Avnet Boards General SPI stand alone example
  • Subscribers 375 subscribers
  • Views 1153 views
I look for simple tutorial on SPI for stand alone project to test my LCD init., so far I only found this
Xillinx/SDK/2014.4/data/embeddedsw/XilinxProcessorIPLib/drivers/spips_v1_06_a
any other simple tutorial for SPI on zedboard ?
    Hello Ahmad,
    If you are looking for an example that uses the Zynq PS based SPI controller take a look at the Maxim reference design for their Santa Fe AFE PMOD. It has code to control the PS SPI interface:
    https://www.maximintegrated.com/en/design/reference-design-center/system-board/5561.html/tb_tab2
    -Gary
  • antony.kobin
    0 antony.kobin over 9 years ago
    hi dear guys
    I tried to setup PL SPI for z7020 chip ( xc7z020clg400-3 ) but it Does not work
    this is my setup in pl
    what did mean the not in this ip setting ? i find the .xdc file but i can not use this command because occur an error when i run the "create_generated_clock -name clk_sck -source [get_pins -hierarchical *axi_quad_spi_1/ext_spi_clk] [get_ports <SCK_IO>] -edges {3 5 7}" command
    Have I done something wrong?
    i skip this step and configure the spi in ps and test it but  it dose not work
    this is my stand alone code for set up spi
     XSpiConfig=XSpi_LookupConfig(XPAR_AXI_QUAD_SPI_0_DEVICE_ID);
     SPI_Status=XSpi_CfgInitialize(&XSpi,XSpiConfig,XSpiConfig->BaseAddress);
    XSpi_Start(&XSpi);
    XSpi_Transfer(&XSpi,&sendbufPtr,&recvbufPtr,bytCuont);
    Can any one help me ?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Antony,
    We are currently in the process of releasing a PL SPI Controller baremetal reference design. I will respond back when we have released it.
    --Josh
  • marcomercuri85
    0 marcomercuri85 over 9 years ago in reply to jafoste4
    Hi Josh,
    could you please notify me when the design is available?
    Thanks.
    Best Regards,
    Marco
  • jafoste4
    Hi Marco,
    The designs have been released, please look under the reference design sections for either MicroZed/PicoZed. You will find two new bare metal SPI designs and two new bare metal I2C designs.
    --Josh
