Avnet Boards General CAT4 LTE Modem wnc m18q2fg-1 technical support question
  • Subscribers 374 subscribers
  • Views 684 views
thaitran
thaitran over 8 years ago
We're building a power meter with networking capabilities and have selected the wnc m18q2fg-1 modem as our modem of choice. We've designed our own PCB following the data sheet and I'm in the process of getting the modem up and running with our linux single board computer.
I'm having some problem with the modem as explained below:
We built a carrier board for the modem and this is plugged into a single board computer. The single board computer recognized the modem and it showed up as an usb ethernet device. However, I could not get it to recognize any sim card.
I've checked our sim detection signal and it seems to be working correctly, sending 1.8V to to modem when a sim is inserted. However, the modem does not produce a Sim VCC to power up the SIM card.
Can anyone tell me what might be wrong with the modem?
Attached is the schematic for the sim card circuit and modem for your reference.
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Thaitran,
    Are you using one of our products? Whether it be the Miroczed/UltraZed/MMP/PicoZed/U96/Mini-itx?
    --Josh
  • thaitran
    0 thaitran over 8 years ago in reply to jafoste4
    I'm not using one of the zed board. However, the modem was purchased from avnett. I called avnett support and was refer to newark support which in turn refer me to this board.
  • jafoste4
    Hi Thaitran,
    I unfortunatly do not have any experience in this area. My suggesiton to you would be to post this quesiton over at
    http://cloudconnectkits.org/
    Josh
