Arduino
Arduino
Documents The Radio Bit for littleBits
  • Date Created: 26 Aug 2015 12:32 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 8:41 PM
  • Views 1067 views
1. Info
Music is in the air with the Radio Bit! Make your own wakeup radio! Auto search for radio stations or tune for channels manual. With the different modes everything is possible. The Bit can be used stand alone(only needs a power bit) or in combination with other Bits.  The Bit also has a headphone connector which volume is adjustable! When connected to e.g. a headphone this will also serve as an antenna. You can also extend the antenna by using the antenna connector. In case of auto search, build-in memory will store the radio station when unpowered.
for pictures and more info visit my website: Radio Bit - PV-Productions
Mode 1: Auto search
Left button on Bit: Scan backwards Middle Button on Bit: Scan forward Right button on Bit: Next mode LittleBits input: Scan forward
Mode 2: Auto search extended
Left button on Bit: Scan backwards Middle Button on Bit: Scan forward Right button on Bit: Next mode LittleBits input: Mute/unmute (Think of projects making your own wakeup radio etc.)
Mode 3: Manual tuning
Left button on Bit: Mute/unmute Middle Button on Bit: Mute/unmute Right button on Bit: Next mode LittleBits input: Scan through Radio stations  If you have suggestions or ideas please put it in a comment below.  I hope you like it. I know Henry does;)
2. Article
Atmel.comGive Philip Verbeek a bunch of LEGO blocks, a handful of littleBits, an MCU and a challenge, and there’s no over-the-top creation that the Maker can’t bring to life. We are sure you will love his latest piece of work: Henry the LEGO Radio.Click here to read the full article.
  • bit
  • LEGO
  • radio
  • littlebits
  • ipv1
    ipv1 over 11 years ago
    Thats pretty cool.
    DAB over 11 years ago
    Very cool project.
    Very well done and intriguing project !
    Why not adding RDS decoding ?
    Nice nice nice image
    Enrico
