Arduino Forum 6V DC Motor Battery??
  • Subscribers 405 subscribers
  • Views 2421 views
mparmpas122321
mparmpas122321 over 11 years ago
Hey guys! I am electrical engineering student and i have a project running. My supervisor told me to control this motor Pololu - 47:1 Metal Gearmotor 25Dx52L mm with 48 CPR Encoder. It needs 6V supply and has a maximum current of 2.2A. What battery should i use with this motor? If i put 4AA batteries, will they be able to give a 2.2A current if needed? I have searched a lot but people say that a battery can theoretically supply whatever current needed but for different time, according to its mAh capacity. Others say that a battery can handle limited current.
Any help?
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +2
    All good advice given by all I would like to simply add to the mix based on your desire to protect the motor and keep things simple Rechargables typically also can output significantly more current than…
    shabaz over 11 years ago +1
    Hi Manos, 4xAA will be fine. As an elec eng student you should just try it - sometimes it's good to experiment. As for the theory, it's related to battery internal resistance. According to the URL, 2.2A…
  • vaghasiamadhuri
    vaghasiamadhuri over 11 years ago +1
    U can use 5 cell NiMh battery pack or buy 5NiMh cell and connect them in series.... So u will have chargeable battery pack of (5x1.2 = 6 V)... and it ll be low cost too...
    0 Robert Peter Oakes over 11 years ago
    Rechargables typically also can output significantly more current than the equivalent alkaline batery, so if this is a real concern, stick with 4 AA alkaline and your good to go. The internal resistance will provide some protection to the motor should it stall and it is a simple solution
    You can protect with other batteries but that would involve more circuitry outside of the battery in order to limit the current
    Regards
    peter, Good Luck with whatever path you choose.
    Regards
