Avnet Boards General Virtual ComPort absent when ZedBoard is off
  • Subscribers 371 subscribers
  • Views 273 views
ejubenville
ejubenville over 13 years ago
I don't understand something fundamental about ZedBoard communications via the Cypress USB virtual comport.  When the ZedBoard is off, the virtual comport does not exist.  The comport shows up when the board is turned on and the USB controller enumerates the device.
The Speedway video training and lab 1.3 for implementing Linux on the Zynq instructs me to use Tera Term and already have a connection to the comport up when I turn on the ZedBoard.  How can this work?  I'm using a different terminal emulator (PuTTY) and it disconnects when power goes off, and won't allow a reconnection until the board is turned back on.  Does Tera Term operate differently, and reopen the port auto-magically after the connection was broken with a power-down?
This seems like a general race condition.  To capture all of the serial data emitted during boot, the connection needs to be made instantly after turning power on.  Am I missing something?
  • bhfletcher
    0 bhfletcher over 13 years ago
    This is actually a feature of the Cypress USB-UART driver, not TeraTerm. I just tried it successfully with PuTTY. Here's how it works:
    1.   Make sure you've downloaded the latest driver (http://www.cypress.com/?mpn=CY7C64225-28PVXC)
    2.   Plug cable between PC and ZedBoard
    3.   Power on ZedBoard
    4.   Virtual COM port will enumerate, and you can see the COM assignment in Device Manager --> Ports
    5.   Update to the latest driver that was previously downloaded
    6.   Open PuTTY or TeraTerm or any terminal program and connect to the assigned COM port. Leave it connected.
    7.   Power down ZedBoard. You'll hear the PC beep indicating a disconnection, but if you look in Device Manager, your Cypress USB-UART COM is still there.
    8.   Power the ZedBoard back on, and you'll find that you are automatically reconnected.
    Bryan
