Arduino Forum Serial array problems
  • Subscribers 414 subscribers
  • Views 897 views
tabarus12
tabarus12 over 12 years ago
Hi guys, Im having problems storing arrays of data from the serial input of the arduino, I made a program to read the data and print back the array ordered but it does not seem to work.
It prints this.
I recived: 1-0-0-0-0-0-0-0-
I recived: 2-0-0-0-0-0-0-0-
I recived: 3-0-0-0-0-0-0-0-
When it should be printing this.
I recived: 1-2-3-0-0-0-0-0-
Can anyone tell me where Im wrong?
Here is the code, the program reads it ok just does not store it correctly.
int d[8];
int b = 0;
void setup() {
  Serial.begin(9600);
void loop() {
  b = 0;
  for(b = 0; b < 8; b++) {
    d[b] = 0;
  b = 0;
  while(Serial.available() > 0) { //Verifies serial byte ready
    Serial.println(""); //New line
    Serial.print("I recived: "); //Prints the start mesage
    for (b = 0; b < 8; b++) { //Increase array location
        d[b] = Serial.read() - 48; //Stores data on array location
      Serial.print(d[b]); //Prints data array location
      Serial.print("-"); //Separator
  • billabott
    billabott over 12 years ago in reply to e14 Contributor +1
    Ha, we had a race condition.
  • tabarus12
    tabarus12 over 12 years ago +1
    Found the issue, the for was running too fast, problem solved with a 1 millisecond delay on the for loop to allow the serial interface to set next value. Any how thanks for the tips Ill try them too.
  • billabott
    0 billabott over 12 years ago
    Can anyone tell me where you are wrong?    Yes, I can try.
    Here is the corrected code, the program reads and stores correctly now.
    int d[8];
    int b = 0;
    void setup() {
      Serial.begin(9600);
    void loop() {
      b = 0;
        d[b] = 0;
      b = 0;
        for (b = 0; (b < 8)||(Serial.available() <= 0); b++) { //Increase array locationindex if not out of data
            Serial.print(d[b]); //Prints data value array location
    -=SyntaxMatters=-
    I think you want an "if" instead of "while".
    The "while" causes each value that is read to be stored into
    the same location, overwriting the previous value, because
    b isn't incremented within the "while" loop.
  • billabott
    0 billabott over 12 years ago in reply to e14 Contributor
    Ha, we had a race condition.  image
  • tabarus12
    0 tabarus12 over 12 years ago
