Avnet Boards General FMC Spacer Set
  • Subscribers 372 subscribers
  • Views 386 views
FMC Spacer Set
I would like to know if there is a mating connector for the FMC connector on the ZedBoard that can give a board-to-board spacing of 14mm or more?
The connector P/N on the ZedBoard is ASP-134603-1.
Anyone seen something like this?
    http://www.samtec.com/ftppub/pdf/seam.pdf
    ASP-134603-1 is the same as SEAF-40-06.5-10-A.  From the mated heights table in the SEAM datasheet, you can use SEAM-40-09.0-10-A for a 15.5mm stack height or SEAM-40-11.0-10-A for 17.5mm.
