Avnet Boards General ZEDBoard with baseband DAC using FMC
  • Subscribers 373 subscribers
  • Views 317 views
Are there any DAC cards that can connect to a ZEDBoard using the FMC interface and work at the baseband? I am not looking for an RF solution just a DAC board that will produce a baseband signal.
Thanks in advance
    Can you narrow down your requirements so that we might suggest the appropriate Avnet solution?
    u2022tAnalog bandwidth           ____ MHz
    u2022tSampling rate              ____ MSPS
    otLVDS or JESD204B ?
    u2022tPreferred tool flow (select all that apply)
    otMATLAB / Simulink
    otHDL
    otSoftware-based
    uF0A7tANSI C / C++
    uF0A7tHLS targeting hardware
    uF0A7tSDSoC
    otOther ___
