Avnet Boards General Network FMC Module to 1Giga compatibility with ZedBoard
  • Subscribers 372 subscribers
  • Views 887 views
  • zedboard
  • ethernet
  • 1giga
  • auto-negotiation
  • vhdl
  • designed by avnet
vlira
vlira over 5 years ago
Hello all,
I am using the FMC NETWORK - Avnet module on the zedboard to make an ethernet communication between the zedboard and a PC. For company requirements, I use the PL part of Zedboard with an IP MAC. For a speed of 10 / 100M the design has been validated, it works perfectly well. However, when I try to switch to 1Gbit in the same design without autonegotiation, between the phys (FMC module / PC) there is no activity. When I try to communicate with auto-negotiation, the auto-negotiation status is completed for 1Giga but I always find an error in fcs.
Ps: I use a CAT6 cable and the two phys are configured for 1Giga or for autonegotiation (FMC module / PC), we have no interoperability errors between them. I thought about a skew error but I don't see any difference when I change the skew to RX_Data and Rx_Clk. Could you help me?
https://www.avnet.com/opasdata/d120001/medias/docus/189/AES-FMC-NETW1-G-Hardware-Design-Guide.pdf
Thank you in advance for your attention.
  • zedhed
    zedhed over 5 years ago
    Hello vlira
    I don't know of any testing that was done with ZedBoard, almost all of our testing here was done on the UltraZed-EG PCIe Carrier Card but I don't see any reason why it could not also be made to work with ZedBoard as well.
    Can you tell us more about your design?  What have you implemented so far?  Are you using the Zynq-7000 GEM from the PS side or are you using a PL based Ethernet IP such as the Tri-Mode Ethernet MAC (TEMAC)?
    Tri-Mode Ethernet MAC v9.0 LogiCORE IP Product Guide (xilinx.com)
    Best Regards,
    -Kevin
