Arduino Forum Delay vs Timer
  • Replies 15 replies
  • Subscribers 414 subscribers
  • Views 3549 views
  • code
Delay vs Timer
WumblingBorkeys
WumblingBorkeys over 4 years ago
I'm making a laser maze for an event, and I've been trying to work this out in my head...
void section1()
  delay(100);// delay to make sure it's a real trigger
  laserstate1 = digitalRead(lasersens1);
  if(laserstate1 == 1)// if it is a trigger, if it isn't make sure the lights are off and go back to the loop
  leds[0] = CRGB (255,255,255);
  leds[1] = CRGB (255,255,255);
  leds[2] = CRGB (255,255,255);//Trigger lights to illuminate those who tripped it
  leds[3] = CRGB (255,255,255);
  leds[4] = CRGB (255,255,255);
  FastLED.show();
    //resetButtonState = digitalRead(resetButton);
    while(digitalRead(resetButton) == 0 ||  digitalRead(lasersens1) == 1) {//require the person to leave then press a button to reset the lights
  leds[0] = CRGB (0,0,0);
  leds[1] = CRGB (0,0,0);
  leds[2] = CRGB (0,0,0);
  leds[3] = CRGB (0,0,0);
  leds[4] = CRGB (0,0,0);
  FastLED.show();
void loop() {
    while (1)
        laserstate1 = digitalRead(lasersens1);//Wait for a laser to be blocked
            section1(); //Trigger the section sequence
There would be more lasers, hoping to be in the neighborhood of 10-20
My question is would there be an advantage to running a timer instead of the delay in "section1"?
I know there theoretically there would be but when it's only 100ms it doesn't feel necessary.
It should be noted that each lasersens wouldn't trip its own section but rather a group of "lasersens" would make a section, and each trigger a singular set of lights.
The only other thing would be an addition of a kill switch they could find and press to deactivate the system. for x amount of time.
  • fmilburn
    fmilburn over 4 years ago +7
    Hi WumblingBorkeys , In general it isn't considered good practice to use delays like this and a non-blocking timer is better. The delay function can work if the application is simple enough but might…
  • fmilburn
    fmilburn over 4 years ago in reply to WumblingBorkeys +6
    I suspect it is because the variable section1Timer is "int" while the millis() function is "unsigned long". The variable section1Timer is probably rolling over after 30 seconds or so while millis() keeps…
  • fmilburn
    fmilburn over 4 years ago in reply to shabaz +4
    Hi Shabaz, I agree it isn't that clean. Timer callbacks aren't listed in the basic Arduino reference documentation that I could see but a search turns up libraries presumably written by others such as…
  • WumblingBorkeys
    WumblingBorkeys over 4 years ago in reply to fmilburn
    I've started to Class-based program and I'm into an issue with my overloaded constructors...
    I want to make a section of lasers/ laser-detectors into a class and then just call an update loop for each section.
    I figured that I could probably call the constructor within another constructor to eliminate duplicated code but now I am getting --
    "declaration of 'senssector pin1' shadows a parameter" error
    As I understand shadows a parameter means there is another 'pin1' variable somewhere which there isn't.....
    I'll attach the Class alone and the rest of the code in another imbed.
    class senssector
      // Class Member Variables
      // These are initialized at startup
      int sens;
      int tripCheck =100;
      int triggerCheck =300;
      int trigger = 0;
      int sens1 =2;
      int sens2 =2;
      int sens3 =2;//pin 2 will  be grounded  and always report a 0/LOW
      int sens4 =2;//so if it is unuesed it will not influnce anything
      int sens5 =2;
      // These maintain the current state
      int laserState;                 // laserState used to set the LED
      unsigned long previousMillis;   // will store last time Update was updated
      // Constructor&Overloads - creates a Flasher
      // and initializes the member variables and state
    public:
      senssector(int pin)
      int sens1 = pin;
      pinMode(sens1, INPUT);
      pinMode(2,INPUT);
      laserState = 0;
      previousMillis = 0;
       senssector(int pin1,int pin2)
       int sens2 = pin2;
       pinMode(sens2, INPUT);
       senssector(pin1);
         senssector(int pin3,int pin4,int pin5)
         int sens3 = pin5;
         pinMode(sens3, INPUT);
         senssector(pin3,pin4);
            senssector(int pin6,int pin7,int pin8,int pin9)
            int sens4 = pin9;
            senssector(pin6,pin7,pin8);
              senssector(int pin10,int pin11,int pin12,int pin13,int pin14)
              int sens5 = pin14;
              pinMode(sens5, INPUT);
              senssector(pin10,pin11,pin12,pin13);
    void Update()
        // check to see if it's time to change the state of the LED
        unsigned long currentMillis = millis();
        sens = digitalRead(sens1) + digitalRead(sens2) + digitalRead(sens3) + digitalRead(sens4) + digitalRead(sens5);
        if((laserState == 0) && (currentMillis - previousMillis >= tripCheck) && (sens == 0))
          laserState = 1;  // Advance laser State
          previousMillis = currentMillis;  // Remember the time
        if ((laserState == 1) && (currentMillis - previousMillis >= tripCheck) &&(sens == 0))
          laserState = 2;  //advance to trigger state
          trigger = 1;
          return trigger;   // Update the actual LEDs
        else if ((laserState == 1) && (currentMillis - previousMillis >= tripCheck) &&(sens == 1))
          laserState = 0;
        if ((laserState == 2) && (currentMillis - previousMillis >= tripCheck))
          if(sens == 0 && digitalRead(resetButton) ==0)
            trigger =0;
            return trigger;
          else
    #include <FastLED.h>
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
    //------------------------Light int-----------------
    #define NUM_LEDS 25
    #define DATA_PIN 12
    #define COLOR_ORDER GRB
    #define CHIPSET WS2812B
    #define BRIGHTNESS 060
    #define VOLTS 5
    #define MAX_AMPS 500
    CRGB leds[NUM_LEDS];
    //--------------timer-----------
    unsigned long section1Timer;
    //1 is tripped zero should be normal
    //--------------Laser Int-------------------
    const int lasersens1 = 2;
    int sensSect1;
    int section1Tripped;
    const int lasersens2 = 3;
    int sensSect2;
    int section2Tripped;
    const int lasersens3 = 4;
    const int lasersens4 = 5;
    const int lasersens5 = 6;
    //---------------------GI/O-------- mostly not used
    const int disablebutton =10;
    int disablebuttonstate;
    int buttonpresscount =0;
    const int resetButton = 9;
    int resetButtonState = 0;
    int senssec1 = 0;
    int tripcount = 0;
    // Set the LCD address to 0x27 for a 16 chars and 2 line display
    LiquidCrystal_I2C lcd(0x27, 16, 2);
    //Class for detecting and handling laser detections------------------------------------
    class senssector
      int sens;
      int tripCheck =100;
      int trigger = 0;
      int sens1 =2;
      int sens2 =2;
      int sens5 =2;
    public:
      senssector(int pin)
      int sens1 = pin;
      pinMode(2,INPUT);
      laserState = 0;
      previousMillis = 0;
       int sens2 = pin2;
       senssector(pin1);
         int sens3 = pin5;
            int sens4 = pin9;
              int sens5 = pin14;
    void Update()
          trigger = 1;
          laserState = 0;
            trigger =0;
            return trigger;
          else
    void setup() {
     //intialize a sector
     senssectorone.senssector(3,4);
     pinMode(resetButton, INPUT);
     FastLED.addLeds<CHIPSET, DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS);
     FastLED.setMaxPowerInVoltsAndMilliamps(VOLTS,MAX_AMPS);
     FastLED.setBrightness(BRIGHTNESS);
     FastLED.clear();
     FastLED.show();
      // initialize the LCD
      lcd.begin();
      lcd.backlight();
      Serial.begin(9600);
    void loop() {
     updateLcd();
    int triggerLights(int x) //Trigger lights to illuminate those who tripped it
    switch (x){
      case 1:
      FastLED.show();
      tripcount++;
      break;
     case 2:
      leds[5] = CRGB (255,255,255);
      leds[6] = CRGB (255,255,255);
      leds[7] = CRGB (255,255,255);
      leds[8] = CRGB (255,255,255);
      leds[9] = CRGB (255,255,255);
      FastLED.show();
      tripcount++;
      break;
      default:
      break;
    int shutOffLights(int x) //shutoff lights that aren't tripped anymore
    switch (x){
      case 1:
      FastLED.show();
      break;
     case 2:
      leds[5] = CRGB (0,0,0);
      leds[6] = CRGB (0,0,0);
      leds[7] = CRGB (0,0,0);
      leds[8] = CRGB (0,0,0);
      leds[9] = CRGB (0,0,0);
      FastLED.show();
      break;
      default:
      break;
    int updateLcd()
     lcd.setCursor(0, 0);
     lcd.print("Times Tripped");
     lcd.setCursor(0, 1);
     lcd.print(tripcount);
  • WumblingBorkeys
    WumblingBorkeys over 4 years ago in reply to WumblingBorkeys
    Most of my Class experience comes from C#, and I have no idea how much transfers. Also I tried implementing state-machine but I'm not to sure. my last code seemed along the lines of state-machine (at least to me) to begin with. Thanks in advanced!
  • fmilburn
    I basically do C programming when using microcontrollers, somewhat tainted with a bit of C++ and am self taught.  My suggestion is to whittle it down to just enough to demonstrate the error when requesting help.  Somewhat related, you have generated a lot of code in a very short period of time.  Get a simple framework working first and then add in the detail, testing as you go along.  That way you can quickly determine which line broke the code and try to determine why that is.
  • WumblingBorkeys
    Well, I've made a lot of progress, at this point, it's functioning! I couldn't figure out if you could call constructors from constructors but I just put in a couple of minutes to create the different constructors in their entirety. At this point, it's just adding a couple of features and getting off to the races! Thanks, SOO much fmiburn!! I'll attach what I've got and probably make a new thread when I have all I want done done, with circuit diagrams and whatnot!
    #include <Wire.h>
    #define NUM_LEDS 25
    #define DATA_PIN 12
    #define VOLTS 5
    //1 is no light, zero should be active
    const int resetButton =11;
    int senssec1 = 0;
    int tripcount = 0;
    class senssector
      int sens;
      int tripCheck =100;
      int trigger = 0;
      int sens1 =2;
      int sens2 =2;
      int sens5 =2;
      int sect;
    public:
      senssector(int light, int pin){
      sect = light;
      sens1 = pin;
      laserState = 0;
      previousMillis = 0;
      senssector(int light,int pin,int pin1) {
      sect = light;
      sens2 = pin1;
      sens1 = pin;
      laserState = 0;
      previousMillis = 0;
      //senssector(light1, pin1);
         senssector(int light,int pin,int pin1,int pin2){
         sect = light;
         sens1 = pin;
         sens2 = pin1;
         sens3 = pin2;
         laserState = 0;
         previousMillis = 0;
            senssector(int light,int pin,int pin1,int pin2,int pin3)
            sect = light;
            sens1 = pin;
            sens2 = pin1;
            sens3 = pin2;
            sens4 = pin3;
            pinMode(sens4, INPUT);
            laserState = 0;
            previousMillis = 0;
                senssector(int light,int pin,int pin1,int pin2,int pin3,int pin4)
                sect = light;
                sens1 = pin;
                sens2 = pin1;
                sens3 = pin2;
                sens4 = pin3;
                sens5 = pin4;
                laserState = 0;
                previousMillis = 0;
    void poll()
        Serial.println("poll");
        sens = digitalRead(sens1)+ digitalRead(sens2) + digitalRead(sens3) + digitalRead(sens4) + digitalRead(sens5);
        Serial.println(sens);
        if((laserState == 0) && (currentMillis - previousMillis >= tripCheck) && (sens != 0))
        if ((laserState == 1) && (currentMillis - previousMillis >= tripCheck) &&(sens != 0))
          triggerLights(sect);// Update the actual LEDs
        else if ((laserState == 1) && (currentMillis - previousMillis >= tripCheck) &&(sens == 0))
          laserState = 0;
          if(sens == 0 && digitalRead(resetButton) == 0)
            shutOffLights(sect);
            laserState=0;
          else
          switch (x){
          case 1:
           FastLED.show();
           tripcount++;
          break;
          case 2:
            FastLED.show();
            tripcount++;
           break;
           default:
           break;
    switch (x){
      case 1:
      FastLED.show();
      break;
     case 2:
      FastLED.show();
       break;
       default:
       break;
    senssector senssectorone(1,3,4,5,6);
    senssector senssectortwo(2,7);
    void setup() {
     pinMode(2,INPUT);
     FastLED.clear();
     FastLED.show();
      lcd.begin();
      lcd.backlight();
      Serial.begin(9600);
    void loop() {
     updateLcd();
     senssectorone.poll();
     senssectortwo.poll();
    int updateLcd()
  • fmilburn
    Great!  I do hope you make a post when you are done.
