41.1.39"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="48.6"
       x2="277.49"
       y2="52.2" />
    				<line
       id="_x30_.1.41.1.40"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="52.2"
       x2="275.693"
       y2="54" />
    				<line
       id="_x30_.1.41.1.41"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="54"
       x2="277.49"
       y2="55.8" />
    				<line
       id="_x30_.1.41.1.42"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="55.8"
       x2="277.49"
       y2="59.4" />
    				<line
       id="_x30_.1.41.1.43"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="59.4"
       x2="275.693"
       y2="61.2" />
    				<line
       id="_x30_.1.41.1.44"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="61.2"
       x2="277.49"
       y2="63" />
    				<line
       id="_x30_.1.41.1.45"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="63"
       x2="277.49"
       y2="66.6" />
    				<line
       id="_x30_.1.41.1.46"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="66.6"
       x2="275.693"
       y2="68.4" />
    				<line
       id="_x30_.1.41.1.47"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="68.4"
       x2="277.49"
       y2="70.2" />
    				<line
       id="_x30_.1.41.1.48"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="70.2"
       x2="277.49"
       y2="73.8" />
    				<line
       id="_x30_.1.41.1.49"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="73.8"
       x2="275.693"
       y2="75.6" />
    				<line
       id="_x30_.1.41.1.50"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="75.6"
       x2="277.49"
       y2="77.4" />
    				<line
       id="_x30_.1.41.1.51"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="77.4"
       x2="277.49"
       y2="81" />
    				<line
       id="_x30_.1.41.1.52"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="81"
       x2="275.693"
       y2="82.799" />
    				<line
       id="_x30_.1.41.1.53"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="82.799"
       x2="277.49"
       y2="84.6" />
    				<line
       id="_x30_.1.41.1.54"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="84.6"
       x2="277.49"
       y2="88.2" />
    				<line
       id="_x30_.1.41.1.55"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="90"
       x2="277.49"
       y2="88.2" />
    				<line
       id="_x30_.1.41.1.56"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="90"
       x2="277.49"
       y2="91.799" />
    				<line
       id="_x30_.1.41.1.57"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="95.4"
       x2="277.49"
       y2="91.799" />
    				<line
       id="_x30_.1.41.1.58"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="95.4"
       x2="275.693"
       y2="97.2" />
    				<line
       id="_x30_.1.41.1.59"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="97.2"
       x2="277.49"
       y2="99" />
    				<line
       id="_x30_.1.41.1.60"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="102.6"
       x2="277.49"
       y2="99" />
    				<line
       id="_x30_.1.41.1.61"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="102.6"
       x2="275.693"
       y2="104.4" />
    				<line
       id="_x30_.1.41.1.62"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="104.4"
       x2="277.49"
       y2="106.2" />
    				<line
       id="_x30_.1.41.1.63"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="109.799"
       x2="277.49"
       y2="106.2" />
    				<line
       id="_x30_.1.41.1.64"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="109.799"
       x2="275.693"
       y2="111.6" />
    				<line
       id="_x30_.1.41.1.65"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="111.6"
       x2="277.49"
       y2="113.4" />
    				<line
       id="_x30_.1.41.1.66"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="117"
       x2="277.49"
       y2="113.4" />
    				<line
       id="_x30_.1.41.1.67"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="117"
       x2="275.693"
       y2="118.799" />
    				<line
       id="_x30_.1.41.1.68"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="118.799"
       x2="277.49"
       y2="120.6" />
    				<line
       id="_x30_.1.41.1.69"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="124.2"
       x2="277.49"
       y2="120.6" />
    				<line
       id="_x30_.1.41.1.70"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="124.2"
       x2="275.693"
       y2="126" />
    				<line
       id="_x30_.1.41.1.71"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="126"
       x2="277.49"
       y2="127.799" />
    				<line
       id="_x30_.1.41.1.72"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="131.4"
       x2="277.49"
       y2="127.799" />
    				<line
       id="_x30_.1.41.1.73"
       fill="none"
       stroke="#FFFFFF"
       x1="277.49"
       y1="131.4"
       x2="275.693"
       y2="133.2" />
    				<line
       id="_x30_.1.41.1.74"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="133.2"
       x2="263.092"
       y2="131.4" />
    				<line
       id="_x30_.1.41.1.75"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="131.4"
       x2="263.092"
       y2="127.799" />
    				<line
       id="_x30_.1.41.1.76"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="126"
       x2="263.092"
       y2="127.799" />
    				<line
       id="_x30_.1.41.1.77"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="126"
       x2="263.092"
       y2="124.2" />
    				<line
       id="_x30_.1.41.1.78"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="124.2"
       x2="263.092"
       y2="120.6" />
    				<line
       id="_x30_.1.41.1.79"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="118.799"
       x2="263.092"
       y2="120.6" />
    				<line
       id="_x30_.1.41.1.80"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="118.799"
       x2="263.092"
       y2="117" />
    				<line
       id="_x30_.1.41.1.81"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="113.4"
       x2="263.092"
       y2="117" />
    				<line
       id="_x30_.1.41.1.82"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="113.4"
       x2="264.893"
       y2="111.6" />
    				<line
       id="_x30_.1.41.1.83"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="111.6"
       x2="263.092"
       y2="109.799" />
    				<line
       id="_x30_.1.41.1.84"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="106.2"
       x2="263.092"
       y2="109.799" />
    				<line
       id="_x30_.1.41.1.85"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="106.2"
       x2="264.893"
       y2="104.4" />
    				<line
       id="_x30_.1.41.1.86"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="104.4"
       x2="263.092"
       y2="102.6" />
    				<line
       id="_x30_.1.41.1.87"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="102.6"
       x2="263.092"
       y2="99" />
    				<line
       id="_x30_.1.41.1.88"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="97.2"
       x2="263.092"
       y2="99" />
    				<line
       id="_x30_.1.41.1.89"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="97.2"
       x2="263.092"
       y2="95.4" />
    				<line
       id="_x30_.1.41.1.90"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="95.4"
       x2="263.092"
       y2="91.799" />
    				<line
       id="_x30_.1.41.1.91"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="90"
       x2="263.092"
       y2="91.799" />
    				<line
       id="_x30_.1.41.1.92"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="90"
       x2="263.092"
       y2="88.2" />
    				<line
       id="_x30_.1.41.1.93"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="88.2"
       x2="263.092"
       y2="84.6" />
    				<line
       id="_x30_.1.41.1.94"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="82.799"
       x2="263.092"
       y2="84.6" />
    				<line
       id="_x30_.1.41.1.95"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="82.799"
       x2="263.092"
       y2="81" />
    				<line
       id="_x30_.1.41.1.96"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="81"
       x2="263.092"
       y2="77.4" />
    				<line
       id="_x30_.1.41.1.97"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="75.6"
       x2="263.092"
       y2="77.4" />
    				<line
       id="_x30_.1.41.1.98"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="75.6"
       x2="263.092"
       y2="73.8" />
    				<line
       id="_x30_.1.41.1.99"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="73.8"
       x2="263.092"
       y2="70.2" />
    				<line
       id="_x30_.1.41.1.100"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="68.4"
       x2="263.092"
       y2="70.2" />
    				<line
       id="_x30_.1.41.1.101"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="68.4"
       x2="263.092"
       y2="66.6" />
    				<line
       id="_x30_.1.41.1.102"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="66.6"
       x2="263.092"
       y2="63" />
    				<line
       id="_x30_.1.41.1.103"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="61.2"
       x2="263.092"
       y2="63" />
    				<line
       id="_x30_.1.41.1.104"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="61.2"
       x2="263.092"
       y2="59.4" />
    				<line
       id="_x30_.1.41.1.105"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="59.4"
       x2="263.092"
       y2="55.8" />
    				<line
       id="_x30_.1.41.1.106"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="54"
       x2="263.092"
       y2="55.8" />
    				<line
       id="_x30_.1.41.1.107"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="54"
       x2="263.092"
       y2="52.2" />
    				<line
       id="_x30_.1.41.1.108"
       fill="none"
       stroke="#FFFFFF"
       x1="263.092"
       y1="52.2"
       x2="263.092"
       y2="48.6" />
    				<line
       id="_x30_.1.41.1.109"
       fill="none"
       stroke="#FFFFFF"
       x1="264.893"
       y1="46.8"
       x2="263.092"
       y2="48.6" />
    				<line
       id="_x30_.1.41.1.110"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="10.8"
       x2="264.893"
       y2="10.8" />
    				<line
       id="_x30_.1.41.1.111"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="18"
       x2="264.893"
       y2="18" />
    				<line
       id="_x30_.1.41.1.112"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="25.2"
       x2="264.893"
       y2="25.2" />
    				<line
       id="_x30_.1.41.1.113"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="32.4"
       x2="264.893"
       y2="32.4" />
    				<line
       id="_x30_.1.41.1.114"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="39.6"
       x2="264.893"
       y2="39.6" />
    				<line
       id="_x30_.1.41.1.115"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="46.8"
       x2="264.893"
       y2="46.8" />
    				<line
       id="_x30_.1.41.1.116"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="54"
       x2="264.893"
       y2="54" />
    				<line
       id="_x30_.1.41.1.117"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="61.2"
       x2="264.893"
       y2="61.2" />
    				<line
       id="_x30_.1.41.1.118"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="68.4"
       x2="264.893"
       y2="68.4" />
    				<line
       id="_x30_.1.41.1.119"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="75.6"
       x2="264.893"
       y2="75.6" />
    				<line
       id="_x30_.1.41.1.120"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="82.799"
       x2="264.893"
       y2="82.799" />
    				<line
       id="_x30_.1.41.1.121"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="90"
       x2="264.893"
       y2="90" />
    				<line
       id="_x30_.1.41.1.122"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="97.2"
       x2="264.893"
       y2="97.2" />
    				<line
       id="_x30_.1.41.1.123"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="104.4"
       x2="264.893"
       y2="104.4" />
    				<line
       id="_x30_.1.41.1.124"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="111.6"
       x2="264.893"
       y2="111.6" />
    				<line
       id="_x30_.1.41.1.125"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="118.799"
       x2="264.893"
       y2="118.799" />
    				<line
       id="_x30_.1.41.1.126"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="126"
       x2="264.893"
       y2="126" />
    				<line
       id="_x30_.1.41.1.127"
       fill="none"
       stroke="#FFFFFF"
       x1="275.693"
       y1="133.2"
       x2="264.893"
       y2="133.2" />
    		</g>
    	</g>
    	<g
       id="_x30_.2">
    		<title
       id="0.2.0">layer 21</title>
    			<line
       id="_x30_.2.1"
       fill="none"
       stroke="#FFFFFF"
       stroke-width="0.864"
       x1="266.693"
       y1="135"
       x2="266.693"
       y2="136.44" />
    			<line
       id="_x30_.2.2"
       fill="none"
       stroke="#FFFFFF"
       x1="266.693"
       y1="136.44"
       x2="273.893"
       y2="136.44" />
    			<line
       id="_x30_.2.3"
       fill="none"
       stroke="#FFFFFF"
       x1="273.893"
       y1="136.44"
       x2="273.893"
       y2="135" />
    		<g
       id="_x30_.2.9"
       transform="matrix(1,0,0,-1,0,44.879036)">
    			<g
       id="_x30_.2.9.0">
    				<g
       id="_x30_.2.9.0.0"
       transform="translate(199.772,16.2)">
    					<g
       id="_x30_.2.9.0.0.0"
       transform="rotate(-90)">
    							<text
       id="_x30_.2.9.0.0.0.0"
       transform="translate(3.051758e-4,-17.6804)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">0</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.10"
    			<g
       id="_x30_.2.10.0">
    				<g
       id="_x30_.2.10.0.0"
       transform="translate(192.572,16.2)">
    					<g
       id="_x30_.2.10.0.0.0"
    							<text
       id="_x30_.2.10.0.0.0.0"
       transform="translate(3.051758e-4,-17.6796)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">1</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.11"
    			<g
       id="_x30_.2.11.0">
    				<g
       id="_x30_.2.11.0.0"
       transform="translate(185.372,16.2)">
    					<g
       id="_x30_.2.11.0.0.0"
    							<text
       id="_x30_.2.11.0.0.0.0"
       transform="translate(3.051758e-4,-17.6788)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">2</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.12"
    			<g
       id="_x30_.2.12.0">
    				<g
       id="_x30_.2.12.0.0"
       transform="translate(178.172,16.2)">
    					<g
       id="_x30_.2.12.0.0.0"
    							<text
       id="_x30_.2.12.0.0.0.0"
       transform="translate(3.051758e-4,-17.68)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">3</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.13"
    			<g
       id="_x30_.2.13.0">
    				<g
       id="_x30_.2.13.0.0"
       transform="translate(170.972,16.2)">
    					<g
       id="_x30_.2.13.0.0.0"
    							<text
       id="_x30_.2.13.0.0.0.0"
       transform="translate(3.051758e-4,-17.6792)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">4</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.14"
    			<g
       id="_x30_.2.14.0">
    				<g
       id="_x30_.2.14.0.0"
       transform="translate(163.772,16.2)">
    					<g
       id="_x30_.2.14.0.0.0"
    							<text
       id="_x30_.2.14.0.0.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">5</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.15"
    			<g
       id="_x30_.2.15.0">
    				<g
       id="_x30_.2.15.0.0"
       transform="translate(156.572,16.2)">
    					<g
       id="_x30_.2.15.0.0.0"
    							<text
       id="_x30_.2.15.0.0.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">6</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.16"
    			<g
       id="_x30_.2.16.0">
    				<g
       id="_x30_.2.16.0.0"
       transform="translate(149.372,16.2)">
    					<g
       id="_x30_.2.16.0.0.0"
    							<text
       id="_x30_.2.16.0.0.0.0"
       transform="translate(3.051758e-4,-17.6808)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">7</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.17"
    			<g
       id="_x30_.2.17.0">
    				<g
       id="_x30_.2.17.0.0"
       transform="translate(138.572,16.2)">
    					<g
       id="_x30_.2.17.0.0.0"
    							<text
       id="_x30_.2.17.0.0.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">8</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.18"
    			<g
       id="_x30_.2.18.0">
    				<g
       id="_x30_.2.18.0.0"
       transform="translate(131.372,16.2)">
    					<g
       id="_x30_.2.18.0.0.0"
    							<text
       id="_x30_.2.18.0.0.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">9</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.19"
    			<g
       id="_x30_.2.19.0">
    				<g
       id="_x30_.2.19.0.0"
       transform="translate(124.172,19.8)">
    					<g
       id="_x30_.2.19.0.0.0"
    							<text
       id="_x30_.2.19.0.0.0.0"
       transform="translate(6.713867e-4,-17.68)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">10</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.20"
    			<g
       id="_x30_.2.20.0">
    				<g
       id="_x30_.2.20.0.0"
       transform="translate(116.972,19.8)">
    					<g
       id="_x30_.2.20.0.0.0"
    							<text
       id="_x30_.2.20.0.0.0.0"
       transform="translate(6.713867e-4,-17.6802)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">11</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.21"
    			<g
       id="_x30_.2.21.0">
    				<g
       id="_x30_.2.21.0.0"
       transform="translate(109.772,19.8)">
    					<g
       id="_x30_.2.21.0.0.0"
    							<text
       id="_x30_.2.21.0.0.0.0"
       transform="translate(6.713867e-4,-17.6804)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">12</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.22"
    			<g
       id="_x30_.2.22.0">
    				<g
       id="_x30_.2.22.0.0"
       transform="translate(102.572,19.8)">
    					<g
       id="_x30_.2.22.0.0.0"
    							<text
       id="_x30_.2.22.0.0.0.0"
       transform="translate(6.713867e-4,-17.6796)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">13</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.23"
       transform="matrix(1,0,0,-1,0,266.57916)">
    			<title
       id="0.2.23.0">text:0</title>
    			<g
       id="_x30_.2.23.1"
       transform="translate(164.132,137.88)">
    				<g
       id="_x30_.2.23.1.0"
    						<text
       id="_x30_.2.23.1.0.0"
       transform="translate(-0.6293,-17.6381)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A0</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.24"
    			<title
       id="0.2.24.0">text:1</title>
    			<g
       id="_x30_.2.24.1"
       transform="translate(170.612,137.88)">
    				<g
       id="_x30_.2.24.1.0"
    						<text
       id="_x30_.2.24.1.0.0"
       transform="translate(-0.6293,-17.6376)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A1</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.25"
    			<title
       id="0.2.25.0">text:2</title>
    			<g
       id="_x30_.2.25.1"
       transform="translate(178.532,137.88)">
    				<g
       id="_x30_.2.25.1.0"
    						<text
       id="_x30_.2.25.1.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A2</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.26"
    			<title
       id="0.2.26.0">text:3</title>
    			<g
       id="_x30_.2.26.1"
       transform="translate(185.732,137.88)">
    				<g
       id="_x30_.2.26.1.0"
    						<text
       id="_x30_.2.26.1.0.0"
       transform="translate(-0.6293,-17.6384)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A3</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.27"
    			<title
       id="0.2.27.0">text:4</title>
    			<g
       id="_x30_.2.27.1"
       transform="translate(192.932,137.88)">
    				<g
       id="_x30_.2.27.1.0"
    						<text
       id="_x30_.2.27.1.0.0"
       transform="translate(-0.6293,-17.6373)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A4</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.28"
    			<title
       id="0.2.28.0">text:5</title>
    			<g
       id="_x30_.2.28.1"
       transform="translate(199.772,137.88)">
    				<g
       id="_x30_.2.28.1.0"
    						<text
       id="_x30_.2.28.1.0.0"
       transform="translate(-0.6293,-17.6375)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A5</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.29"
    			<title
       id="0.2.29.0">text:6</title>
    			<g
       id="_x30_.2.29.1"
       transform="translate(206.972,137.88)">
    				<g
       id="_x30_.2.29.1.0"
    						<text
       id="_x30_.2.29.1.0.0"
       transform="translate(-0.6293,-17.6382)"
       fill="#ffffff"
       font-family="OCRA"
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.30"
    			<title
       id="0.2.30.0">text:7</title>
    			<g
       id="_x30_.2.30.1"
       transform="translate(214.532,137.88)">
    				<g
       id="_x30_.2.30.1.0"
    						<text
       id="_x30_.2.30.1.0.0"
       transform="translate(-0.6293,-17.6396)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A7</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.31"
    			<title
       id="0.2.31.0">text:8</title>
    			<g
       id="_x30_.2.31.1"
       transform="translate(228.932,137.88)">
    				<g
       id="_x30_.2.31.1.0"
    						<text
       id="_x30_.2.31.1.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A8</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.32"
    			<title
       id="0.2.32.0">text:9</title>
    			<g
       id="_x30_.2.32.1"
       transform="translate(236.132,137.88)">
    				<g
       id="_x30_.2.32.1.0"
    						<text
       id="_x30_.2.32.1.0.0"
       transform="translate(-0.6293,-17.6401)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A9</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.33"
    			<title
       id="0.2.33.0">text:10</title>
    			<g
       id="_x30_.2.33.1"
       transform="translate(243.332,137.88)">
    				<g
       id="_x30_.2.33.1.0"
    						<text
       id="_x30_.2.33.1.0.0"
       transform="translate(-0.6293,-17.637)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A10</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.34"
    			<title
       id="0.2.34.0">text:11</title>
    			<g
       id="_x30_.2.34.1"
       transform="translate(250.532,137.88)">
    				<g
       id="_x30_.2.34.1.0"
    						<text
       id="_x30_.2.34.1.0.0"
       transform="translate(-0.6293,-17.6397)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A11</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.35"
    			<title
       id="0.2.35.0">text:12</title>
    			<g
       id="_x30_.2.35.1"
       transform="translate(257.732,137.88)">
    				<g
       id="_x30_.2.35.1.0"
    						<text
       id="_x30_.2.35.1.0.0"
       transform="translate(-0.6293,-17.6405)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A12</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.36"
    			<title
       id="0.2.36.0">text:13</title>
    			<g
       id="_x30_.2.36.1"
       transform="translate(264.932,137.88)">
    				<g
       id="_x30_.2.36.1.0"
    						<text
       id="_x30_.2.36.1.0.0"
       transform="translate(-0.6293,-17.6374)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A13</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.37"
    			<title
       id="0.2.37.0">text:14</title>
    			<g
       id="_x30_.2.37.1"
       transform="translate(272.132,137.88)">
    				<g
       id="_x30_.2.37.1.0"
    						<text
       id="_x30_.2.37.1.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A14</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.38"
    			<title
       id="0.2.38.0">text:15</title>
    			<g
       id="_x30_.2.38.1"
       transform="translate(278.972,137.88)">
    				<g
       id="_x30_.2.38.1.0"
    						<text
       id="_x30_.2.38.1.0.0"
       transform="translate(-0.6293,-17.6403)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">A15</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.40"
       transform="matrix(-1,0,0,1,517.16856,0)">
    			<title
       id="0.2.40.0">text:22</title>
    			<text
       id="_x30_.2.40.1"
       transform="translate(255.8913,16.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">22</text>
    		</g>
    		<g
       id="_x30_.2.41"
    			<title
       id="0.2.41.0">text:24</title>
    			<text
       id="_x30_.2.41.1"
       transform="translate(255.8913,23.3999)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">24</text>
    		</g>
    		<g
       id="_x30_.2.42"
    			<title
       id="0.2.42.0">text:26</title>
    			<text
       id="_x30_.2.42.1"
       transform="translate(255.8913,30.6001)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">26</text>
    		</g>
    		<g
       id="_x30_.2.43"
    			<title
       id="0.2.43.0">text:28</title>
    			<text
       id="_x30_.2.43.1"
       transform="translate(255.8913,37.8003)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">28</text>
    		</g>
    		<g
       id="_x30_.2.44"
    			<title
       id="0.2.44.0">text:30</title>
    			<text
       id="_x30_.2.44.1"
       transform="translate(255.8913,45.0005)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">30</text>
    		</g>
    		<g
       id="_x30_.2.45"
       transform="matrix(-1,0,0,1,564.95381,0)">
    			<title
       id="0.2.45.0">text:31</title>
    			<text
       id="_x30_.2.45.1"
       transform="translate(279.2927,45.0005)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">31</text>
    		</g>
    		<g
       id="_x30_.2.46"
    			<title
       id="0.2.46.0">text:32</title>
    			<text
       id="_x30_.2.46.1"
       transform="translate(255.8913,52.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">32</text>
    		</g>
    		<g
       id="_x30_.2.47"
    			<title
       id="0.2.47.0">text:33</title>
    			<text
       id="_x30_.2.47.1"
       transform="translate(279.2927,52.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">33</text>
    		</g>
    		<g
       id="_x30_.2.48"
    			<title
       id="0.2.48.0">text:34</title>
    			<text
       id="_x30_.2.48.1"
       transform="translate(255.8913,59.3999)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">34</text>
    		</g>
    		<g
       id="_x30_.2.49"
    			<title
       id="0.2.49.0">text:35</title>
    			<text
       id="_x30_.2.49.1"
       transform="translate(279.2927,59.3999)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">35</text>
    		</g>
    		<g
       id="_x30_.2.50"
    			<title
       id="0.2.50.0">text:36</title>
    			<text
       id="_x30_.2.50.1"
       transform="translate(255.8913,66.6001)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">36</text>
    		</g>
    		<g
       id="_x30_.2.51"
    			<title
       id="0.2.51.0">text:37</title>
    			<text
       id="_x30_.2.51.1"
       transform="translate(279.2927,66.6001)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">37</text>
    		</g>
    		<g
       id="_x30_.2.52"
    			<title
       id="0.2.52.0">text:38</title>
    			<text
       id="_x30_.2.52.1"
       transform="translate(255.8913,73.8003)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">38</text>
    		</g>
    		<g
       id="_x30_.2.53"
    			<title
       id="0.2.53.0">text:39</title>
    			<text
       id="_x30_.2.53.1"
       transform="translate(279.2927,73.8003)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">39</text>
    		</g>
    		<g
       id="_x30_.2.54"
    			<title
       id="0.2.54.0">text:41</title>
    			<text
       id="_x30_.2.54.1"
       transform="translate(279.2927,81.0005)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">41</text>
    		</g>
    		<g
       id="_x30_.2.55"
    			<title
       id="0.2.55.0">text:40</title>
    			<text
       id="_x30_.2.55.1"
       transform="translate(255.8913,81.0005)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">40</text>
    		</g>
    		<g
       id="_x30_.2.56"
    			<title
       id="0.2.56.0">text:43</title>
    			<text
       id="_x30_.2.56.1"
       transform="translate(279.2927,88.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">43</text>
    		</g>
    		<g
       id="_x30_.2.57"
    			<title
       id="0.2.57.0">text:42</title>
    			<text
       id="_x30_.2.57.1"
       transform="translate(255.8913,88.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">42</text>
    		</g>
    		<g
       id="_x30_.2.58"
    			<title
       id="0.2.58.0">text:45</title>
    			<text
       id="_x30_.2.58.1"
       transform="translate(279.2927,95.3999)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">45</text>
    		</g>
    		<g
       id="_x30_.2.59"
    			<title
       id="0.2.59.0">text:47</title>
    			<text
       id="_x30_.2.59.1"
       transform="translate(279.2927,102.6001)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">47</text>
    		</g>
    		<g
       id="_x30_.2.60"
    			<title
       id="0.2.60.0">text:49</title>
    			<text
       id="_x30_.2.60.1"
       transform="translate(279.2927,109.8003)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">49</text>
    		</g>
    		<g
       id="_x30_.2.61"
    			<title
       id="0.2.61.0">text:51</title>
    			<text
       id="_x30_.2.61.1"
       transform="translate(279.2927,117.0005)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="2.5px">MOSI</text>
    		</g>
    		<g
       id="_x30_.2.62"
    			<title
       id="0.2.62.0">text:44</title>
    			<text
       id="_x30_.2.62.1"
       transform="translate(255.8913,95.3999)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">44</text>
    		</g>
    		<g
       id="_x30_.2.63"
    			<title
       id="0.2.63.0">text:46</title>
    			<text
       id="_x30_.2.63.1"
       transform="translate(255.8913,102.6001)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">46</text>
    		</g>
    		<g
       id="_x30_.2.64"
    			<title
       id="0.2.64.0">text:50</title>
    			<text
       id="_x30_.2.64.1"
       transform="translate(255.3073,117.0005)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="2.5px">MISO</text>
    		</g>
    		<g
       id="_x30_.2.65"
    			<title
       id="0.2.65.0">text:48</title>
    			<text
       id="_x30_.2.65.1"
       transform="translate(255.8913,109.8003)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">48</text>
    		</g>
    		<g
       id="_x30_.2.66"
    			<title
       id="0.2.66.0">text:53</title>
    			<text
       id="_x30_.2.66.1"
       transform="translate(279.2927,124.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="2.5px">SS</text>
    		</g>
    		<g
       id="_x30_.2.67"
    			<title
       id="0.2.67.0">text:52</title>
    			<text
       id="_x30_.2.67.1"
       transform="translate(255.8913,124.1997)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="2.5px">SCK</text>
    		</g>
    		<g
       id="_x30_.2.70">
    			<title
       id="0.2.70.0">element:C1</title>
    			<g
       id="_x30_.2.70.1">
    				<title
       id="0.2.70.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.71">
    			<title
       id="0.2.71.0">element:C2</title>
    			<g
       id="_x30_.2.71.1">
    				<title
       id="0.2.71.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.72">
    			<title
       id="0.2.72.0">element:C3</title>
    			<g
       id="_x30_.2.72.1">
    				<title
       id="0.2.72.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.73">
    			<title
       id="0.2.73.0">element:C4</title>
    			<g
       id="_x30_.2.73.1">
    				<title
       id="0.2.73.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.74">
    			<title
       id="0.2.74.0">element:C5</title>
    			<g
       id="_x30_.2.74.1">
    				<title
       id="0.2.74.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.75">
    			<title
       id="0.2.75.0">element:C6</title>
    			<g
       id="_x30_.2.75.1">
    				<title
       id="0.2.75.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.76">
    			<title
       id="0.2.76.0">element:C7</title>
    			<g
       id="_x30_.2.76.1">
    				<title
       id="0.2.76.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.77">
    			<title
       id="0.2.77.0">element:C8</title>
    			<g
       id="_x30_.2.77.1">
    				<title
       id="0.2.77.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.78">
    			<title
       id="0.2.78.0">element:C9</title>
    			<g
       id="_x30_.2.78.1">
    				<title
       id="0.2.78.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.79">
    			<title
       id="0.2.79.0">element:C10</title>
    			<g
       id="_x30_.2.79.1">
    				<title
       id="0.2.79.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.80">
    			<title
       id="0.2.80.0">element:C11</title>
    			<g
       id="_x30_.2.80.1">
    				<title
       id="0.2.80.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.81">
    			<title
       id="0.2.81.0">element:C12</title>
    			<g
       id="_x30_.2.81.1">
    				<title
       id="0.2.81.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.82">
    			<title
       id="0.2.82.0">element:C13</title>
    			<g
       id="_x30_.2.82.1">
    				<title
       id="0.2.82.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.83">
    			<title
       id="0.2.83.0">element:C14</title>
    			<g
       id="_x30_.2.83.1">
    				<title
       id="0.2.83.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.84">
    			<title
       id="0.2.84.0">element:C15</title>
    			<g
       id="_x30_.2.84.1">
    				<title
       id="0.2.84.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.85">
    			<title
       id="0.2.85.0">element:F1</title>
    			<g
       id="_x30_.2.85.1">
    				<title
       id="0.2.85.1.0">package:L1812</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.86">
    			<title
       id="0.2.86.0">element:FD1</title>
    			<g
       id="_x30_.2.86.1">
    				<title
       id="0.2.86.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.87">
    			<title
       id="0.2.87.0">element:FD2</title>
    			<g
       id="_x30_.2.87.1">
    				<title
       id="0.2.87.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.88">
    			<title
       id="0.2.88.0">element:FD3</title>
    			<g
       id="_x30_.2.88.1">
    				<title
       id="0.2.88.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.89">
    			<title
       id="0.2.89.0">element:FD4</title>
    			<g
       id="_x30_.2.89.1">
    				<title
       id="0.2.89.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.90">
    			<title
       id="0.2.90.0">element:GROUND</title>
    			<g
       id="_x30_.2.90.1">
    				<title
       id="0.2.90.1.0">package:SJ</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.91">
    			<title
       id="0.2.91.0">element:R1</title>
    			<g
       id="_x30_.2.91.1">
    				<title
       id="0.2.91.1.0">package:R0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.92">
    			<title
       id="0.2.92.0">element:R2</title>
    			<g
       id="_x30_.2.92.1">
    				<title
       id="0.2.92.1.0">package:R0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.93">
    			<title
       id="0.2.93.0">element:RN1</title>
    			<g
       id="_x30_.2.93.1">
    				<title
       id="0.2.93.1.0">package:CAT16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.94">
    			<title
       id="0.2.94.0">element:RN2</title>
    			<g
       id="_x30_.2.94.1">
    				<title
       id="0.2.94.1.0">package:CAY16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.95">
    			<title
       id="0.2.95.0">element:RN3</title>
    			<g
       id="_x30_.2.95.1">
    				<title
       id="0.2.95.1.0">package:CAY16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.96">
    			<title
       id="0.2.96.0">element:RN4</title>
    			<g
       id="_x30_.2.96.1">
    				<title
       id="0.2.96.1.0">package:CAY16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.97">
    			<title
       id="0.2.97.0">element:RN5</title>
    			<g
       id="_x30_.2.97.1">
    				<title
       id="0.2.97.1.0">package:CAT16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.98">
    			<title
       id="0.2.98.0">element:Z1</title>
    			<g
       id="_x30_.2.98.1">
    				<title
       id="0.2.98.1.0">package:CT/CN0603</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.99">
    			<title
       id="0.2.99.0">element:Z2</title>
    			<g
       id="_x30_.2.99.1">
    				<title
       id="0.2.99.1.0">package:CT/CN0603</title>
    			</g>
    		</g>
    		<title
       id="0.2.100">layer 25</title>
    		<g
       id="_x30_.2.103"
    			<g
       id="_x30_.2.103.0">
    				<g
       id="_x30_.2.103.0.0"
       transform="translate(88.087,25.9574)">
    					<g
       id="_x30_.2.103.0.0.0"
    							<text
       id="_x30_.2.103.0.0.0.0"
       transform="translate(0.4257,-17.6811)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">AREF</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.104"
    			<g
       id="_x30_.2.104.0">
    				<g
       id="_x30_.2.104.0.0"
       transform="translate(95.6779,22.2854)">
    					<g
       id="_x30_.2.104.0.0.0"
    							<text
       id="_x30_.2.104.0.0.0.0"
       transform="translate(-2.441406e-4,-17.6802)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">GND</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.105"
    			<g
       id="_x30_.2.105.0">
    				<g
       id="_x30_.2.105.0.0"
       transform="translate(192.572,30.96)">
    					<g
       id="_x30_.2.105.0.0.0"
    							<text
       id="_x30_.2.105.0.0.0.0"
       transform="translate(5.187988e-4,-17.6817)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">TX0</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.106"
    			<g
       id="_x30_.2.106.0">
    				<g
       id="_x30_.2.106.0.0"
       transform="translate(199.772,30.96)">
    					<g
       id="_x30_.2.106.0.0.0"
    							<text
       id="_x30_.2.106.0.0.0.0"
       transform="translate(5.187988e-4,-17.6825)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">RX0</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.108"
    			<g
       id="_x30_.2.108.0">
    				<g
       id="_x30_.2.108.0.0"
       transform="translate(113.647,139.141)">
    					<g
       id="_x30_.2.108.0.0.0"
    							<text
       id="_x30_.2.108.0.0.0.0"
       transform="translate(0.6239,-18.3759)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.25px">RESET</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.109"
    			<g
       id="_x30_.2.109.0">
    				<g
       id="_x30_.2.109.0.0"
       transform="translate(120.847,139.141)">
    					<g
       id="_x30_.2.109.0.0.0">
    						<g
       id="_x30_.2.109.0.0.0.0"
    								<text
       id="_x30_.2.109.0.0.0.0.0"
       transform="translate(0.6239,-18.3757)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.25px">3V3</text>
    						</g>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.110"
    			<g
       id="_x30_.2.110.0">
    				<g
       id="_x30_.2.110.0.0">
    						<text
       id="_x30_.2.110.0.0.0"
       transform="rotate(-90,124.1148,14.4023)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.25px">5V</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.111"
    			<title
       id="0.2.111.0">text:VIN</title>
    				<text
       id="_x30_.2.111.1"
       transform="rotate(-90,135.02595,3.48435)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.25px">VIN</text>
    		</g>
    		<g
       id="_x30_.2.112"
    			<title
       id="0.2.112.0">text:GND</title>
    				<text
       id="_x30_.2.112.1"
       transform="rotate(-90,131.3106,7.1987)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.25px">GND</text>
    		</g>
    		<g
       id="_x30_.2.113"
    			<title
       id="0.2.113.0">text:GND</title>
    				<text
       id="_x30_.2.113.1"
       transform="rotate(-90,127.7105,10.7988)"
       fill="#ffffff"
       font-family="OCRA"
    		</g>
    		<g
       id="_x30_.2.114"
    			<g
       id="_x30_.2.114.0">
    				<g
       id="_x30_.2.114.0.0"
       transform="translate(257.372,30.96)">
    					<g
       id="_x30_.2.114.0.0.0"
    							<text
       id="_x30_.2.114.0.0.0.0"
       transform="translate(1.3618,-17.8568)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">SDA 20</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.115"
    			<g
       id="_x30_.2.115.0">
    				<g
       id="_x30_.2.115.0.0"
       transform="translate(264.572,30.96)">
    					<g
       id="_x30_.2.115.0.0.0"
    							<text
       id="_x30_.2.115.0.0.0.0"
       transform="translate(1.3618,-17.8575)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">SCL 21</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.117"
    			<g
       id="_x30_.2.117.0">
    				<g
       id="_x30_.2.117.0.0"
       transform="translate(228.572,30.96)">
    					<g
       id="_x30_.2.117.0.0.0"
    							<text
       id="_x30_.2.117.0.0.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">TX2 16</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.118"
    			<g
       id="_x30_.2.118.0">
    				<g
       id="_x30_.2.118.0.0"
       transform="translate(235.772,30.96)">
    					<g
       id="_x30_.2.118.0.0.0"
    							<text
       id="_x30_.2.118.0.0.0.0"
       transform="translate(1.3618,-17.8583)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">RX2 17</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.119"
    			<g
       id="_x30_.2.119.0">
    				<g
       id="_x30_.2.119.0.0"
       transform="translate(221.372,30.96)">
    					<g
       id="_x30_.2.119.0.0.0"
    							<text
       id="_x30_.2.119.0.0.0.0"
       transform="translate(1.3618,-17.8567)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">RX3 15</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.120"
    			<title
       id="0.2.120.0">text:TX3</title>
    			<g
       id="_x30_.2.120.1"
       transform="translate(214.172,30.96)">
    				<g
       id="_x30_.2.120.1.0"
    						<text
       id="_x30_.2.120.1.0.0"
       transform="translate(1.3618,-17.8578)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">TX3 14</text>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.121"
    			<g
       id="_x30_.2.121.0">
    				<g
       id="_x30_.2.121.0.0"
       transform="translate(250.172,30.96)">
    					<g
       id="_x30_.2.121.0.0.0"
    							<text
       id="_x30_.2.121.0.0.0.0"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">RX1 19</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.122"
    			<g
       id="_x30_.2.122.0">
    				<g
       id="_x30_.2.122.0.0"
       transform="translate(242.972,30.96)">
    					<g
       id="_x30_.2.122.0.0.0"
    							<text
       id="_x30_.2.122.0.0.0.0"
       transform="translate(1.3618,-17.8571)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.75px">TX1 18</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.124"
       transform="matrix(-1,0,0,1,524.39117,0)">
    			<title
       id="0.2.124.0">text:5V</title>
    			<text
       id="_x30_.2.124.1"
       transform="translate(259.9382,3.4966)"
       fill="#ffffff"
       font-family="OCRA"
    		</g>
    		<g
       id="_x30_.2.125"
       transform="matrix(-1,0,0,1,562.13205,0)">
    			<title
       id="0.2.125.0">text:GND</title>
    			<text
       id="_x30_.2.125.1"
       transform="translate(276.7722,136.8003)"
       fill="#ffffff"
       font-family="OCRA"
    		</g>
    		<g
       id="_x30_.2.128">
    			<title
       id="0.2.128.0">text:M.Banzi</title>
    		</g>
    		<g
       id="_x30_.2.129">
    			<title
       id="0.2.129.0">text:D.Cuartielles</title>
    		</g>
    		<g
       id="_x30_.2.130">
    			<title
       id="0.2.130.0">text:D.Mellis</title>
    		</g>
    		<g
       id="_x30_.2.131">
    			<title
       id="0.2.131.0">text:G.Martino</title>
    		</g>
    		<g
       id="_x30_.2.132">
    			<title
       id="0.2.132.0">text:T.Igoe</title>
    		</g>
    		<g
       id="_x30_.2.133"
    			<g
       id="_x30_.2.133.0">
    				<g
       id="_x30_.2.133.0.0"
       transform="translate(106.087,139.141)">
    					<g
       id="_x30_.2.133.0.0.0"
    							<text
       id="_x30_.2.133.0.0.0.0"
       transform="rotate(90,16.6027,-11.9104)"
       fill="#ffffff"
       font-family="OCRA"
       font-size="3.25px">IOREF</text>
    					</g>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.134">
    			<title
       id="0.2.134.0">text:SDA</title>
    		</g>
    		<g
       id="_x30_.2.135">
    			<title
       id="0.2.135.0">text:SCL</title>
    		</g>
    		<g
       id="_x30_.2.136">
    			<title
       id="0.2.136.0">element:C1</title>
    			<g
       id="_x30_.2.136.1">
    				<title
       id="0.2.136.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.137">
    			<title
       id="0.2.137.0">element:C2</title>
    			<g
       id="_x30_.2.137.1">
    				<title
       id="0.2.137.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.138">
    			<title
       id="0.2.138.0">element:C3</title>
    			<g
       id="_x30_.2.138.1">
    				<title
       id="0.2.138.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.139">
    			<title
       id="0.2.139.0">element:C4</title>
    			<g
       id="_x30_.2.139.1">
    				<title
       id="0.2.139.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.140">
    			<title
       id="0.2.140.0">element:C5</title>
    			<g
       id="_x30_.2.140.1">
    				<title
       id="0.2.140.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.141">
    			<title
       id="0.2.141.0">element:C6</title>
    			<g
       id="_x30_.2.141.1">
    				<title
       id="0.2.141.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.142">
    			<title
       id="0.2.142.0">element:C7</title>
    			<g
       id="_x30_.2.142.1">
    				<title
       id="0.2.142.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.143">
    			<title
       id="0.2.143.0">element:C8</title>
    			<g
       id="_x30_.2.143.1">
    				<title
       id="0.2.143.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.144">
    			<title
       id="0.2.144.0">element:C9</title>
    			<g
       id="_x30_.2.144.1">
    				<title
       id="0.2.144.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.145">
    			<title
       id="0.2.145.0">element:C10</title>
    			<g
       id="_x30_.2.145.1">
    				<title
       id="0.2.145.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.146">
    			<title
       id="0.2.146.0">element:C11</title>
    			<g
       id="_x30_.2.146.1">
    				<title
       id="0.2.146.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.147">
    			<title
       id="0.2.147.0">element:C12</title>
    			<g
       id="_x30_.2.147.1">
    				<title
       id="0.2.147.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.148">
    			<title
       id="0.2.148.0">element:C13</title>
    			<g
       id="_x30_.2.148.1">
    				<title
       id="0.2.148.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.149">
    			<title
       id="0.2.149.0">element:C14</title>
    			<g
       id="_x30_.2.149.1">
    				<title
       id="0.2.149.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.150">
    			<title
       id="0.2.150.0">element:C15</title>
    			<g
       id="_x30_.2.150.1">
    				<title
       id="0.2.150.1.0">package:C0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.151">
    			<title
       id="0.2.151.0">element:D1</title>
    			<g
       id="_x30_.2.151.1">
    				<title
       id="0.2.151.1.0">package:SMB</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.152">
    			<title
       id="0.2.152.0">element:D2</title>
    			<g
       id="_x30_.2.152.1">
    				<title
       id="0.2.152.1.0">package:MINIMELF</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.153">
    			<title
       id="0.2.153.0">element:D3</title>
    			<g
       id="_x30_.2.153.1">
    				<title
       id="0.2.153.1.0">package:MINIMELF</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.154">
    			<title
       id="0.2.154.0">element:F1</title>
    			<g
       id="_x30_.2.154.1">
    				<title
       id="0.2.154.1.0">package:L1812</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.155">
    			<title
       id="0.2.155.0">element:FD1</title>
    			<g
       id="_x30_.2.155.1">
    				<title
       id="0.2.155.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.156">
    			<title
       id="0.2.156.0">element:FD2</title>
    			<g
       id="_x30_.2.156.1">
    				<title
       id="0.2.156.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.157">
    			<title
       id="0.2.157.0">element:FD3</title>
    			<g
       id="_x30_.2.157.1">
    				<title
       id="0.2.157.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.158">
    			<title
       id="0.2.158.0">element:FD4</title>
    			<g
       id="_x30_.2.158.1">
    				<title
       id="0.2.158.1.0">package:FIDUCIA-MOUNT</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.159">
    			<title
       id="0.2.159.0">element:GROUND</title>
    			<g
       id="_x30_.2.159.1">
    				<title
       id="0.2.159.1.0">package:SJ</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.160">
    			<title
       id="0.2.160.0">element:IC3</title>
    			<g
       id="_x30_.2.160.1">
    				<title
       id="0.2.160.1.0">package:TQFP100</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.161">
    			<title
       id="0.2.161.0">element:IC4</title>
    			<g
       id="_x30_.2.161.1">
    				<title
       id="0.2.161.1.0">package:MLF32</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.162">
    			<title
       id="0.2.162.0">element:IC6</title>
    			<g
       id="_x30_.2.162.1">
    				<title
       id="0.2.162.1.0">package:SOT23-DBV</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.163">
    			<title
       id="0.2.163.0">element:IC7</title>
    			<g
       id="_x30_.2.163.1">
    				<title
       id="0.2.163.1.0">package:MSOP08</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.164">
    			<title
       id="0.2.164.0">element:L</title>
    			<g
       id="_x30_.2.164.1">
    				<title
       id="0.2.164.1.0">package:CHIP-LED0805</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.165">
    			<title
       id="0.2.165.0">element:L1</title>
    			<g
       id="_x30_.2.165.1">
    				<title
       id="0.2.165.1.0">package:0805</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.167">
    			<title
       id="0.2.167.0">element:R1</title>
    			<g
       id="_x30_.2.167.1">
    				<title
       id="0.2.167.1.0">package:R0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.168">
    			<title
       id="0.2.168.0">element:R2</title>
    			<g
       id="_x30_.2.168.1">
    				<title
       id="0.2.168.1.0">package:R0603-ROUND</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.169">
    			<title
       id="0.2.169.0">element:RN1</title>
    			<g
       id="_x30_.2.169.1">
    				<title
       id="0.2.169.1.0">package:CAT16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.170">
    			<title
       id="0.2.170.0">element:RN2</title>
    			<g
       id="_x30_.2.170.1">
    				<title
       id="0.2.170.1.0">package:CAY16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.171">
    			<title
       id="0.2.171.0">element:RN3</title>
    			<g
       id="_x30_.2.171.1">
    				<title
       id="0.2.171.1.0">package:CAY16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.172">
    			<title
       id="0.2.172.0">element:RN4</title>
    			<g
       id="_x30_.2.172.1">
    				<title
       id="0.2.172.1.0">package:CAY16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.173">
    			<title
       id="0.2.173.0">element:RN5</title>
    			<g
       id="_x30_.2.173.1">
    				<title
       id="0.2.173.1.0">package:CAT16</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.174">
    			<title
       id="0.2.174.0">element:RX</title>
    			<g
       id="_x30_.2.174.1">
    				<title
       id="0.2.174.1.0">package:CHIP-LED0805</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.175">
    			<title
       id="0.2.175.0">element:T1</title>
    			<g
       id="_x30_.2.175.1">
    				<title
       id="0.2.175.1.0">package:SOT-23</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.176">
    			<title
       id="0.2.176.0">element:TX</title>
    			<g
       id="_x30_.2.176.1">
    				<title
       id="0.2.176.1.0">package:CHIP-LED0805</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.177">
    			<title
       id="0.2.177.0">element:XIO</title>
    			<g
       id="_x30_.2.177.1">
    				<title
       id="0.2.177.1.0">package:2X18</title>
    				<g
       id="_x30_.2.177.1.1">
    					<title
       id="0.2.177.1.1.0">text:XIO</title>
    				</g>
    			</g>
    		</g>
    		<g
       id="_x30_.2.178">
    			<title
       id="0.2.178.0">element:Y1</title>
    			<g
       id="_x30_.2.178.1">
    				<title
       id="0.2.178.1.0">package:RESONATOR</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.179">
    			<title
       id="0.2.179.0">element:Y2</title>
    			<g
       id="_x30_.2.179.1">
    				<title
       id="0.2.179.1.0">package:QS</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.180">
    			<title
       id="0.2.180.0">element:Z1</title>
    			<g
       id="_x30_.2.180.1">
    				<title
       id="0.2.180.1.0">package:CT/CN0603</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.181">
    			<title
       id="0.2.181.0">element:Z2</title>
    			<g
       id="_x30_.2.181.1">
    				<title
       id="0.2.181.1.0">package:CT/CN0603</title>
    			</g>
    		</g>
    		<g
       id="_x30_.2.182"
    			<path
       id="_x30_.2.182.0"
       fill="#ffffff"
       d="m 172.521,18.089 c 0.004,0 0.01,-10e-4 0.014,0 h 1.945 c 0.125,0 0.237,0.068 0.297,0.178 0.063,0.11 0.053,0.243 -0.016,0.347 l -0.978,1.459 c -0.125,0.188 -0.438,0.188 -0.563,0 l -0.931,-1.394 c -0.065,-0.062 -0.112,-0.152 -0.112,-0.253 0.007,-0.186 0.159,-0.337 0.344,-0.337 z" />
    		</g>
    		<g
       id="_x30_.2.183"
    			<path
       id="_x30_.2.183.0"
       fill="#ffffff"
       d="m 181.728,20.213 c -0.004,0 -0.008,10e-4 -0.015,0 h -1.942 c -0.125,0 -0.238,-0.068 -0.299,-0.178 -0.063,-0.11 -0.054,-0.243 0.018,-0.347 l 0.977,-1.459 c 0.125,-0.188 0.438,-0.188 0.563,0 l 0.932,1.394 c 0.068,0.062 0.111,0.152 0.111,0.253 -0.007,0.186 -0.161,0.337 -0.345,0.337 z" />
    		</g>
    	</g>
    </g>
    <g
       id="copper1">
    	<g
       id="copper0">
    		<circle
       id="connector1pad"
       fill="none"
       stroke="#F7BD13"
       stroke-width="1.0295"
       cx="216.293"
       cy="144"
       r="1.883" />
    		<circle
       id="connector2pad"
       fill="none"
       stroke="#F7BD13"
       cx="223.49"
       cy="144"
       r="1.883" />
    		<circle
       id="connector3pad"
       fill="none"
       stroke="#F7BD13"
       cx="230.693"
       cy="144"
       r="1.883" />
    		<circle
       id="connector4pad"
       fill="none"
       stroke="#F7BD13"
       cx="237.893"
       cy="144"
       r="1.883" />
    		<circle
       id="connector289pad"
       fill="none"
       stroke="#F7BD13"
       cx="118.371"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector5pad"
       fill="none"
       stroke="#F7BD13"
       cx="245.091"
       cy="144"
       r="1.883" />
    		<circle
       id="connector6pad"
       fill="none"
       stroke="#F7BD13"
       cx="252.293"
       cy="144"
       r="1.883" />
    		<circle
       id="connector7pad"
       fill="none"
       stroke="#F7BD13"
       cx="259.49"
       cy="144"
       r="1.883" />
    		<circle
       id="connector481pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="72"
       r="1.861" />
    		<circle
       id="connector8pad"
       fill="none"
       stroke="#F7BD13"
       cx="144.292"
       cy="144"
       r="1.883" />
    		<circle
       id="connector9pad"
       fill="none"
       stroke="#F7BD13"
       cx="151.491"
       cy="144"
       r="1.883" />
    		<circle
       id="connector305pad"
       fill="none"
       stroke="#F7BD13"
       cx="101.091"
       cy="144"
       r="1.883" />
    		<circle
       id="connector10pad"
       fill="none"
       stroke="#F7BD13"
       cx="158.693"
       cy="144"
       r="1.883" />
    		<circle
       id="connector11pad"
       fill="none"
       stroke="#F7BD13"
       cx="165.893"
       cy="144"
       r="1.883" />
    		<circle
       id="connector12pad"
       fill="none"
       stroke="#F7BD13"
       cx="173.091"
       cy="144"
       r="1.883" />
    		<circle
       id="connector13pad"
       fill="none"
       stroke="#F7BD13"
       cx="180.293"
       cy="144"
       r="1.883" />
    		<circle
       id="connector14pad"
       fill="none"
       stroke="#F7BD13"
       cx="187.49"
       cy="144"
       r="1.883" />
    		<circle
       id="connector465pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="14.4"
       r="1.861" />
    		<circle
       id="connector15pad"
       fill="none"
       stroke="#F7BD13"
       cx="194.693"
       cy="144"
       r="1.883" />
    		<circle
       id="connector497pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="129.6"
       r="1.861" />
    		<circle
       id="connector313pad"
       fill="none"
       stroke="#F7BD13"
       cx="158.693"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector473pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="43.2"
       r="1.861" />
    		<circle
       id="connector489pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="100.8"
       r="1.861" />
    		<circle
       id="connector285pad"
       fill="none"
       stroke="#F7BD13"
       cx="89.572"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector309pad"
       fill="none"
       stroke="#F7BD13"
       cx="129.892"
       cy="144"
       r="1.883" />
    		<circle
       id="connector317pad"
       fill="none"
       stroke="#F7BD13"
       cx="129.892"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector469pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="28.8"
       r="1.861" />
    		<circle
       id="connector477pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="57.6"
       r="1.861" />
    		<circle
       id="connector485pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="86.4"
       r="1.861" />
    		<circle
       id="connector493pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="115.2"
       r="1.861" />
    		<circle
       id="connector68pad"
       fill="none"
       stroke="#F7BD13"
       cx="245.091"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector69pad"
       fill="none"
       stroke="#F7BD13"
       cx="237.893"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector70pad"
       fill="none"
       stroke="#F7BD13"
       cx="230.693"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector283pad"
       fill="none"
       stroke="#F7BD13"
       cx="75.172"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector71pad"
       fill="none"
       stroke="#F7BD13"
       cx="223.49"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector287pad"
       fill="none"
       stroke="#F7BD13"
       cx="103.972"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector72pad"
       fill="none"
       stroke="#F7BD13"
       cx="216.293"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector73pad"
       fill="none"
       stroke="#F7BD13"
       cx="209.091"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector74pad"
       fill="none"
       stroke="#F7BD13"
       cx="201.893"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector75pad"
       fill="none"
       stroke="#F7BD13"
       cx="194.693"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector303pad"
       fill="none"
       stroke="#F7BD13"
       cx="86.692"
       cy="144"
       r="1.883" />
    		<circle
       id="connector307pad"
       fill="none"
       stroke="#F7BD13"
       cx="115.492"
       cy="144"
       r="1.883" />
    		<circle
       id="connector311pad"
       fill="none"
       stroke="#F7BD13"
       cx="173.091"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector315pad"
       fill="none"
       stroke="#F7BD13"
       cx="144.292"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector463pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="7.2"
       r="1.861" />
    		<circle
       id="connector467pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="21.6"
       r="1.861" />
    		<circle
       id="connector471pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="36"
       r="1.861" />
    		<circle
       id="connector475pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="50.4"
       r="1.861" />
    		<circle
       id="connector479pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="64.8"
       r="1.861" />
    		<circle
       id="connector483pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="79.2"
       r="1.861" />
    		<circle
       id="connector487pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="93.6"
       r="1.861" />
    		<circle
       id="connector491pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="108"
       r="1.861" />
    		<circle
       id="connector495pad"
       fill="none"
       stroke="#F7BD13"
       cx="273.893"
       cy="122.4"
       r="1.861" />
    		<circle
       id="connector282pad"
       fill="none"
       stroke="#F7BD13"
       cx="67.972"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector284pad"
       fill="none"
       stroke="#F7BD13"
       cx="82.371"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector286pad"
       fill="none"
       stroke="#F7BD13"
       cx="96.772"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector288pad"
       fill="none"
       stroke="#F7BD13"
       cx="111.172"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector302pad"
       fill="none"
       stroke="#F7BD13"
       cx="79.492"
       cy="144"
       r="1.883" />
    		<circle
       id="connector304pad"
       fill="none"
       stroke="#F7BD13"
       cx="93.892"
       cy="144"
       r="1.883" />
    		<circle
       id="connector306pad"
       fill="none"
       stroke="#F7BD13"
       cx="108.292"
       cy="144"
       r="1.883" />
    		<circle
       id="connector308pad"
       fill="none"
       stroke="#F7BD13"
       cx="122.692"
       cy="144"
       r="1.883" />
    		<circle
       id="connector310pad"
       fill="none"
       stroke="#F7BD13"
       cx="180.293"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector312pad"
       fill="none"
       stroke="#F7BD13"
       cx="165.893"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector314pad"
       fill="none"
       stroke="#F7BD13"
       cx="151.491"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector316pad"
       fill="none"
       stroke="#F7BD13"
       cx="137.091"
       cy="7.2"
       r="1.884" />
    		<circle
       id="connector462pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="7.2"
       r="1.861" />
    		<circle
       id="connector464pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="14.4"
       r="1.861" />
    		<circle
       id="connector466pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="21.6"
       r="1.861" />
    		<circle
       id="connector468pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="28.8"
       r="1.861" />
    		<circle
       id="connector470pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="36"
       r="1.861" />
    		<circle
       id="connector472pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="43.2"
       r="1.861" />
    		<circle
       id="connector474pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="50.4"
       r="1.861" />
    		<circle
       id="connector476pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="57.6"
       r="1.861" />
    		<circle
       id="connector478pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="64.8"
       r="1.861" />
    		<circle
       id="connector480pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="72"
       r="1.861" />
    		<circle
       id="connector482pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="79.2"
       r="1.861" />
    		<circle
       id="connector484pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="86.4"
       r="1.861" />
    		<circle
       id="connector486pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="93.6"
       r="1.861" />
    		<circle
       id="connector488pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="100.8"
       r="1.861" />
    		<circle
       id="connector490pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="108"
       r="1.861" />
    		<circle
       id="connector492pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="115.2"
       r="1.861" />
    		<circle
       id="connector494pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="122.4"
       r="1.861" />
    		<circle
       id="connector496pad"
       fill="none"
       stroke="#F7BD13"
       cx="266.693"
       cy="129.6"
       r="1.861" />
    		<circle
       id="connector0pad"
       fill="none"
       stroke="#F7BD13"
       cx="209.091"
       cy="144"
       r="1.883" />
    	</g>
    </g>
    </svg>
  • colporteur
    0 colporteur over 4 years ago in reply to javagoza
    I might give the impression I know Inkscape but when someone who actually know the application and uses it, my skills are minimal in comparison. Your suggestion enable me to see the text. Thanks.
  • colporteur
    0 colporteur over 4 years ago in reply to BigG
    OK now that I can see the text me thinks there are other forces at play.
    The errant text is only on bottom side rendering of the Mega. This screen shot shows the text correctly.
    Maybe what is happening is normal and my lack of spacial recognition is the problem. I'm thinking what is on the screen is going to be what is printed. Is that correct for the reversed text on some Mega footprints.
    0 Jan Cumps over 4 years ago in reply to colporteur
    Bottom text appears reversed in the PCB editor.
    If you select the 3D renderer, you can rotate the result, and see the backside as if you have the PCB in your hand.
  • phoenixcomm
    0 phoenixcomm over 4 years ago
    imageI have a baseboard, as I do a lot of wire-wrapping. If you add a wire wrap to a post then putting a shield on top is out of the question. So what I do Is to put the Mega as a kit that is without the headers soldered in place.. I use the headers on the baseboard and then I use long-tail headers on the MEGA.
    On the baseboard in the rear, I have  wire-wrap pins soldered on so I can do my work there.
  • colporteur
    0 colporteur over 4 years ago in reply to Jan Cumps
    My PCB are for personal use, so poor silk screening is something I will have to accept to avoid breadboarding another unit. The first has been brutal!
  • colporteur
    0 colporteur over 4 years ago in reply to phoenixcomm
    I'm using up some old Mega stock. In the future the pinning my own board is what I will do. I've done that for Nano's for a number of years. Only because they are cheaper to purchase.
