Avnet Boards General Accessing AXI DMA using HP3 port
  • Subscribers 374 subscribers
  • Views 587 views
  We are  working on linux 3.15.0 kernel from analog devices on my ZED board.
We want to transfer data b/w PS and PL using axi-dma on HP port 3.
My config base address is at 0x40400000.
Here is my device tree
axi_dma_0: axidma@40400000 {
                        compatible = "xlnx,axi-dma";
                        #address-cells = <1>;
                        #size-cells = <1>;
                        #dma-cells = <1>;
                        #dma-channels = <1>;
                        interrupt-parent = <&gic>;
                        interrupts = <0 29 4 0 30 4>;
                        reg = <0x40400000 0x1000>;
                        dma-channel@40400000 {
                                compatible = "xlnx,axi-dma-mm2s-channel";
                                interrupts = <0 29 0x4>;
                                xlnx,datawidth = <0x40>;
                                xlnx,device-id = <0x0>;
                                #xlnx,genlock-mode = <0x0>;
                                #xlnx,include-dre = <0x0>;
                        dma-channel@40400030 {
                                compatible = "xlnx,axi-dma-s2mm-channel";
                                interrupts = <0 30 0x4>;
I could see the dma channel registered in /sys/class/dma
dma1chan0 -> ../../devices/soc0/fpga-axi@0/40400000.axidma/dma/dma1chan0
lrwxrwxrwx 1 root root 0 Jan  1  1970 dma1chan1 -> ../../devices/soc0/fpga-axi@0/40400000.axidma/dma/dma1chan1
Is there any application to access this from user space.
Above method is using kernel drivers.
Other method i tried using memorymapping the base address and trying to access the registers, this also does not work.
Any pointers will be helpful.
Thanks in advance.
Ramprasad
    I guess you need a device driver to use this axidma to send data through HP port.... Even if you have an entry in the device tree there is still a need of driver to do the transaction...
    Hope this helps you...... Might be a late reply for your question......
  • metinburak_
    0 metinburak_ over 11 years ago
    You should use the kernel drivers, not the traditional mmap way. If you like I can provide you some code for transfering data
