Avnet Boards General Easiest Way to Load Debian Linux on a Microzed XC7Z010
  • Subscribers 373 subscribers
  • Views 1090 views
pejmon
pejmon over 8 years ago
I need a Linux OS on my Microzed that has "apt-get", not "rpm" or "yum" (I know there are equivalents). What is the easiest way to find, and load a prebuilt Debian OS onto my MicroZed Zynq XC7Z010?
Thank you,
Alex
  • jafoste4
    0 jafoste4 over 8 years ago
    Take a look at these posts
    http://zedboard.org/content/installing-linux-zedboard
    https://forums.xilinx.com/t5/Embedded-Linux/Debian-on-MicroZed/td-p/554048
    --Josh
  • pejmon
    0 pejmon over 8 years ago in reply to jafoste4
    Thank you, I was able to get Xillinux running on my board. I now want to output SPI communication to my ADC chip (AD7771BCPZ) on a AD777xFMCZ eval board. I know I probably should use the PMOD port. But I don't see anything like /dev/pmod or anything like that listed. I've looked at some tutorials, but I havent found anything helpful. How do I configure the PMOD to write and receive SPI messages?
    Thank you,
    Alex
  • jafoste4
    Hi Alex,
    Take a look at tutorial 06 and 07 here http://zedboard.org/support/design/1519/10
    In these tutorials it shows how to hook up SPI Pmods to the PMOD ports on MicroZed using Vivado.
    --Josh
  • pejmon
    Thank you! Follow up question: What's the highest sampling rate the XC7010 could achieve? I'm trying to sample from an ADC chip at a rate of around 200k - 400k samples per second. Is that possible not using the FPGA?
