Avnet Boards General 'Hello world' SDK running problem
  • Subscribers 373 subscribers
  • Views 453 views
Hi! I did 'getting started guide' and it worked well. I could use tera term to control led lights on board. But when I follow CTT v14.6 do JTAG on SDK, it doesn't work. When running  'run configuration' it appears 'Error Launching Problem' which says 'Unable to connect to Ps7_cortexa9'. I have imported ZC702 board template file in XPS and try many times as CTT says but still doesn't work. Do anyone know this problem? Waiting for your answer! Thanks!
    If you are targeting the ZedBoard you need to use a version of the CTT designed for the ZedBoard and not the ZC702 evaluation board. In the Zedboard version you will load the ZedBoard template. The ZedBoard versions of the CTT are posted here:
    http://www.zedboard.org/design/1521/11
    -Gary
    I have the same problem doing exactly the same thing as in the tutorial. I use the Zedboard card and set exactly the same setting and I have this error. I'm working on Windows xp with Vivado 2013.2 + SDK.
    Thanks for your help,
    Jerome.
    That's working now, I do nothing especially... just run again and again. Strange software...
