Arduino Forum Errors AHT10
  • Subscribers 411 subscribers
  • Views 1076 views
  • arduino uno r4 wifi
Errors AHT10
Henrik_t2
Henrik_t2 over 2 years ago
Hello
I have bought 2 AHT10 sensors and I want to do a small test to see if they work.
See code.
But getting a lot of errors?? I am using Arduino Uno R4 Wifi Thanks
The code
#include <Wire.h>
#include <Adafruit_AHT10.h>
AHT10 myAHT(0x38);
void setup() {
  Wire.begin();
  Serial.begin(9600);
  Serial.println ("Initialising AHT10 Sensor");
  if (!myAHT10.begin ())
  Serial.println("Sensor error!");
  while(1);
void loop() {
 float temp = myAHT10.readTemperature ();
 float hum = myAHT10.readHumidity();
 Serial.print("Temp:");
 Serial.print (temp);
 Serial("°C");
 Serial.print("Humidity:");
 Serial.print (hum);
 Serial("%");
 delay (1000);
Errors
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino:4:1: error: 'AHT10' does not name a type
AHT10 myAHT(0x38);
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino: In function 'void setup()':
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino:11:8: error: 'myAHT10' was not declared in this scope
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino: In function 'void loop()':
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino:18:15: error: 'myAHT10' was not declared in this scope
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino:22:14: error: no match for call to '(UART) (const char [4])'
Serial("°C");
M:\Arduino Sketch\AHT10 sensor\sketch_apr7a_AHT10_test_2\sketch_apr7a_AHT10_test_2.ino:25:12: error: no match for call to '(UART) (const char [2])'
Serial("%");
exit status 1
Compilation error: 'AHT10' does not name a type
  • misaz
    misaz over 2 years ago +3
    You declared myAHT at line 4, but later use myAHT 10 . Change AHT10 myAHT(0x38); to AHT10 myAHT10(0x38);
  • JWx
    0 JWx over 2 years ago
    which library do you use? there is Adafruit_AHTX0 library, but the include file is named Adafruit_AHTX0.h and the class is named the same (Adafruit_AHTX0)
    have you tried using any examples provided with your library?
  • misaz
    0 misaz over 2 years ago
    You declared myAHT at line 4, but later use myAHT10. Change
    AHT10 myAHT(0x38);
    to
