Arduino
Arduino
Documents Arduino Projects for Arduino Day 2019:  Arduino MKR Projects in the Cloud!
  • Date Created: 7 Mar 2019 7:06 PM Date Created
  • Last Updated Last Updated: 16 Mar 2019 1:19 AM
  • Views 4456 views
  • Likes 15 likes
  • Comments 17 comments
Arduino Home
An Open-Source platform to create digital devices and interactive objects that sense and control physical devices.
Arduino Tutorials
Arduino Projects
We'll be sending out a limited number of Arduino MKR 1010 boards for your Arduino IoT in the Cloud project proposals!
In the comments below let us know what Cloud project you'll be working on in honor of Arduino Day 2019!
Last year, Arduino was celebrated on May 12th, 2018 and we decided to celebrate the first birthday of Project14  by celebrating the birthday of Arduino  with an Open Arduino competion in Project14 | The Birthday Special: Arduino Projects for Arduino Day!   It was so much fun we have decided to do something similar but with a twist. We'll be using Arduino Day to encourage you to use the build cloud based projects with MKR boards using Arduino IoT Cloud as the cloud service provider.
You can also free to create whatever Arduino cloud based projects you want by visiting IoT: In the Cloud !  The challenge will be to submit a project that makes use of a wireless technology and a cloud provider (Arduino IoT Cloud, AWS, Google Cloud, io.adafruit, etc). Projects could include cloud connected home security system, Environmental monitoring (Temp, humidity, air quality etc), Industrial data logger with online data logging, baggage tracker utilising GPS and Sigfox network, Smart garage door opener, Energy monitoring, and more.   While you can use any component you choose with any cloud provider, we hope that some of you will use this opportunity to demonstrate what's possible with an MKR board and the Arduino IoT cloud platform    The competition will launched on March 14th, two days prior to Arduino Day on March 16th, 2019.
You are free to post the project in IoT: In the Cloud , Arduino Projects ,  or your community blog by using the tag iotcloudch
Tag your project arduinoday2019ch to have it featured in Arduino !
Visit our IoT essentials series to explore further possibilities for your IoT cloud projects:
  • The Industrial Internet of Things
  • IoT II LoRaWAN for Internet of Things Applications
  • Internet of Things Security
Visit for details & to enter your project:  IoT: In the Cloud
The Prizes
The Grand Prize
The Grand Prize
(2) Arduino MKR WAN 1300 Board + (1) Arduino MKR Relay Proto Shield
A Compatible LoRa Gateway *
* Arduino Pro LoRa Gateway, 8 x LoRaWAN Channels, 868MHz, IoT Development (Outside of the US) / TTN-GW-915TTN-GW-915 -  Network Gateway, The Things Network, LoRaWAN, IoT Development, US Only (915MHz)
3 First Place Winners
Arduino MKR GSM 1400 + (MKR CAN Shield +  MKR RS 485 Shield +  MKR ETH Shield) Combo
Plus a $100 Shopping Cart
Arduino GSM 1400 Board + a Shield Combo (MKR CAN, MKR RS-485, MKR ETH) + a $100 Shopping Cart
Getting Started with Arduino IoT Cloud
While you are free to use any hardware components or cloud provider you like for the upcoming Project14 competition,  IoT: in the Cloud, there are several reasons you might consider using the combination of an MKR board and the Arduino IoT Cloud service to connect the cloud to the world around you.  You can use Arduino IoT  Cloud to log, graph, and analyze sensor data, trigger data, and home automation.  It offers an easy platform for beginners and its ideal for rapid prototyping for professionals.  You can quickly build remote sensor monitoring using widgets and connect to a spreadsheet, database, or automate alerts using webhooks.  Devices are secured using X 509 certificate-based authentication, developers can create custom apps using Arduino IoT Cloud APIs, and its based on open hardware and open IoT standards.
The following video shows how you can get up and running in no time at all:
Sign up to Arduino IoT cloud at https://auth.arduino.cc/register :
or login if you have an account or use your google account:
You'll find a step-by-step tutorial as well as an FAQ.  Currently, Arduino IoT Cloud only supports the MKR 1000, MKR WiFi 1010 and the MKR GSM 1400 boards.  In the future the MKR VIDOR 4000 and Arduino Uno boards will also be supported.  Next click on "New Thing" and select the board you wish to use to configure:
You'll need to download and install a plugin onto your computer, connect your board via USB, give it a name, and then configure your board. Arduino IoT Cloud is currently in the public beta stage. We welcome feedback on what you like and what you don’t!
Arduino IoT Cloud Components
Based on what the user wants to achieve, an IoT application will require a few basic components:
  • Devices to collect data or control something (the hardware you want to use);
  • Software to define the behavior of the hardware (code such as an Arduino Sketch)
  • A Cloud application to store data, or remotely control the equipment. (cloud service provider
Arduino IoT Cloud Properties
Devices such as the MKR 1010 board use software (eg. Sketches) to run software, read sensors, control actuators, an communicate with the Arduino IoT Cloud.  The "thing" in Internet of things refers to a collection of properties such as temperature or light and not the hardware itself.   A thing is the logical representation of a connected object.  Properties are the qualities defining the characteristics of a system. A property can be something like a 'read-only' (RO) setting to indicate the Arduino IoT Cloud can read the data, but cannot change the value of the property. A property might be designed as 'read and write' (RW) if the Arduino IoT Cloud can also remotely change the property’s value and send an event notification to the device.
For example, a device might have a sensor which will provide the room temperature. That would be read-only. It might also include a thermostat to be able which will change the room’s temperature.
PropertyTypeValuePermission
ROOM_TEMPERATURETEMP (F)64RO
DESIRED_TEMPERATURETEMP (F)69RW
Arduino IoT Cloud Events
The Arduino IoT Cloud becomes aware of events when it receives application messages that indicate the something has happened. For example, it might be informed by a face-recognition application that someone is at a door, or it has received a request from another app that light has to be turned on.
Software for Arduino IoT Cloud
If you're familiar with Arduino then you are aware of how Sketches work.  When you create a "sketch" it is processed and compiled to machine language. Sketches are basically a simplified version of C/C++.   What Arduino IoT Cloud does it will quickly
and automatically generate a Sketch when setting up a new thing. Arduino IoT Cloud allows other methods o interaction, including HTTP REST API, MQTT, Command-Line Tools, Javascript, and Websockets.
You can get started using the Arduino IoT Cloud at the following location: https://create.arduino.cc/projecthub/133030/iot-cloud-getting-started-c93255
Arduino MKR Boards:
Product NameQuantity
Arduino MKR WiFi 1010 Development Board *1Buy NowBuy Now
Arduino MKR WAN 1300 Development Board ***1Buy NowBuy Now
Arduino MKR GSM 1400 Development Board *1Buy NowBuy Now
Arduino MKR VIDOR 4000 Development Board **1Buy NowBuy Now
* - Supported with Arduino IoT Cloud
** - Support coming for Arduino IoT Cloud
*** - Not supported
Arduino Lora Gateway:
Arduino Lora Gateway Pro *1Buy NowBuy Now
* - only available in Europe
Arduino MKR Shields:
Arduino MKR SD Proto Shield
1Buy NowBuy Now
Arduino MKR CAN Shield
1Buy NowBuy Now
1Buy NowBuy Now
Arduino MKR Connector Carrier
1Buy NowBuy Now
Arduino MKR MEM Shield
1Buy NowBuy Now
Arduino MKR 485 Shield
1Buy NowBuy Now
Arduino MKR ETH Shield1Buy NowBuy Now
Arduino MKR Proto Shield1Buy NowBuy Now
Arduino MKR Proto Large Shield1Buy NowBuy Now
Arduino MKR Kits:
Arduino MKR 1000 IoT Bundle1Buy NowBuy Now
Arduino Engineering Kit1Buy NowBuy Now
  • arduinoday2019
    balearicdynamics over 7 years ago +10
    Hi Tariq tariq.ahmad this idea sounds really good So, I try to explain in a few words the project below An image sometimes is better than a thousand words. Next April, 5 together with the other artist…
  • swathic
    swathic over 7 years ago +9
    I would like to create a Incubator Environment Monitoring device for our college Laboratory with the Arduino MKR 1010 Boards and monitor the status in Arduino IoT cloud. Incubators are mostly used to grow…
  • ntewinkel
    ntewinkel over 7 years ago +7
    Hey that's interesting! I wasn't aware of the Arduino IoT cloud, but it sounds like it could save me a lot of effort. So far I've been rolling my own cloud services in php, which takes some effort, but…
  • carmelito
    carmelito over 7 years ago
    Thank you element14 team, I received my MKR1010 yesterday after my building manager decide to call me, to say that I have a package to collect.. I have been waiting to try out a couple of LoRa breakouts boards, I purchased about a month ago, so this should be a good opportunity to hook up one of the breakouts to MKR1010 to send data to a cloud platform, not sure which one I should go with image , to many cloud'dy options to choose from image..
    -Carmelito
  • petersmith69
    petersmith69 over 7 years ago
    Above threads are quite helpful.I feel so lucky being a part of this forum.Also i was completed one of my project with the help of this thread. so a special thanks to each and every person providing this information.
  • jomoenginer
    jomoenginer over 7 years ago
    Okay, I got the nudge by receiving a MKR1010, a pair of earbuds, some stickers and a post card to add a Thing to the IoT: in the Cloud Projects.  Thank you!
    Earlier, I had already started a Robot Arm made from Foam Board using an MKR1000 sitting on top of a MKR2UNO Board which I had receive previously and a Make Motor Controller I had sittin' around. Adding to this is a MKR1010 with a the MKR Relay Proto Shield  and a MKR MEM Shield to control a Conveyor Belt I have yet to build.  The intention is to use the Arduino IoT Cloud tool to control the Robot ARM and Conveyor Belt as in a production environment to move widgets.  The new MKR1010 will be added somewhere.
    Here is the collection of stuff:
    Thing 1 in the Arduino IoT Cloud has already been created
    On to Bloggin'
  • rsc
    rsc over 7 years ago
    I just got back from two weeks in the Magellan Straits, but since you sent me this cool board, I'll try and come up with a project.
    Scott
  • ntewinkel
    ntewinkel over 7 years ago in reply to ntewinkel
    Ooh! cool! I received a care package from element14 today too!
    It includes the Arduino MKR 1010 to try out the Arduino IoT cloud image
    Thank you, good peoples of the element14 team!
    -Nico
  • paj
    paj over 7 years ago
    Hi,
    i was thinking about a simple device to monitor the activity levels of recently rehabilitated people who live alone and do not have a care giver to assist them. Using the cloud would mean That the output of the device could easily be monitored by a health centre who could contact the patient and send someone to assist if necessary. It would need to be low cost so that it would be readily adopted and reliable. The MKR 1010 would seem to fit the bill. The lorawan board also seems like a good way to send data but I know nothing at all about how to set up a Lora gateway or even if it is feasible to use it this so this would be a steep learning curve.
    i need to think some more about how to measure vital signs of patients without being too intrusive.
    PAJ
  • ntewinkel
    ntewinkel over 7 years ago in reply to Jan Cumps
    Jan said:
    >Finally an MQTT example with security built in from the start.
    I noticed that too - it has a built in "Cryptochip". That's leaps and bounds forward compared to my current cheapo go-to option.
    (https://store.arduino.cc/usa/mkr-wifi-1010 )
    Which I guess also explains why the Arduino IoT cloud only supports the 3 Arduino MKR boards.
    Cheers,
    -Nico
  • 14rhb
    14rhb over 7 years ago
    Thanks to the Element14 Team: I missed the UPS delivery yesterday so picked up this mystery package today from a local depot image
    The board is a very nice Arduino MKR1010WAN
    Rod
    Jan Cumps over 7 years ago in reply to Jan Cumps
    I'm impressed by the AWS example for the Adrduino MKR. Finally an MQTT example with security built in from the start.
    https://create.arduino.cc/projecthub/Arduino_Genuino/securely-connecting-an-arduino-mkr-wifi-1010-to-aws-iot-core-a9f365…
    It uses SSL and certificates to connect safely to AWS IOT's MQTT sevice.
    Sending a message:
    And a message back from AWS:
  • aabhas
    aabhas over 7 years ago
    Hi all
    Thanks tariq.ahmad for organizing such a contest for celebration of Arduino day , I am also very excited to take part in the contest and be a part of Arduino Day 2019 celebration.
    I am interested in making a system to keep a track of few important things that we generally tend to misplace inside our houses and then go mad searching them , so I was thinking  of making this using arduino mkr1010 , few radio frequency modules and esp device and buzzers , which would not only help you locate where you have kept your things if connected to internet by ringing the buzzer and even show you the most probable area where you might have kept your device by showing the if the device is in the riegon  of radio frequency modules.It would even keep a track of wherever you keep your things and store it over cloud so you can get to know the probable area you have kept. Along with ringing your device over internet and showing you it is in which reigon of radio frequency it would also notify on your phone and you can always access it on cloud.
    Thanks
    Aabhas Senapati
