Avnet Boards General How to begin with AD-FMCOMMS2-EBZ
  • Subscribers 374 subscribers
  • Views 299 views
I'm a beginner with ZedBoard and I'm studying about module AD-FMCOMMS2-EBZ, I'm following the instruction of ADI on https://wiki.analog.com/resources/fpga/docs/hdl ,session "Building on Vivado",to Build library HDL on VIVADO 14.4.1, but when i open Vivado, type the command in TCL console  :"cd C:Doan2hdl-masterprojectsfmcomms2zed"(My path where library is downloaded on GITHUB, I downloaded version file named "hdl_hdl_2015_r1.zip" to suitable for VIVADO 14.4.1 which i have), this does not run as same as instruction, VIVADO's message announce :"couldn't change working directory to "C:Doan2hdl-masterprojects-mcomms2zed": no such file or directory". I'm sorry about silly question but i'm very new about ZEDBOARD,if anyone have the answer, please help me, thank you very much!!!
  • zedhed
    0 zedhed over 10 years ago
    Hi Tang,
    I think that Vivado is going to expect "unix-style" path delimiters when specifying directories instead of using "dos-style" path delimiters.
    Try re-running your command using this one here:
    cd C:/Doan2/hdl-master/projects/fmcomms2/zed
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Thank you, you are very kind, i fixed it and it ran, thank you once again!
