Arduino Forum How to interrupt delay?
  • Subscribers 403 subscribers
  • Views 3150 views
  • delay
Hi, it's me again,
So want to press button to close relay and then it opens after fixed time or I press button again, whichever comes first.  I can do the time, but I can't figure how to interrupt or halt the delay prematurely with a second button press.
I have tried replacing
int stayON = 10000;
delay(stayON);
with
int stayON = 100;
int var = 0;
            while(var < 100 && stateButton == LOW)
                delay(stayON);
                var++;
trying to break delay down into smaller increments and make it so if I press button then the while stops.  It works fine if I don't have any stateButton evaluations, but as soon as I add the button eval it just blinks when I press button but relay doesn't ever close.  I have tried a bazillion different ways of doing this with no luck and it's the only concept I have found, that I understand anyway.
Any help would be appreciated, thank you!
Full unmodified code below:
int pinButton = 10;
int Relay = 11;
int stateRelay = LOW;
int stateButton;
int previous = LOW;
long time = 0;
long debounce = 500;
int stayON = 10000;
void setup() {
pinMode(pinButton, INPUT);
pinMode(Relay, OUTPUT);
Serial.begin(9600);
void loop()
stateButton = digitalRead(pinButton);
if(stateButton == HIGH && previous == LOW && millis() - time > debounce)
  if(stateRelay == HIGH)
      digitalWrite(Relay, LOW);
  else
      digitalWrite(Relay, HIGH);
      Serial.print(1);
      delay(stayON);
      Serial.print(2);
time = millis();
previous == stateButton;
    Ok I found the answer, go down to odometers post, it doesn't use the delay function and works perfectly.   Adafruit customer service forums • View topic - Countdown Timer Relay Sketch Help
    mcb1 over 10 years ago in reply to Former Member
    check out the IMO porrly worded "BlinkWithoutDelay" in the examples in Arduino IDE.
    As peter said don't use Delay().
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to mcb1
    Yes, good point mcb1, that is a good example to refer to
