Arduino Forum Mini CNC machine Arduino Based & Adafruit Driver Motor L293D v1 & 2*Mini Stepper CD/DVD player
  • Subscribers 412 subscribers
  • Views 1640 views
  • arduino uno
  • help
  • stepper motor with arduino
  • l293d
  • cnc
  • prototyping
  • help_required
  • arduino_development_environment
samiboutgoulla
samiboutgoulla over 3 years ago
Hello everyone, I'm trying to make a small dvd-based cnc machine that contains two small stepper motors, but in each video on youtube the height between x and y is not specified, here are the links some video to understand if someone has an idea I ask him to answer me and help me ""https://youtu.be/CmDMgwrPLKY""https://youtu.be/">youtu.be/.../ KsZn5lQo1DY""">https://youtu.be/qMWEW3rzd2Q"
  • mayermakes
    mayermakes over 3 years ago +1
    that height does not matter, its up to you to decide and set it in your FW. when you build your own machine all measurements can be set by you and you have to accountfor the min the firmware anyway.
  • mayermakes
  • samiboutgoulla
    samiboutgoulla over 3 years ago in reply to mayermakes
    hi mayermakes thank you for your reply , can you more  explain what is FW , and give more details
  • mayermakes
    mayermakes over 3 years ago in reply to samiboutgoulla
    FW= Firmware, the piece of software you write that drives the machine.
    you can either write it fro mscratch or use something like GRBL or Marlin to run your machine depending on the Hardware you are using.
    if you buiild everything from scratch all the choices are up to you.
    Here is a blog series I did that explains the major steps of building cnc machines.
    Clem's CNC Control Project
  • samiboutgoulla
    thank you mayermakes for your help but I'm not good at code and i don't know how to change it .
