Avnet Boards General Zedboard power problem
  • Subscribers 371 subscribers
  • Views 269 views
Hi all
I was doing "hellow world" lab
suddenly power disappear.
Although power cable was plugged and switch was ON, board didn't have power.
Does anyone knows what this problem is?
  • bhfletcher
    0 bhfletcher over 13 years ago
    On very rare occasions, we saw cases where the power switch went bad or had material from manufacturing lodged in it. You can try toggling the power switch back and forth several times. Use a voltmeter to see if you are getting 12V on the opposite side of the switch. Otherwise, you will need to work out an RMA from wherever you purchased the board.
    Bryan
