Arduino Forum Code for multiple soil moisture sensors
  • Answers 5 answers
  • Subscribers 409 subscribers
  • Views 2542 views
izzrahim
izzrahim over 7 years ago
Hi there, Im working on Soil Moisture Sensors using Arduino Uno, however I have no knowledge on how to come up with a code, here are things that i need to do:
1)  how to come up with a code, I will be using 6 analogs (6 sensors) of A0 to A5 at one time and I need them to have simultaneous readings.
2) Since I need to have 6 readings simultaneously, how do i put them in a code  and how to extract these 6 readings into PLX-DAQ excel.
3) how do I separate these 6 readings (from A0,A1,A2,A3,A4 & A5) into individual column in excel and serial monitor.
thanks in advance.
    dougw over 7 years ago +3 suggested
    An arduino typically cannot read all channels simultaneously. Analog channels can be read sequentially with about 0.1 ms between readings. For moisture readings this would normally be sufficient. To make…
  • mp2100
    mp2100 over 7 years ago +2 suggested
    Izz, How flexible are you for solutions (budget and programming language)? If Arduino is required, you’ll be limited by the memory of the computer, very few data points can be saved. You could use an add…
  • luislabmo
    luislabmo over 7 years ago in reply to izzrahim +2 suggested
    Hello Izz, This Arduino example is probably the starting point to learn how to read Analog input with an Arduino and then using the serial as output. Then, use the serial info produced by the arduino to…
    0 dougw over 7 years ago
    To make an arduino system that can read analog channels simultaneously requires external sample and hold circuitry or external A/D converters.
    Could you explain why you need simultaneous sampling in case there is a better way to achieve your requirement?
  • mp2100
    0 mp2100 over 7 years ago
    Izz,
    How flexible are you for solutions (budget and programming language)?  If Arduino is required, you’ll be limited by the memory of the computer, very few data points can be saved.  You could use an add-on SD memory card shield.  For example:
    https://www.adafruit.com/product/1141
    Using that, you can file writing to the SD memory card.  If you are moving this into Excel, I use the simplest format, a CSV file, write each data point to the SD card with a comma between each value.
  • izzrahim
    0 izzrahim over 7 years ago in reply to dougw
    Okay Thanks. I know nothing about Arduino and coding, can I ask for your assistance to help me with the coding (sketch), what to be included, what are the loops, basically how to get 6 analogs in a code.
    I'm doing this experiment of measuring volumetric water content in a one meter cylinder, and I'll be placing six soil moisture sensors inside the cylinder... later i will introduce water on the top and I need to measure (obtain readings) the water content in the cylinder at different height. And these readings are to be taken for 24 hours period: I need to have all six readings (since you mentioned that it cant be done simultaneously, therefore a gap of 0.1 ms should be fine) every five minutes.
    thanks for the explanation.
  • luislabmo
    0 luislabmo over 7 years ago in reply to izzrahim
    Hello Izz,
    Then, use the serial info produced by the arduino to build the excel with your computer, few options that come to my mind:
    • Processing
    • Use the Parallax Data Acquisition tool:
      • One example here
      • Another example
    Good luck.
    Luis
    0 dougw over 7 years ago in reply to izzrahim
    You could also measure the water depth with a single capacitance sensor:
    Keysight Technologies U1282A Digital Multimeter - Applications - Water Level Sensing
    Texas Instruments FDC2214 Capacitance to Digital - Review
    An arduino can measure capacitance using just 2 wires and a resistor.
