Arduino
Arduino
Documents Arduino UNO Click Boards
  • Author Author: pchan
  • Date Created: 6 Feb 2015 5:28 PM Date Created
  • Last Updated Last Updated: 1 Nov 2016 9:19 PM
  • Views 1450 views
Start with the Arduino UNO Click Shield Adapter Boardimage
Buy NowBuy Now
The Arduino Uno Click Shield extends your Arduino Uno and any other Arduino-compatible board. It's a simple shield with two mikroBUSTm host sockets that allow you to connect more than 75 different types of MikroElektronika Click boards to the Arduino for features like:
Tech Specs image
Now Available!  Add on Click Boards
Bluetooth Click
BuyBuyMore Info image
Thermo Click
SHT11 Click
Analog to Digital (ADC) Click
BEE Click
GPS Click L10
GSM Click
Click boards are plug-and-play modules designed to add extra functionality to existing development kits.  These small, function-specific add-on boards/modules all have a common interface to the mikroBUSTm adapter board.  Multiple Click boards can also be used simultaneously to enable many features to be implemented at the same time.  These Click boards offer a dual power design, 3.3V and 5V, taking the issue of power supply out of the equation.
There are over 70 Click Boards available allowing developers to easily implement features such as Bluetooth, temperature sensing, humidity sensing and analog-to-digital conversion.  Here’s four we’re featuring now – check back for updates as we add more Click Boards to the list!
Buy NowBuy Now
Bluetooth Click
image  Fully certified Class 1 Bluetooth 2.1 + EDR module
image  Bluetooth SIG qualified
image  UART (SPP or HCI) and USB (HCI only) data connection hardware interfaces
image  Supports Bluetooth data link to iPhone/iPad/iPod Touch
Tech Specs image
Buy NowBuy Now
Thermo Click
image  Cold-Junction Compensation
image  14-Bit, 0.25°C Resolution
image  Simple SPI-Compatible Interface (read-Only)
image  Detects Thermocouple Shorts to GND or VCC
Tech Specs image
Buy NowBuy Now
SHT11 Click
image  Temperature can be represented in 12-bit or 14-bit format in operating range from -40 to +100°C with accuracy of +/-0.5°C at room temperature
image  Humidity can be represented in 8-bit or 12-bit resolution with +/-3% accuracy
image  Typical standby, 400nA max
Tech Specs image
Buy NowBuy Now
image  12 bit ADC converter (Microchip MCP3204)
image  Up to 50k samples per second
image  4 input channels
Tech Specs image
Buy NowBuy Now
BEE Click
image  2.4GHz IEEE 802.15.4 Transceiver module supports ZigBeeTm, MiWiTm, and MiWi P2P protocols
image  FCC (USA), IC (Canade), ETSI (Europe) Certified
image  Integrated PCB Antenna with simple four-wire SPI interface to PICRegistered microcontroller
image  Low current consumption (Tx 23mA, Rx 19mA, Sleep 2uA)
image  Hardware CSMA-CA Mechanism
image  Automatic ACK response
image  Hardware security engine (AES-128)
Learn More image
Buy NowBuy Now
GPS Click L10
image  210 PRN channels
image  66 search channels
image  22 simultaneous tracking channels
image  -165dBm tracking sensitivity
image  Highest autonomous mode acquisition sensitivity, -148dBm
image  Low tracking power consumption, 38mA (passive antenna)
image  Up to 5Hz update rate
image  Embedded with one 4Mbits flash memory
Learn More image
Buy NowBuy Now
GSM Click
image  Supports GSM/GPRS protocol stack 3GPP
image  Supports GSM/GPRS 850/900/1800/ 1900 MHz Quad-band frequency
image  On-board antenna connector
image  3.5mm quadrupole earphone/microphone jack
image  SIM card socket integrated at the bottom side of the board
image  Easy integration with mikroBUSTm form factor
image  Supported in all mikroElektronika compilers
Tech Specs image
Other Accessories to Extend your Arduino UNO's Features
Buy NowBuy Now
4.3" LCD Module and Adapter Board
image  TFT-LCD Module with 16/24-bit RGB parallel conversion board
image  TSC2046 chip for touch functionality
image  3.3V regulation chip with I2C control capability and PWM backlight
image  Supports 16- and 24-bit driving modes for LCD displays
image  4-wire SPI resistive touch screen
Tech Specs image
Buy NowBuy Now
WiFi Dongle
Adding WiFi to your board is as simple as plugging in this dongle into a USB port.
image  Uses latest 802.11n technology
image  Supports data rates up to 150Mbps
image  Supports wireless roaming
Tech Specs image
What Software Works with Click Boards?
µC/Probe Tm Graphical Live WatchTm
Micrium’s µC/Probe is a Windows application that allows you to read and write the memory of any embedded target processor during run-time, and map those values to a set of virtual controls and indicators placed on a graphical dashboard.
Absolutely no programming is required – simply drag and drop the graphic components into place, and watch them go.
This software is a must-have runtime agnostic tool to display and control just about any I/O variable in a target system thru rich graphical objects on the host computer. No code on target needed when using JLINK or select JTAG interfaces.  Tech Specs image
  • boards
  • click
  • adapter
  • uno
  • shield
    Like the information
