Avnet Boards General MicroZed and Mathworks
  • Subscribers 374 subscribers
  • Views 823 views
I have a general question concerning the MicroZed. At the moment I am using the Zedboard and Mathworks Workflow Advisor to program the Zynq. Is the Mathworks Software also compatible with the MicroZed?
Thanks in advance.
  • raunaq
    raunaq over 9 years ago +1
    Did that work for you using those instructions given in the MATLAB page? It would be great to have a default plugin published by Avnet.
  • mbrown
    0 mbrown over 9 years ago
    Yes, Xilinx Zynq Support from MATLAB and Simulink works on MicroZed. Although they do not have a plugin published for MicroZed, you can quickly create your own. See the link below:
    Supported Zynq platforms -- https://www.mathworks.com/hardware-support/zynq.html
    Make your own plugin -- https://www.mathworks.com/help/hdlcoder/examples/define-and-register-custom-board-and-reference-design-for-soc-workflow.html
    /Matt
  • raunaq
    0 raunaq over 9 years ago
  • htkim40
    0 htkim40 over 9 years ago
    Hi, is there an example where someone has anyone successfully created a microzed plugin for matlab? I can't seem to find much support for microzed.
  • htkim40
    0 htkim40 over 9 years ago in reply to htkim40
    Go to https://github.com/mathworks/buildroot and clone the mathworks buildroot directory. Create a new catalog file based on the zedboard (microzed and zedboard have the same DTS apparently) inside buildroot/board/mathworks/zynq/boards called microzed. run the following command in a linux terminal:
    python build.py -b microzed -p zynq
    This should build the kernel and output it into a directory inside buildroot/output/<boardname>_linux_xilinx/images . Look inside for <boardname>_sdcard_zynq7000ec_<date>.zip  . This contains all the stuff that shold go inside your sd card.
