Arduino Forum Arduino- Wait For Key Press without Library
  • Subscribers 415 subscribers
  • Views 942 views
  • arduino sketch
obulorn
obulorn over 9 years ago
I need help, I have a circuit setup with input (74hc165) and output (74hc595) shift registers.  Am trying out with 4x4 matrix keypad (for thats what i have available for now) but this will end up 8x8 matrix keypad. I have put a firmware together and that is running ok and returning the key press. But my challenge is;  how can I make Arduino loop function wait for a keypress. Presently it continously returns the last key pressed. I played around it without luck; I adopted the code below from online, this only wait for the initial time(ie without any key pressed), the moment a key is press, it runs with it  and return that key until another is press.
const unsigned int DebounceDelay = 15;
 const long AutoRepeatDelay = 125;
 const unsigned int KeyWait = 25;
int WaitKey()
    int key;
    //    wait for all keys to be released
    key = KeyDown();
    if (key == 0)
        long repeatTime = millis() + AutoRepeatDelay;
        do
                    // wait a bit
            delay(KeyWait);
            //    see if a key is still down
            if (KeyDown() != 0)
                //    debounce the key release
                delay(DebounceDelay);
                if (KeyDown() != 0)
                    key = 0;
                    break;
                else if (millis()>repeatTime)
                            //    effect auto-repeat
                            break;
        } while (true);
       //    wait for a key to be pressed
        while (key != 0)
            key = KeyDown();
            if (key == 0)
                //    debounce the key down
            else
                delay(KeyWait);
return key;
    dougw over 9 years ago
    After you read a new key press, reset key to a unique value. When you read key, test to see if it is the reset value or some new value. If it is the reset value, ignore it.
  • obulorn
    obulorn over 9 years ago in reply to dougw
    Many thanks Mr Douglas for your time. Is this what you mean by reset?
    void loop()
    int UniqueVal=0;
    int keypress =WaitKey();
    keypress =Uniqueval;
    if (keypress==Uniqueval)
    { ignore}
    else
    {return}
    or can you please put some thing together for me.
