Arduino Forum Is it possible to transport humans and things through air?
  • Replies 22 replies
  • Subscribers 421 subscribers
  • Views 3321 views
  • crazy
  • teleport
  • dixonselvan
  • ideas
  • teleportation
  • travel
dixonselvan
dixonselvan over 9 years ago
I wonder how it would be if we can transport human beings or other things like luggage, goods and livestock through air. Something similar to teleport. Is it really possible to break atoms and combine them again at a different place? image
Leave your comments in the comments section below!
  • skspurling
    skspurling over 9 years ago +7
    It's called an airplane.... ;-)
    dougw over 9 years ago +4
    It is a mind boggling exercise to even quantify the problem. There are 7 x 10 to the 27th power atoms in a human. One issue of many is you need a machine that can record the type of atom, its state and…
  • ntewinkel
    ntewinkel over 9 years ago in reply to e14phil +4
    Interesting concepts One other thing that comes to mind is that we would need to figure out the differences between a living pile of atoms and a non-living one. For example, what makes a living creature…
  • rsc
    rsc over 9 years ago
    Yes, Dixon,
    Both nuclear fisson and fusion can be done, I don't think it's been done with the same material because there is not a way to capture it.
    There are 7 x 10 to the 27th power atoms in a human. One issue of many is you need a machine that can record the type of atom, its state and its location with atomic precision of all these atoms at exactly the same time.
    To provide some perspective, all the data on all google servers combined is less than 10 to the 19th power bytes - not even close to enough to capture the state of one human.
    Transmitting this amount of data at the fastest known speeds might take longer than the universe has been in existence.
    The closest thing we could attempt in the foreseeable future is growing a clone from DNA. Incidentally DNA is a promising way to store vast amounts of data.
    DAB over 9 years ago
    Unfortunately, there are fatal flaws in the idea.
    While it might be possible one day to deconstruct every atom in  person and then reassemble them in correct order, it would be nearly impossible to capture all of the metadata within the body that makes you, you.
    You not only need the correct atoms, but you also need the precise number of photons around the atom to capture the exact state of each atom.
    The complexity of nearly every living thing is more than just its collection of atoms.  There are genetic constructs within those atoms that keep the object functioning.  Since we do not know how any of those things works, then reconstructing the exact state of the array of atoms become moot.
    The other issue is moral.  You essentially have to kill yourself to transport and recreate yourself somewhere else.  It is a suicide and resurrection conundrum.  Even if you can do it, should you?
    That added to the other issue of reliability of information and state transfer makes such a process extremely hazardous.
    As Douglas pointed out, that is a lot of data to transfer.  Even a one part per billion error rate would leave serious flaws in the copy.
    Think about all of the errors you get everyday in web searches.  Then extrapolate that into people transfers.  Are you really prepared to live with the consequences?
    dougw over 9 years ago in reply to DAB
    Yes, I didn't get into the state of each atom, but it is quite conceivable that the structure and state of all the subatomic particles in every single atom could individually take more data to accurately describe than what is stored on all the google servers right now. Each quark could be like an entire universe - we essentially have no knowledge at this level.
    DAB over 9 years ago in reply to dougw
    Don't get me started about those imaginary particles. image
    Even with my simple atomic model, the details are immense.  So if I am wrong and atoms are even more complex, well it just goes for bad to worse.
    mcb1 over 9 years ago
    I think the answer is NO.
    Very interesting DAB  and dougw
  • skspurling
    • Vote Up +7 Vote Down
  • dr-jhc
    dr-jhc over 9 years ago
    It can be done... but only if you don't care where every particle is transported to, or don't care if you make a good approximation to the original item.
    Heisenberg's uncertainty principle will get you every time: you can know exactly where something is, but have no idea about its energy; or you can know exactly its energy but have no idea where it is.
    Even if you could get around this, how fast can you measure, teleport and reconstruct all the particles? Everything is in constant motion so best case you would end up with some fuzzy, out-of-focus copy of the original.
  • dixonselvan
    dixonselvan over 9 years ago in reply to rsc
    Thank you rsc
  • dixonselvan
    dixonselvan over 9 years ago in reply to dougw
    Thank you dougw for your numerical statistical explanation about atoms and storage needed to store data.
    Cloning DNA! I have heard cloning human parts like ear, nose but this is new to hear. Thanks again.
    Is the below is what you are referring to by cloning DNA? dougw
    Dixon Selvan
