Arduino Forum Hi how to convert analogy signal to digital signal in arduino
  • Replies 11 replies
  • Subscribers 404 subscribers
  • Views 1611 views
Hi! Can some one help me with Arduino codes for converting analog signal to digital signal.
There four input analog signal wishing to convert each them to digital signal.
  • R_Phoenix
    R_Phoenix over 11 years ago
    First off, I don't see why you are using analogRead(), unless your switches in your schematic are just representations of something that outputs an actual analog signal - You are not reading Analog. Your pins will see either LOW (switch close) or HIGH, assuming the internal pullups are set. So why not use Digital pins for this?
    Former Member over 11 years ago in reply to R_Phoenix
    My switches in my schematic are just representations of something that outputs analog signal,I  have set threshold value for each pin
