Avnet Boards General ZEDBOARD Bootabale System
  • Subscribers 371 subscribers
  • Views 356 views
  • Using Xilinx Tools
  • ZedBoard General Questions
  • Zedboard Hardware Design
  • Software Application Development
  • Ultrazed Hardware Design
  • Zedboard Training
upadhyay_h
upadhyay_h over 6 years ago
Hii,
I'm designing with Zedboard. and with zedboard normally we create bit file + elf file and it's stored in ROM and we run. but shall we create a bootable system without os ?? is it possible ?
and 2nd thing
is it compatible with 100mhz sample ADC ?
  • drozwood90
    drozwood90 over 6 years ago +1
    Hi there, You can create a bare metal or standalone design. It would be compatible with whatever you want to design into it. If you have an ADC attached, you can certainly do that. However, it is on you…
  • drozwood90
    Hi there,
    You can create a bare metal or standalone design.  It would be compatible with whatever you want to design into it.  If you have an ADC attached, you can certainly do that.  However, it is on you to generate it - where the PetaLinux might have a driver.
    --Dan
