Avnet Boards General Cypress- USB2UART Driver Problem
  • Subscribers 372 subscribers
  • Views 608 views
I have 2 new ZED-Boards but I can't connect them to my PC, because during power up the driver installation failed. On the boards itself everything is OK. It is even not possible to connect to cypress homepage and download the driver manually.
When I try this link
https://secure.cypress.com/?mpn=CY7C64225-28PVXC
I got this error
sec_error_revoked_certificate
All other links and trials end in the same error message.
Does anyone have an idea?
Thomas
(Winwows 7, 64Bit)
  • bhfletcher
    0 bhfletcher over 12 years ago
    I have the same problem. I have created a temporary link, good for 3 days. Please use this for now while I contact Cypress to see what the problem is.
    https://avnet.egnyte.com/h-s/20130916/7344cd76af6240e1
    Will you please report back if this works or not?
    Bryan
    I've run the install at the link above but still don't see the drivers in the device manager.  Any ideas?
  • bhfletcher
    0 bhfletcher over 12 years ago in reply to e14 Contributor
    After you install the drivers, then plug in the ZedBoard USB-UART and power it on. When the New Device Wizard comes up in Windows, point it to the newly installed driver.
    Bryan
    0 e14 Contributor over 12 years ago in reply to bhfletcher
    Hi Bryan, I solved my problem with the missing USB2UART driver. I register at cypress on my home PC (which was no problem). After that, i could download the driver file from the cypress site without anymore problems.
    I install the driver using the device manager.
    Thanks for your reply
    Thomas
    Thanks Bryan
