Arduino Forum Hi, I need some hellp with my code structure.
  • Replies 40 replies
  • Subscribers 410 subscribers
  • Views 7205 views
phoenixcomm
phoenixcomm over 3 years ago
for you that don't know I grew up writing C code. So my Code Base has multiple files currently working on my Landing Gear for my sim.
I have the following files in the LandingGear directory:
LandingGear.ino
isr1.c through isr5.c
lamps.c
and landingGear.h
so in lamps.c  i have my code for the lamp test.
void lampTest( int state ){
for( int count = 0; count < 10; count++;) {
digitalWrite( Lamps.pin[count] ); }
it is called from isr4 (isr4.c)
it is also  declared in landingGear.h
#define TRUE 1
#define FALSE -1
#define ON 1
#define OFF 0
/************************** Prototypes *****************************/
void lampTest( int state );
void lamp( Lamps.pin[count], int state );
void blink( Lamps.pin[count] );
typedef struct Lamps{
char name[];
char name[];
lamp} Lamps[] = {
{22, "RIGHT", "RED"}, {23, "NOSE", "RED"}, {24, "LEFT", "RED"},
{25, "RIGHT", "GREEN"}, {26, "NOSE", "GREEN"}, {27, "LEFT", "GREEN"},
{28, "WARNnose", "GREEN"}, {29, "WARNgear, "ORANGE"}, {30, "WARNnoseDis, "BLUE"}, {31, "WARNskid", "RED"}};
and pucks with this isr4.c:2:12: error: ‘ON’ undeclared (first use in this function)    lampTest( ON );
cam anybody give me a straight answer why this happens???
~~  thanks C Harrison
    shabaz over 3 years ago +9
    Hi Cris, The following rules extremely strong guidelines I think apply to your specific scenarios: (1) For every .c file apart from main.c, create a header file with the same name. Otherwise, it's…
    shabaz over 3 years ago in reply to phoenixcomm +5
    Hi Cris, This is what's causing the problems, because there will be corner-cases (sometimes more often than not) where things will break down and not compile (as you have seen) unless those guidelines…
  • ntewinkel
    ntewinkel over 3 years ago in reply to shabaz +3
    What shabaz said ^ It can be tempting to cut corners by skipping coding best practices, but then you often run into issues that cost you so much more time and frustration later.
    0 Jan Cumps over 3 years ago in reply to Andrew J
    That's me typing an A on a QUERTY keyboard without looking...
  • Andrew J
    0 Andrew J over 3 years ago in reply to Jan Cumps
    Ah, ok...I thought it was some special C thing.  You know, like right hand values and left hand values (whatever it's actually termed!)
    Fixed it Grin
  • phoenixcomm
    0 phoenixcomm over 3 years ago in reply to Jan Cumps
    no you can NOT typedef a struct with out the name of the struct is and the name of it typedefed!
    case in point typedef struct { int thing; char abc; char name[10]; } led; this begs the question what is the advantage of this? None;  he is trying to rename the struct but it only has one name listed::= led; which is the same as struct { int thing; char abc; char name[10]; } led;   if on the other hand if had done this: typedef struct led { int thing; char abc; char name[10]; } led; you still end up with what we started with. But lets make some use of the typedef like this: typedef struct led { int thing; char abc; char name[10]; } warninLamp; now the typedef of led is now warningLamp..
    Now does it make sense you all?? CAH
    0 Jan Cumps over 3 years ago in reply to phoenixcomm
  • phoenixcomm
     Jan Cumps  Duh, you got it. i hope.
    Do you now understand my comment? why the first example on stack exchange is junk?? and would have made more sense if he never used typedef which is just trash and hyperbole. furthermore, I think Eclipse with GCC would have flagged it.  I just don't like the Arduino IDE! it's very crude, you cant build CLEAN, and its SAVE function does not work as you will lose your .h files. or you can't write over the original code (DUH?).
    I think the IDE should be ABANDONED! and use the C/C++ Eclipse tool set with Arduino PlugIn.  ~~ CAH there is a word that comes to mind. but you said it upsets people. You will Please note there is a third definition. where it can refer to inanimate objects.
    • Vote Up -1 Vote Down
    Best test is to try it, and see.
  • phoenixcomm
    0 phoenixcomm over 3 years ago in reply to Andrew J
     Andrew J nah, don't like it. PERL is better for strings, unfortunatly it is typeless which means if you had 4 oranges and 3 apples you will end up with 7 fruits :)) imageand if you are up for it try APL, great for math and 3D stuff, Fortran has been replace by C. ~~CAH
  • Stuart_S
    0 Stuart_S 9 months ago
    Hi Chris,
    This is my answer and I'm a couple of years behind, your function " lampTest( int state )" has the variable ON passed into it as " lampTest( ON) "  and replicated as 'state'. the state variable is not used within your lampTest function. Maybe try something like this:
    if (state){
              for( int count = 0; count < 10; count++;) {  // this syntax is a bit different to what Id use on C18
  • dang74
    0 dang74 9 months ago in reply to shabaz
    Great response.... with special emphasis on items 5 and 6.
