Avnet Boards General ZynqSW Lab 08 Project Management Can't Export Run and Debug Configurations
  • Subscribers 373 subscribers
  • Views 760 views
rivey30
rivey30 over 8 years ago
I am working through the ZyncSW labs and in Lab08, step 4, the tutorial asks to store the Run and Debug Configurations that were "previously created.
After selecting file-> Export and Run/Debug -> Launch configurations then clicking next, and creating the C:/Speedway/ZynqSW/2016.2/Lab08_config_export folder and selecting all the configurations the Finish button is still greyed out.
What is missing to enable this?
  • jafoste4
    0 jafoste4 over 8 years ago
    What Vivado version are you using and what Speedway are you going through?
    If the finished button is greyed out that means you did not select a debug configuration. If that is the case do go through the debug/run section in the lab correctly where you setup your run/debug configurations. Please double check this.
    Also please ensure that you are using the correct Vivado/SDK version for the speedway material you are going through.
    --Josh
